Hi, today i went to turn the volume up on my tv using the remote that came with my set top box. I pressed the volume up button once but the volume shot up until I pressed the down button. Then when I tried to turn the TV down to a normal level, I presses the volume down button once and the volume shot down to zero on its own. I then grabbed the remote that came with the TV and the same problem was there. Saying that, I'm convinced it's the TV and not the remotes. I can adjust the volume from the buttons on the TV its self without any issues. The other thing is the input button acts dead when I press it then may or may not work after a few attempts. So, could this be a remote sensor issue, and if so, is it an easy fix? Please if you can reply via email, that would be great. I will try to keep checking back here. [email protected]
Bob..
Toshiba 55" TV. Volume and input buttons acting up.
Tue, 11/06/2018 - 16:47
