Mitsubishi WS65613 Light blinking
612 posts / 0 new
NexusX
NexusX's picture
I have a 65" rear projection Mitsubishi HDTV that is about 3 years old. When it is plugged in the light continues to blink non-stop. I have left it unplugged several times. When I plug it back in the reset light still blinks. It has happened before and I unplugged the tv and it quite after a couple minutes and I was able to turn the tv on. Can you guys help me out?
Larry Dillon's picture
 1-  CHECK FOR 12 VOLTS DC
 1-  CHECK FOR 12 VOLTS DC (AC-OFF DETECT) AT PIN 3 OF PC9A21 IF MISSING REPLACE PC9A21 PART # 268P058020 ON THE POWER PCB.  2. SHORT DETECT SHUTDOWN (PIN 13 OF IC700) CHECK FOR OPEN L902 PART # 351P155010 OFF Q904 C (15 V SUPPLY) ON THE MAIN PCB.   2-  SHORT DETECT SHUTDOWN (PIN 13 OF IC700) CHECK FOR SHORTED D913 PART # 264P722010 AND OPEN Z901 PART # 283P039020 (Z905 AND Z900 M.    3-  CHECK FOR BAD CAPACITORS IN DM MODULE.    4- CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB.   5-  SUSPECT SHORTED WINDINGS OF T5A31 PART # 349P216010 ON THE MAIN PCB.     6- SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.  7-  SHORTED HORIZONTAL OUTPUT TRANSISTOR.  8-  COOLENT HAS LEAKED ON THE MAIN BOARD FROM THE CRT'S AND HAS DAMAGED THE MAIN BOARD BEYOND REPAIR. also if the 24 volt B+ and or B- Is missing from the convergence ICs, change both convergence ICs as well as the defective pico fuse in the power supply. This is not a quicky type of repair most likely.     These are a few of my notes on this Set from me and a few of my buds in the buisness.  Good Luck and let us know how you made out with this set.
NexusX
NexusX's picture
Larry, I fixed my tv after
Larry, I fixed my tv after reading this post http://www.techlore.com/forum/thread/16439/?page=1  and going to HDTVvoice. It was #3 on your trouble shooting list. I removed the DM Module and found the 4 capacitors swollen on the top. I found 4 1000ui 35v volt caps at the local Radio Shack and replaced the old ones. I am very happy that the tv is now working. I couldn't believe how dusty everything is inside after 3 yrs. I am going to vacuum the inside carefully. I can see a layer of dust on the lenses and am looking for info to clean them before I reassemble the unit. I have some pics but didn't know how to post them.
Porsche356A
Porsche356A's picture
I also did the 4-capacitor
I also did the 4-capacitor replacement. I couldn't find the Panasomic 1000uf recommended, but ordered 493-1287-ND from www.digikey.com. These are the identical size of the ones in my Mitsubishi 65613. I found that I had to use a very high temperature to desolder them while wiggling the capacitor. The new ones went in fine. When I powered it back up, all seemed perfectly fine, and the picture was brighter than it had been in a long time (cleaned the lenses while inside the case). A couple of hours later, it suddenly reverted to its former bad behavior by suddenly going dead slient with no picture, but a solid green power LED. I powered it off and back up, and the picture was back, but every hour or so it continues to turn off the video and sound. So, I replaced all 4 capacitors again, with the identical result. Anyone have that same problem? Or know where to go next?
To^iTo^iTo^i
To^iTo^iTo^i's picture
I have a 65" (WS65813) rear projection Mitsubishi HDTV that is about 4 years old. I just got the LED light continues to blink non-stop this morning. I have left it unplugged several times. When I plug it back in the LED light still blinks. It has happened before and I waited for a few minutes and I was able to turn the tv on.  My search send me to this link.
Any help with instruction on how to fix this problem is greatly appreciated!
