Mitsubishi WS65613 Light blinking
612 posts / 0 new
Tom T
Tom T said: Larry
Tom T said:
Larry Dillon said: Dan and Cariha, I will send you out the common repair fix for this TV set tonight. Good Luck with the repair.
Hello Larry, My Mit. Tv, WS65613, blinked for 3 or 4 days then it's not turn on any more. Could you please email me the instruction to fix that problem? [email protected] Thanks. Tom T
Thanks Larry. TV was fixed. Here is my feed back:
1. Use digital camara to take pictures before removed the board.
2. Change 4 capacitors as you indicated on DM board. I ordered from Mitsubishi part no. 181P734030 ( 680uF16v)
3. After reinstalled, checked all connection agaist the pictures BEFORE removed the board.
Holla. I make it.
Thanks Larry again.
Tom
Great news Tom on the repair
Great news Tom on the repair of your TV set! Tagger I just sent out the repair directions to you. Good Luck
xmas
Hey Larry I am a victim of
Hey Larry I am a victim of the blinking green lights, Can you send the fix to [email protected].  Thanks
The repair documents and the
The repair documents and the service manual are on their way to you. Good luck
Jimbo17361
"LARRY" Your are the man! I
"LARRY" Your are the man! I have a WS55859, green light blinking. Replaced the 7 capacitors, cleaned mirrors and lamps. TV is like new. And my capacitors were not swollen, TV repairman wanted $600, he said capacitors were good. He was going to get whole new module.
Great news Jimbo! Glad to
Great news Jimbo! Glad to hear you repaired your TV set without the rippoff.
Conge
Hello Larry. Heard that you
Hello Larry. Heard that you're the man! Can you send me this info also. I have the WS65613 with the green blinking light. I have a warranty and a tech coming tomorrow hopefully. But I am making sure he has the right parts for the fix. My e-mail addy is [email protected]. Thanks Larry!
I am sure the tech will fix
I am sure the tech will fix the set right. If he does not do as the documents say, complain to his boss but remember, you catch more flies with honey then you do vinegar.
Chad1336
Hi all,
Hi all,
I have a WS55813 that has recently started blinking and won't turn on.  Been looking through several posts here and wanted to request a copy of the instructions on how to fix.  My email is [email protected]
-Chad
I just sent you the manual
I just sent you the manual and the repair documents. Good luck with the repair.
wakesurf
Wow I thought I had such a
Wow I thought I had such a unique problem... I  could sure use the same advice that seems to be posted for the ws65613 blinking problem.. Can you please help..        thanks Brian
Brian, how do I help you
Brian, how do I help you without knowing where to send the documents?
Tom Godfrey
 Please send me the DM Capacitor fix, I have a MITSUBISHI WS65613, that has had this problem in the past, and now has intermittent wavy picture.  [email protected]
Tom
Tom they are on their way.
Tom they are on their way. Good luck with the repair.
Kristie
Larry, please send me the
Larry, please send me the info to fix the infamous blinking green light on the Mitsu WS-65613.  Also could you rate the difficulty for the repair.  Should I let my handy-man husband attempt this or leave it to the pros?   Thanks for all your help!  Mitsu should put you on the payroll!
dmills
Hi Larry, another casualty of
Hi Larry, another casualty of the blinking green light here!  Any chance you could forward me the fix instructions to the following e-mail address: [email protected].  Also if anyone managed to find a reasonably priced repair company in the Phoenix, AZ area, I would really appreciate the contact details.  I won't be buying a Mitsubishi product again, that's for sure!  Thanks - really appreciate your help.
Kristie and dmills, I will be
Kristie and dmills, I will be sending out that info to you in a short while. Good luck
BradF
I just got the 'green
I just got the 'green blinking light' of death. Is it really just a problem with the capacitors ? Could you also send me the repair documents you've been mentioning ? A friend does tv/vcr repair work and won't charge much.
Thanks !!!
BradF
Could you also send me the docs for a 55613 model to [email protected] ?
Brad
Brad, I will send those out
Brad, I will send those out to you a little later tonight. Good Luck with the repair.
Tom Godfrey
I got the capacitors from Mouser, did the repair, but I still have wavy picture, vertical kind of ripples.  Any other suggestions, or is it time to give it up?
Tom
Tom, can you send some
Tom, can you send some pictures to [email protected]? And I need a model number as well.
Tom Godfrey
Thanks for lookin' at this for me.  I sent off an explanation and 3 pics, first turned on, 60 sec then 2 minutes.  Let me know if you need anything else.
 Tom
mattandlisa
Greetings, another one with the green blinking light problem. The model is a 65 inch ws-65613. The problem just started tonight. Could you please send me the needed repair documents to [email protected].
thanks!!
Matt, the repair information
Matt, the repair information will be to you before the morning sun. Good luck with the repair.
kdhough
I am having the same Green Blinking Light problem. Could you please send the manual and instructions to me at [email protected]?
Kevin
Kevin, what's the model
Kevin, what's the model number. There are three different repairs for different models.
wendy w
I have a mitsubishi ws65513.
I have a mitsubishi ws65513. It will not power on, has a green blinking light. Can someone please advise me with a solution to this problem. [email protected]
Wendy W, if you leave an e
Wendy W, if you leave an e-mail address I will send you a repair procedture as well as the service manual for the repair of your TV set. Good luck
wendy w
Larry Dillon said: Wendy W,
Larry Dillon said: Wendy W, if you leave an e-mail address I will send you a repair procedture as well as the service manual for the repair of your TV set. Good luck
