I have WS-65809 tv and the tech is saying it is the convergence IC and asked $400.00 to fix it. How much did the part cost? for the diagram I have strong feeling it's available somehere online. Please if someone find it let me know too, I could not find it.
Fadel [email protected]
larry, will you please e-mail me the service manual for WS-55513 the pitcher went out i unpluged it hit the reset button and the green light just flashes and the t.v. will not turn on. also before it wouldn't come on it would cycle through all of the different screen formats by it's self. Do you know what would cause and how to fix it.
I need a little help. I have a Mitsu 60 inch big screen (i think its vs-60607) and around 10 years old. My son was playing video games on it when the image started to shrink then the power went off. It would turn on briefly, then shut down again. After several attempts, it would start with 3/4 of the screen displayed with lines across the top then shut down and eventually remain powerless. This is my first problem with the t.v. Do you think this sounds like an easy and cheap fix or should I think about purchasing a new t.v. I'm fairly handy but have no experience with electronics. Thanks for your help..
The best advice I can tell anyone at this point. at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK ICÂ’S , not those cheap aftermarket or china made ICÂ’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases,
I have one of these projection CRT's with the Convergence issue, I am OK with soldering so I am going to attempt this myself. However, I read CRT and I think of the old school CRT's. Do I need to be worried about high voltage even though the TV would be switched off and unplugged? If so I'm thinking of buying the chips and seeing if someone professional will solder them for me.....Unless someone local to Dallas, TX is willing to do it for a reasonable cost. Thanks.
I have horizontal lines running accross the tv, i see multiples of everything, tried adjusting the convergence but it didnt help, it almost seems as though the tv is out of focus, any ideas on a cheap fix? [email protected]
I have a mitsubishi VS-55707 that has horizontal lines running across it. I see multiples of anything on the screen. I tried adjusting the convergence but it didnt help. The whole screen is jumping and it almost seems as if the whole set is out of focus. any way to fix this? [email protected]
Ok, i have a Mitsubishi VS-60705 Rear Projection TV that shuts off 2 seconds after turning on. Did the error code check and got Coded 22 - Short Protect. From reading this and other posts it comes down to IC's and pico fuses. I ordered the kit form tvrepairkits.com and the items arrived. I pulled out the board, located and replaced the IC's no problem. My problem is in locating the Pico fuses F9A04 AND F9A05 which a re referenced in this and many other forums. If someone can point me to where to look for these fuses, or are they labeled different on this model. I have taken pictures and can email them to someone if they want to show me where to look. my email is [email protected]
I have a Mitsubishi VS 45609 and the convergence failed on the blue gun. Replaced with a Genuine Sanyo 393-110 f(rom Audiolab Of GA) as indicated above. Worked great for a few weeks. Now I am having a vertical sweep problem where every so often the tv screen will zoom in and out approx 1/8 of an inch intermittently but not displaying any black bars.
switch the convergence ic's around and see if the problem switches to another color if it does interchange the convergence ic to see if you still have a problem with that pesky convergence ic'?
Larry D
Hi Larry I have a WS-55807 and I am looking for the service manual. I am working on the ICs and I am unable to get the board fully out. Any information would be greatly appreciated. Thanks! [email protected]
Hello,
I am looking for a signal board for a WS-65819, WS-55819 or from any WS-XX819.
I will take a whole TV or parts.
Part number is 930B881001. Other models used this module.
My board is not repairable.
I am a service Professional looking for this part or TV.
Please contact me directly.
Will pay for UPS shipping.
My Mitsubishi VS-55707 has been very reliable for the last 9-10 years. But it's starting to show its age, when I turn it on it is dark and the colors are bad. BUT WHEN IT IS WARMED UP (after 15 minutes or so) EVERYTHING LOOKS GOOD INCLUDING THE PICTURE. I was told something is wrong with the "Temperature Board". Can it be fixed?
flatheadv8 said:
Do you have a service manual for a Mitsub WT-46807? Where would I go to get convergence ICs and new fuses for it?
Had the bowed screen for a while and finally blew a fuse.