Please email: [email protected]
I have sent you the
I have sent you the documentaion you requested, as well as the factory service manual. Good Luck
Sudheer
Sudheer's picture
My Mitsubishi WS-65613 started blinking green this morning and does not stop blinking and I cannot turn it on.
Can you please send me the instructions and service manuals to fix this infamous blinking green light problem. I've had this blinking green light problem before but it would stop blinking after blinking for a long time (30min to 1 hour). This morning it started blinking again but doesn't stop.
 Are there any precautions one must take to attempt such a repair other than simply unplugging the unit. I'm sure I can solder the new caps.
Please send the information to: [email protected]
Sudheer
Sudheer, I sent the info you
Sudheer, I sent the info you requested as well as the original factory service manual. Good Luck
jjohn000
jjohn000's picture
Larry Dillon said:  1-
Larry Dillon said:  1-  CHECK FOR 12 VOLTS DC (AC-OFF DETECT) AT PIN 3 OF PC9A21 IF MISSING REPLACE PC9A21 PART # 268P058020 ON THE POWER PCB.  2. SHORT DETECT SHUTDOWN (PIN 13 OF IC700) CHECK FOR OPEN L902 PART # 351P155010 OFF Q904 C (15 V SUPPLY) ON THE MAIN PCB.   2-  SHORT DETECT SHUTDOWN (PIN 13 OF IC700) CHECK FOR SHORTED D913 PART # 264P722010 AND OPEN Z901 PART # 283P039020 (Z905 AND Z900 M.    3-  CHECK FOR BAD CAPACITORS IN DM MODULE.    4- CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB.   5-  SUSPECT SHORTED WINDINGS OF T5A31 PART # 349P216010 ON THE MAIN PCB.     6- SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.  7-  SHORTED HORIZONTAL OUTPUT TRANSISTOR.  8-  COOLENT HAS LEAKED ON THE MAIN BOARD FROM THE CRT'S AND HAS DAMAGED THE MAIN BOARD BEYOND REPAIR. also if the 24 volt B+ and or B- Is missing from the convergence ICs, change both convergence ICs as well as the defective pico fuse in the power supply. This is not a quicky type of repair most likely.     These are a few of my notes on this Set from me and a few of my buds in the buisness.  Good Luck and let us know how you made out with this set.
jjohn000
jjohn000's picture
jjohn000
jjohn000's picture
hey larry i have ws-65613 and
hey larry i have ws-65613 and the green light is blinking also luckily im under warranty and have a technician coming out tomorrow can he put the high temp capacitor adn if so which ones should i try and persuade him to use ????
He should already know, but
He should already know, but if the set is under a factory warranty, he will have to replace the DM board with one from Mitsubishi. If it is an extended warranty, ask them, if this is indeed the problem to replace them with 105C capacitors. Good Luck.
todd smith
todd smith's picture
Larry, I've got the same
Larry, I've got the same issue here with the continuously blinking green light on my WS-65869 after a power surge last night.  Left it unplugged all night but still blinking this morning.  Can you send me the instructions and service manual?  Much appreciated.  [email protected]
In your case, when there is a
In your case, when there is a power surge, most likely the DM module or the power supply is at fault. I do not have this model number of set, You can download one from HERE I will however send you the different documents for the different DM modules. Good Luck
hikingkev1
hikingkev1's picture
larry this is amazing how
larry this is amazing how many people have this problem.I too suffer from G.L.D,green light of death.tv runs great for weeks then bam flashing green light.its a ws-65613 hdtv 65 inch.I sure could use a fix for this.any help would be great.
