YZbat.... After you did your repairs did you turn your set on and leave it sit for 30 min? Some say your supose to so the components can warm to operating temp. From what i understand the next step would be to attempt the auto converge. This is the order I did things. Auto converge didnt do much so i went into the standard menu on screen, then video, converence, manual adjust. I then started from the center and with the red aligning to the white. Work your way out. Then go to the blue and do the same. Try this before going into the depths of hell called the service menu.
As for sixfour.....I dont think I can help you. That would be a larry dillon thing. I can only speculate that the board was damaged during soldering or removal or something. Did you double check/label or your connections? good luck bud. I'll take it off your hands if your in the chicago area.
I WOULD LIKE & APPRECIATE IF I COULD GET A COPY OF A MANUAL TO
HELP ME FIX THE COLOR DISTORTION CONVERGENCE IN MY SONY MODEL#
KP-51WS510 I READ I COULD CHAGE THE CONVERGENCE BOARDS IC-392-560
IS THIS CORRECT.
THANK YOU
HARRY FORMANEK
Thanks to JRoque's comments about the 2 pico fuses (PS6503 and PS6504) on the G-Board (power supply). In my case, I replace the D-Board after the display went all warped, distorted, and almost in a 3-D in focus. After replacing the D-Board, the display did not change a bit though I can tell that the color is more vivid on the new board. After replacing the 2 pico fuses, everything worked fine and the focus and the color saturation on the new D-Board was multiple times better than what I had on the old board. The color and brightness level is just as good as the newer LCD sets currently available on the market. The G-Board is easy to pull-out so you can work with it with your soldering iron. Thanks, again, JRoque! By the way, the 2 pico fuses costs me an additional $3.98 !
Thanks to the great help i have almost completely repaired my tv. the problem is now i have a green oval in the middle of my picture. The other 2 colors are working great but the green is just the oval. any ideas on how to fix this would be greatly appreciated.
After looking at my tv more closely, i noticed that the green is showing everything that it should, its just only in an area about 3 inches wide. Once again any ideas on how to fix this are appreciated.
thanks again
update: i found out that it was a poorly connected wire so once that was done the TV works again.
if you people would really read these forums and post as most of you claim you would know that most of the manuals and service data is available on techlores home page under the resources tab in the technicians corner.
LMAO Larry! I was just scrolling up and saw more people asking for service manuals and turned to my wife to say......."if you people would really read these forums and post as most of you claim you would know that most of the manuals and service data is available on techlores home page under the resources tab in the technicians corner." But as you know you already said it!
I believe it. I dont know if you ever read over my thank you post but "THANKS" for your help with my set. Its working beutifully again with no other problems. We are moving to a new house next weekend so naturaly Im worried about moving it again. We shall see.
you can find the service manual of this set on the home page of techlore under the resources tab and then in the technician's corner. it will show you a chassis breakdown and where the convergence IC's are. Good Luck
I swapped both chips, two 5A pico fuses, tested all the 3.15A tested all the 4.7k resistors. checked and rechecked all my connections. and now the problem is worse and on a different color. First it was the red, now it's the blue.
And I have now lost audio
Same problem with convergence so won't repeat it here. Center of picture is fine but much worse at bottom and top (bowing effect). I suspect stk's should be replaced and possible picos. Does the top and bottom bowing indicate which device is going out to lunch?
I had planned on replacing both stks and the picos but after removing the back and seems I can't even locate them, the other half is pushing to replace the set with a Vizio or something else. Who knows, maybe I will part this one out. Its a shame because it has been a good set but alas only an area about 1 square foot in the center is perfect then drops off from there.
Hello Larry: I have a KP-51WS510. Today I turned on the set and the red colour is all over the place. When I try to converge it I cannot alighn the red with the rest. The middle row seems ok but the left and right side is off. If I try to move it left right it becomes distorted and grainy. The top left and bottom right are off completely. What should I do.
Cheers,
For those of you who don't want to wing the installation http://www.TvRepairKits.com has put together a complete kit for the Sony set. The kit includes factory original Sanyo STK chips, the 3.5 and 5AMP pico fuses, 4.7 OHM resistors, thermal paste, and a step by step photo instruction guide for the KP series.
Also note that we just purchased a large QTY of original Sony/Sanyo STK392-560 chips in the original factory Sony boxes. These were leftovers from a Sony supplier.
Hi, it appears that I have the same convergence issue with my Sony KP-57WS520 and would like to try to solve this problem myself if I could possibly get a copy of the service manual sent to [email protected]. Thank you,
Hi, it appears that I have the same convergence issue with my Sony KP-57WS520 if I could possibly get someone to send me the manual to [email protected], I would greatly appreciate it. Thanks,
DanaandTim, Go to the sites home page and click on the resources tab, then onto the technicians corner , then view all downloads and scroll down till you find your model and download it.
IS THIS CORRECT.
THANK YOU
HARRY FORMANEK
it is available in the technician's corner here at techlore under the resourses tab on the home page
Do I need to remove the individual boards to change the ic's or can I just pull the chassis out enough to angle up to work from the bottom side?
Thanks again.
thanks again
Thanks for all the help and suggestions
I have the same convergance problem. can someone send me the service manual so i can do this myself?
Thanks.
I have convergence issue with my Sony TV. Can you please email me the service manual for Sony KP53HS20
Thank you
I have a KP51WS510 with a blue convergence problem. Where on the D Board are the CI chips. I know what they look like but do not see them.
did you use good replacement IC's? ALL IC;s are not alike even if they have the same numbers
Always replace them both at once!!! Only with original Sanyo IC's
AAH too far for me!! I am in northern Michigan
Cheers,
Mike
Stop trying to adjust it ( you may never get it straight now), and read backwards through this thread...
MIKE, Replace the two convergence IC's BEFORE you touch the adjustments or you will mess it up bad!!!
Finaly found those pictures.....
Replaced the two convergence ic's and adjusted the convergence and have the sharpest cleanest pictre ever...thanks guys.
