I have a JVC, HV-Z34L1 and it is stuck in standby mode. It worked fine then one day nothing, I took it to a repair shop but they could do nothing with it . 2 months latter I plugged it in and it worked, shut it off next day same problem would act like it wants to turn on then 2 seconds later back to standby. Ther is no bliking of lights just on to the green and 2 seconds latter to the red stuck in standby. this tv is only 2 yars old, any help would be great.
Sorry Rocko, according to my sources, this is a european model, and I have no source for service info for these types of TV sets.
This sounds to me like a power related problem. The issue with JVC TVs is that there is little service information available outside of authorized service centers. If unplugging the set for while "restores" the set, then that is an interesting symptom or clue. Try that and report the results. There may be a problem on one of the data lines internally that is causing the CPu to shut down the set. Internal "batteries" that allow the set to weather short power outages may retain this error condition not allowing the set to function until the "battery" runs out. Once this occurs, the CPU in effect will reset and clear the condition.
Keep us posted,
Dan
my jvc tv is stuck on standbye now, although my tv doesnt even show the green light. i plug it in and it just shows the red light, no buttons work, even on the actuall tv . annoying