chrisandnat
chrisandnat's picture
I have fixed two of the newer
I have fixed two of the newer TV's with the blink
My steps to fix:
http://www.chrisandnat.com/temp/BlinkingTV.pdf
Todd, I have sent you the
Todd, I have sent you the documents you have requested. Just one thing, if you do not know how to solder, please seek the help of a trained tech to assist you in the capacitor replacement. Good Luck
Garretf
Garretf's picture
  I am also having this problem where the green light just blinks and the tv will not turn on.  I have tried to reset it but it just keeps blinking.  Could you please send me instructions and manuals on how to fix this problem.  I called the place i bought it from and they said that it probably wasn't worth fixing.  I just bought it 2-3 years ago and can't believe that isn't worth anything anymore.  Please send info to [email protected]
Garretf, I have sent you also
Garretf, I have sent you also the documents so hopefully you as well can join in the many here who are saving a ton of cash by repairing their Mitsubishi TV sets by replacing some capacitors.  If you have no printed circuit board soldering experience, do not chance it, take the board to a pro to assist you with the capacitor replacements. Good Luck
hikingkev, I tried twice to
hikingkev, I tried twice to send these things to you. They keep coming back to me as a bad e-mail address. I am sorry i do not have the time to keep sending these things out as a lot of folks want them but they put good addresses in the post.
Jlh
Jlh's picture
I also have the ws65613 with the non stop blinking LEDs.  Please send me the docs.
Jlh
Jlh's picture
Jlh said: Larry, I also have
Jlh said: Larry, I also have the ws65613 with the non stop blinking LEDs.  Please send me the docs.  [email protected]
Larry.......anyone.....I could really use the ws65613 docs.
 JLH
JCorn
JCorn's picture
Hi,  I have a Mitsubishi
Hi,  I have a Mitsubishi Diamond WS-55813 that started behaving the same way today, it was purchased new in 2004.  The green power/reset light continues to blink but the unit will not come on.  I unplug everything and when I plug it back in the green light continues to blink but never comes on.  Could you please e-mail me the fix?  Thank you.
r/Jeff Cornell
e-mail: [email protected]
JCorn
JCorn's picture
Thanks chrisandnat, found the
Thanks chrisandnat, found the fix with pictures on your post above...
 see: http://www.chrisandnat.com/temp/BlinkingTV.pdf
Garretf
Garretf's picture
  Thank you for your help!!Smile  Replaced the capacitors and the TV worked.  Cleaned the lenses and this is the brightest and clearest the TV has ever been.  Its like having a new TV!!!
Glad to hear Garret! Yes I
Glad to hear Garret! Yes I always get that response after repairing a TV set and then cleaning the lens from the dust that gets sucked into the TV set like a magnet. You should clean it at least twice a year.
paul_g
paul_g's picture
Hi Larry, I guess I am
Hi Larry, I guess I am another "dreaded green light" problem. I have a 65613 with the blinking green light. I am a retired communications tech and will have no problem changing the caps on the DM board. What would be nice before I start would be the instructions for removing the board instead of just "winging it " Could you email me the info like you nicely did for the other fellas ?
Also I'm guessing the DM board is most likely short for "diagnostic monitor" Is that correct ?
Paul in El Paso
Should I go and knock on
Should I go and knock on every door in El Paso and ask if they are Paul? Whats your e-mail man?
paul_g
paul_g's picture
Larry Dillon said: Should I
Larry Dillon said: Should I go and knock on every door in El Paso and ask if they are Paul? Whats your e-mail man?
Sorry about that,thanks for the reply.  My email is  [email protected]
paul_g
paul_g's picture
To all of you who may be
To all of you who may be attempting the capacitor fix on their Mitsubishi a word of caution. Modern circuit boards are easily damaged by static electicity. Techs in the industry use grounding wrist straps when handling these boards. Simply walking across a room with the circuit board in your hand could damage it. Try to ground yourself to the metal chassis of the tv when touching circuits.Even though the Tv is not plugged in it will equalize your electrical potential. Handle the circuit board carefully by the edges when taking it to your workbench. Try to gound yourself while soldering on the board. I bring this up after reading some posts that stated after changing out the caps they ended up with new or different problems. Thats why you see new circuit boards shipped in the anti static special plastic bags.
paul_g
thank you Paul for the tip!
thank you Paul for the tip! Yes it is absolutely true, staic can certainly knock out a digital board. Those instructions should be there soon.
