We turned on our Sony rear projection TV...and the convergence is a mess....we still get a piture although clearly the convergence is way off.....the front LED blink 4 times....the set is about 5yrs old and this is the third time it's needed repair.....I was hoping to get a service manual to decode what the 4 blinks mean and see if I could fix it myself......I've serviced other TVs....but I'm certainly no pro....any help is appreciated.
Well you could always go to http://www.servicemanuals.net and buy one there for about 25 or 30 bucks, or you could leave an e-mail address and I will send you one if you like. When you say you have had this set worked on before a few times, was it for the convergence problem? If it was, maybe the right IC's were not used. When you look at the convergence IC's, the proper IC's should have Sanyo printed on them, or they are inexpensive after-market parts. You can go to mcmelectronics.com and enter the STK number that is in that set and get the proper ones without spending an arm and a hand for them. Good Luck and let us know how you make out with this repair.
Larry,
I appreciate your offer to send me a service manual for my Sony KP-51WS500.
Thanks,
CWB
[email protected]
CWB, I sent you a manual that has the same chassis number, it will colse enough to troubleshoot the set With. Keep us informed about your progress of this repair. Good Luck
Larry,
I received the service maunal you sent...thank you.......when I turn the TV, the standby / timer LED blinks 4 times and them goes steady off...the TV picture comes on although convegence is obviouly way off. This code means a loss of vert deflection.....however, we do get a picture. The blinking code 4 and the fact we do get a picture appears inconsistant....also, when I go into error history, all areas are 0, suggesting all sections are working......any thoughts.
Is it possible that the convergence issus is due to a physical problem...such as someone bumped into the set and caused one the picture tubes to become out of alignemnt.....
Thanks,
Charlie
No, I have seen a bad convergence IC cause a vertical error on the blinking codes. Although it does not happen a lot, or lets say i have only seen it a couple of times, it does happen. Change the convergence IC's and make sure you test the voltage feed resistors that feed the + and - (plus and minus) 22 volts to the convergence IC's as well as the six circuit protectors they use in this circuit as returns on the IC's.
Larry,
Would you happen to have a copy of a Sony KP-43HT20 Service Manual that you could send me:) I have a convergence problem ( bowtie pattern - picture clear in the middle and colors separted on the left and right ). I would like to try and fix the problem by replacing the convergence ICs. Thank you.
Steve
I do not have the exact model number service manual, but the TV set your referring to is an RA6 chassis and I do have that service manual. If you would like a copy of it, you will need to leave an e-mail address and go to pando.com and get the free download so you can open this very large file. Good Luck with this repair.
Larry,
Thanks. My email is [email protected].
Steve
It is done! I mailed it to you Steve.
Thanks, Larry.
I'll let you know how it goes. My parts are ordered.
Steve
Great! Hope you fix it.![Sealed Sealed](/javascript/tinymce/jscripts/tiny_mce/plugins/emotions/images/smiley-sealed.gif)
Larry.
I would like to remove the D board and was wondering how the clips between the 'A' and 'D' boards work - I don't want to break them.
Steve
Larry,
I am having the same issue with my KP43HT20. The display is showing double images and is constant.
Can you please e-mail me the service manual as well?
Atul Chaudhary
Larry,
I forgot to give you my e-mail address. The e-mail address is [email protected]
Thanks,
Atul
Well did not really mater my friend, as I do not have that manual for you. But one can be gotten HERE Who knows it is a possibility I will get a copy in a month or so.?
Larry,
I might have fixed the convergence issue without repairing the tv. I did some more research and found a service manual for another tv. The manual had some instructions on diagnosing by entering display 5 Video and TV Power on the remote as quickly as possible. I pressed the buttons several times, and the problem was resolved.
Atul
Excuse me? Explain in a better form please.
Larry,
I have the same issue as Steve above - with a Sony in an RA6 chassis. Would you please send me the above referenced manual as well. (I'll also go to pando.com to get the free download to open the file).
Mike
denvermike, I tried to send the manual, I tried to save you 30 bucks. It came back as undeliveralble for a bad e-mail address. Now you will have to go to servicemanuals.com to get a manual. I got a manual from a friend just for you. Now i cannot send it unless I get it again. I tried twice to send it. This is your address you left. [email protected] It is wrong!
Larry,
Sorry - it was a typo.
Go to servicemanuals.com and you can get a service manual there.
I hate to say "me too" but I moved recently and I can't find my service manual. I have a KP51WS500. Since I moved the set I need to get into the service menu so I can adjust the convergence. If anyone would email the service manual to me I would appreciate it.
Thanks,
[email protected]
If the convergence is off a lot, the service menu will not help you. The service menu is ONLY to do tweaking of the convergence. If you try to adjust the convergence without replacing the IC's first, once you do replace the IC's, you may have one heck of a time adjusting the convergence, if you even can get it right again. if the convergence is off after you moved, the convergence board could be cracked, or something around the optics could have shifted a bit, and the service menu will not help you as well. If the convergence is just off a little and not all over the screen, yes the tweaking in the service menu might help. Good Luck
Dear Larry,
Would you please kindly send a service manual to me for my TV set:
Sony Wide Screen Model KP-57WS510
My E-mail address is [email protected]
My TV has a same problem as you answered before. The project TV suddenly went into convergence problem. Every object on screen gives 3 colour shadows. The lines on screen are not straight and look like first day of moon. The picture is stretched in the central area.
Thanks.
I have sent you the manual you requested. If you do not understand or know how to read the schematic diagram to trace and to follow the circuit flow, please do not hesitate to call in a tech to assist you in this repair. Good Luck
JNC I sent you a service manual. Just be careful and do not get into deep. if you have any doubts about what to do, please play it safe and call out a pro to assist you in this repair. Good Luck
Thanks so much for the manual as well as the tips. Will keep that in mind before I try anything on my own :)
Larry,
I need a service manual for a KP51WS500 to troubleshoot a red background with red retrace line vice black background problem. could you e-mail or send me a copy? Any information you can provide will be highly appreciated.
Thank You,
Charles
If anyone has thoughts on this problem, add them to this forum please.
Charles
