Hey sounds like sony makes as good of TV's as it does Laptops. i have the sony kp-51ws510. It's almost five years old and the other day my red shifted to the right about 3 inches except fort the center of the screen just right of center. cant adjust it with the tv auto or manual convergence. sounds like I need to get my d-board fixed or replaced. I have read most of this blog and hope someone out there can help. I have some 20 year old electonics knowledge and am not afraid to take out the board and replace it but soldering this micro cicuitry ait going to happen. the manual woud be helpful for removal and any fine tuning. Thanks a bunch
The TV I have is actually a Sony KP-51WS510 with the convergence problem. And I just bought the two STK392-560 Convergence IC needed. If possible can you or somebody else send me a copy of the service manual at [email protected] or at [email protected].
hi guys/gals: i am a service shop and have replaced the stk's and pico fuse but now set tries to come on 3 blinks and then goes to shutdown with 6 blinks. any ideas--HELP
michael
Is the D Board repair a DIY job for someone like myself with no soldering equipment/experience? I am fairly handy, but not quite as confident with electronic repair. If so, I'd love a link to the propere repair manual and a link to the parts. Thanks!
That service manual is available on the technicians corner download thread, on the home page click on resources then on tech corner link then click on veiw all downloads, and scroll down till you see it and click on it. Your problem looks like the convergence ic's as well as a pico fuses or two around the IC's or make sure you check the two green picos on the G board also. those ere picos a lot of DYI's fail to check. so they replace the two IC's and have the same problem. Good Luck!
need servise manual for KP-51ws510 and help with replace ic's and keep blowing picos!!!!!!!!!!!!
Someone please help E-mail me [email protected]
Thanks Viking
I have the same problem with the convergence of a KP-51WS510 model. Looks like the IC's are the way to go. Could I get the service manual please? [email protected]
My colors separated the day before we were planning on having a bunch of people over for a game. My wife called me while I was at work. Larry got me the schematic by the time I got home. I found a local television shop that sold me two stk-392-570 chips for 11 bucks a piece. I was told these chips run cooler than their precedessors. I got em in that night with no adjustments needed and they've been working just great for about a week now.
Larry Dillon said: you have a bad IC, or bad resistors in the Circuit.
Larry I downloaded the manual for this set, getting ready for the surgery, can't find the sony cross-reference listing for the STK392 560 in IC number. Is it in the 8000 series on the D Board?
hi, Larry, I like to get a copy of that Service Manual for Sony KP-51WS500 too. Do you think you can send me a copy. I have problem with my tv; i turned it on and picture starts coming up with pinky bluish and turns off by itself and lights blinks 8 times and pause and 8 times and pause. I asked someone and told that it may be problem with convergence ic's. I like to know how you can replace that IC. Please send me a copy if you could. thanks.
Blink code table:
8 blinks - High Voltage Error - T8005 is faulty (D Board)
Hey there everyone, I have the same problem that everyone else is having with the high quality Sony TV, model number KP-51WS510. I am looking for a D board or the STK's and can't find them anywhere. Does anyone know where to get them and where would that be. Thanks jjfay
They are called IC links, no mistake. They are labeled on the G board as PS5001 and PS5002.These are the 5 amp type, on the D board they are labeled as PS-8001 tru PS8007. These are the 3.15 amp type. I just looked it up in the service manual Parts list.
You're right, but on my D board I only have three per side of IC, the 4th is hard wired and they check good for continuity. I had a bad one on the G board, showed open.
contact PTScorp.com and see how much they will charge to repair your board or for an exchange board.
Thanks...
that manual is available as a download hre at techlore technicians corner fo free! here http://www.techlore.com/group/2/list_downloads
michael
Thanks for the link on the manual. I have another questions regarding the heat sink compound. Which type should I use #AS or #CR?
Thanks again...
as long as it is a thermal paste it really does not matter.
Thanks Viking
I am Looking to replace the to 6.8 resistor also for sony kp-51ws510
Jeremy
go here to dwnload serice manualshttp://www.techlore.com/group/2/Technician-s-Corner/ GOOD LUCK
replaced the ic and the picos but one main pico on the d board keeps blowing .?
any one know why please help.?
jason [email protected]
thanks
how do you check the stk-392-560 ic .?
Thanks jason
yes of course replace the convergence IC first, the check for a bad pico fuse or two.
Chan
go here for the iC'c
http://www.electronic-repair-kits.com/index.html
Did that and on the way. Also found the resistors I got hot.
Blink code table:
thanks for the help. with this problem, how can i fix it, what needs to be done to get it fixed? please advise. thanks in advance.
replace the D board and the service manual is available in the technicians corner section here on this site for free,
you can get a D board from PTScorp.com or from tristate module, the STK original IC's can be Purchaced from http://www.electronic-repair-kits.com/index.html. Good Luck
Larry, you didn't address my question about my D board, it doesn't have pico fuses under the heat sink, hard wired. Mistake by Sony?
