I am also victim of the green blinking light and my Mitsubishi WS-65513 has no power. I am somewhat handy, but have never repaired a TV before. I have read it may be bad capacitors in DM Module, but not sure. If anyone can offer pics and or step by step instructions and possible dangers, I would greatly appreciate it. [email protected]
I will send out the repair info to you. Good luck
I am also having the same issue with this TV. Can u send me the repair info? [email protected]
Sure thing! I will send that right out to ya. Good Luck
HI Larry, I am having the same issue with my WS-65513 with the blinking light and no power. Could you please help me out as well? By sending me the instructions on the fix too. Surely would appericate it. Thanks!!!
I also have the same problem on Mitsubishi
WD-52825 where the TIMER LED continues to blink in green, hence, I'm
not able to turn ON the TV. Have tried to perform SYSTEM RESET multiple
times to no avail. Could you please send me step-by-step repair
instruction?
My email address is [email protected]
Many Thanks,
Wilson
I too have the blinking green timer light on my WD62525. I replaced three of the four capacitors on the dm module. All three were popped at the top of the cap. I replaced them with 1000uf 35V caps. The set was put back together but is still have the blinking green light. Does anyone have any ideas on what the continued problem may by?
MM? why did you not replace all four Capacitors, you might have now ruined the DM because of the mistake?? That was a silly move on your part my friend, as just because it was not swollen at the top does not mean it was not bad! You probably now have an 800.00 repair for a 50 cent capacitor you did not replace before. Penny wise and dollar foolish? There are several other capacitors that go bad in this set. leave an e-mail address and I will share this with you.
Well you may be right, the reason is simply because the store only had three left and I assumed that I could get away with replacing the three that appeared bad. After i pushed the reset button the light went out, but when i thried to power up the set the red led began to flash with no picture. Do you think it is possible to reverse my mistake? If so what ideas do you have? Any info you can provide will be greatly appreciated.
Thanks Rubin
I also hope they were not radio Shack capacitors? They must be the high temp type of capacitors that are marked 105C instead of the 85C type. rubin, I will send to you the repair guide as hopefully it will work after the replacement of several other caps in this model that goes bad. If not, I'm afraid there is no way to reverse a blown out DM module except to replace it.
hello, im having the same blinking light problem on my mitsubishi ws-65513. i have replaced the 4 capacitors on the dm board with 1000uf 35v capacitors but the tv keeps blinking...i was wondering if you could send me the repair instructions to my email [email protected] . thanks.
i also have a prob with my mitsu 65613 and the blinking green light will u send me the info please [email protected] my email addy thank you, Jim Haney
Same problem with WD-52825 blinking green light. Can someone send me the repair. I found 2 bad caps on the Power supply and 2 more on the input pannel. The stby circuitry is now working but still blinking. The DM caps were replaced but still have problem. Please sent manual or anything that can assist to [email protected].
I have a WS-65513 and have replaced the 4 capacitors in C9B01, C9B02,C9B10, and C9B11 with the identical 1000uf 16V 105 degree caps. This only took me about 45 min once I found them, but the green light continues. I have not been able to find any other caps are visibly blown. Any ideas? If you could please e-mail me the service manual to [email protected]
Philipp
Hey Larry,
I got the same issue for the Mitsubishi 65513... could you email me the instructions as well? Please send to [email protected]
Thank you so much!
Zac
Same problem with the the 65513. please email the repair instructions to [email protected] yahoo.com. Thanks so much.
Larry, same issues with my ws 65713,, I think I can fix it if you could forward me the info to [email protected] Thanks so much Ray T
I also have the same problem on Mitsubishi WD-52825 where the TIMER LED continues to blink in green, hence, I'm not able to turn ON the TV. Have tried to perform SYSTEM RESET multiple times to no avail. Could you please send me step-by-step repair instruction?
Many Thanks,
JR
Hi Larry, i am also having the same problem with a mitsubshi ws-65819 rear projection tv with no power.could you also send me repair instruction.my e-mail is [email protected] you,rj.
Hello, that darn blinking light of death has also got me, can someone please send me the instructions or repair manual to replace those caps? I have removed the dm module. please send to [email protected] thank you
i guess i should add I have the ws-65513 mitsubishi
I have a WS-55513 with the same blinking green LED of death. Can you email me the necessary repair information. I'm pretty handy with a soldering iron.
thanks,
Keith
I, also, have the green blinking plague of death on a WS 65713 (may Mitsubishi be infected with a similar affliction!--shame on them--NEVER buy another one of their sets. Things like this happen to every company and are understandable--NOT making it good is inexcusable.) I would very much appreciate a copy of the instructions. Thanks so much.
I have the same problem except I have power (just a black screen with the blinking green light)with the WS - 55813...blinking green light. Can someone send the instructions on how to fix this. I have read numerous posts and it doesn't sound like a difficult fix. My e-mail is [email protected].
I also have the blinking green light of death (BGLOD). Can someone send me the repair info and (if you took any) some pictures of the repair? Thanks! WD-52825
Me too I have the same problem. WS65513 green blinking timer problem. Please send info for repairs to [email protected]. Your help is much appreciated.
Hi, Green blinking light on my Mitsubishi WS-65513, reset does not work. Obviously a very common problem on this model. Can you please send a solution?
Cheers!
i have ws55513, can someone send fix directions to me on blinking light w/ no power on or functions....only blinking light. Thank you!! e-mail [email protected]
I also have a similar problem with a ws-55311. If I unplug and plug back in the green light blinks then goes out. Set will not turn on. If you could send any repair info it would be greatly appreciated. [email protected]
I have a Mitsubishi HDTV 1080 Model WS-65611 and have the dreaded flashing green light. Could you send me info on how to repair DM Board [email protected] Thanks
am also victim of the green blinking light for one week and my Mitsubishi WS-65513 has no power.