Thanks.
flathead
flatheadv8 said:
Thanks. [email protected]
well that is a good thing to hear. did you install the parts from the kit yet???
if you run into a problem please go to tvrepairkits.com/helpdesk and open up a trouble /repair ticket please!
Larry D.
Larry, i have a VS-60705 and was getting the 2-2 error code after replacing the IC's (We messaged each other on it before because i could not find the pico fuses, and you said "this model has the R 533 and R520 , .22ohm @ 2 WATTS and there are R8C60 and 8C49 2 watt resistors at [email protected] 2 watts" I replaced those resistors with same issue. I then replaced Resistors R8C801 through R8C804 (2W 560J) and the unit powers on now. However my convergence is way off - bowed in top, bottom, left and right. Help..
Ram RAM
Their is no such thing as a 'temperature board" Where do you guys get this stuff.
Either you are experiencing a high voltage problem or your CRT's are beginning to fail.
You need a real technician who has a CRT Checker to tell you more..
Call Mitsubishi and find a qualified Technician in your area.
Darren Danga
I am assuming you are not a pro Technician.
This is why their are authorized Mitsubishi service centers. Now that you fixed part of it and do not have the alignment equipment, nor the experience, you have gotten yourself into a bag.
Your TV has experienced a cascade failure in several circuits. This is a tough one even for a trained veteran tech.
I suggest you put the TV together and call someone qualified for help.
People... This is NOT the type of work for the average Joe or even someone with basic electronic knowledge.
Oh the Internet makes it seem so easy, Joe will type in his model number, google stuff and do some research. Then come to his own diagnostic conclusion with out ANY actual technical facts.
I know, we get these calls every day !
Well the FACT is Joe is usually wrong in his diagnosis.
Joe is usually being cheap too.
So Joe will either try fixing it himself of go and buy a new TV needlessly.
SO my advice is Joe, Call Mitsubishi and find an authorized technician in your area. Get the real facts and then decide what to do. Yes it will probably cost you something, but you will have piece of mind that you did the right thing.
Also for the DIY Joe's out their, TV's are dangerous. Electricity is nothing to play with. TV's Store an electrical charge for months that can Kill you DEAD. This is no joke. Be safe.
For the cost of and estimate fee and your time you'll take away from your family, it is better to call a professional.
Heck, I'll call a plumber when my sink is backed up and play with my kids any day, even if I could fix the sink. Being a fun Dad is more important to me.
i have just got a mitsubishi tv model vs-50607. i turn it on and 2 to 3 seconds later if turns right back of. no pic, nothing at all???? what do i do?????
The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon. http://www.fixya.com/support/r3342653-convergence_fix
oh the manual you asked for is now posted under the technicians corner under the resources tab on the home page.
having problems with a flashing green light. my ws-65711 mitsubishi big screen won't turn on. I tried to unplug it for 30 minutes and it still won't turn on. What is the problem? HELP please!!
Fadel
thank you
Hi larry,
Hi larry
I have a mits. ws-55807
i have a convergence problem cant converge blue or red at all
bought the kit and replace the ics and 2 fuses and now it is still doing the same thing
if you have any documentation you can send to me to help me out at all it would really help
thanks alot
sorry my email is [email protected]
larry,
Hey Larry,
It seems that you have helped lots of people. So it seems that many of us have the same problem with the
Thank You.
suggestions would be greatly appreciated
Larry D
My Mitsubishi WS-55313 keeps changing format. Used to do it only on one input but now is doing it on most the inputs. Any thoughts on this.
Hello,
Elmbrook Electronics Inc.
Milwaukee, Wis
i would use Graigs list to find your set as i did last year needed a Sony with a good signal board that got hit by surge.
Larry Dillon.
Thanks.
I got my Convergence kit from http://www.tvrepairkits.com/. i recieved them within 48 Hrs..
Larry D.
Ram RAM
Milwaukee, Wis. 53221
262-789-7737
Established 1974
Darren Danga
262-789-7737
Established 1974
That is some wise and true fact you speak there sir.
Larry Dillon.
Thank you, [email protected]
Larry Dillon.
