Mitsubishi WD-62825 Blinking Green Light
668 posts / 0 new
fatkit
Hello all on this forum.
Hello all on this forum. Please note that Larry may have issues keeping him from responding rapidly. If you have not received the instructions you can contact me at the following email address (remove spaces and swap @ for at):
shitsubishi at hugginsnet.com
I will send you a link and a set of instructions where you can download a ton of info on this. I have Larry's instructions plus my photo journal of the same repair. Again, please be patient, but if you send direct to me I usually respond within 24 hours.
Regards,
RobinH
fatkit
Also, for those of you whom
Also, for those of you whom have left your email addresses, I'll be sending you the info now. Please post back here when you have the info so that we know who's request has been satisfied.
fatkit
mmcmain1 said: I have not
mmcmain1 said: I have not received anything regarding the green blinking light of death on my WD 52725. It's been 5 days....not sure how long to wait.....but i understand Larry has health problems. Anyone know how long? If you have the info please send it to me at [email protected] Thanks!
Sent you the info today
fatkit
Enochstek said: Hey Larry, I
Enochstek said: Hey Larry, I have been cursed with the blinking Green light on my wd-62825. I would really appreciate it if you could send your repair info to [email protected] Thanks, Chad
fatkit
superchicken said: I guess
superchicken said: I guess every Wd62725 will fail eventually. Now its my turn. Mr Dillon, can you send me your repair instuctions for the Blinking green light. Sure would appreciate them. Thanks. Sorry. [email protected]
I'll send you this today, expect email from gmail account as aol doesn't like my home email addy for some reason.
fatkit
Unca d said: Larry, wd 62725
Unca d said: Larry, wd 62725 flashing green light. Had a storm last night and the set shut down and the light was flashing green. have read most of the threads and have not seen this one. Could the caps need replaced? please send me the repair manuals to make the fix. Thx! [email protected]
Sent the info today
fatkit
Unagem said: Larry, I really
Unagem said: Larry, I really hope you are still out there. I have the blinking light of death problem. Can you please send the instructions? I have plenty of experience soldering on PCBs, I just need to know which parts and where. Thanks - [email protected]
Sent info today
fatkit
Justing said: I also have
Justing said: I also have blinking green light on my 52825 i'm going to repair it if its the last thing i do can you send my information on what capacitor to replace thanks Justin [email protected]
Sent info today
fatkit
Wormboy said: I have the
Wormboy said: I have the Mitsubishi 62825. I've replaced the lamp and had the manufacturer confirm it was good. I pulled off the back cover, made sure there were good connections to the lamp assembly. The filter cover is on, the front cover is on. When I power up I get the red lamp light and error code 34. I don't think its the lamp. From all my reading I suspect there are some bad capacitors. IS there some kind of standard kit with the necessary parts and instructions? [email protected]
Sent you the info, and also there is a listing of the error codes in one of the manuals, will tell you better what that code means.
fatkit
IMSHORTY said: NOW IS MY TURN
IMSHORTY said: NOW IS MY TURN I HAVE A WD52825. WITH THE GREEN LIGHT FLASHING. I NEED YOURE HELP LARRY. IT WAS WORKING THEN ONEDAY IT SHUT OFF. RESET UNPLUGED TIME AFTER TIME DOES NOT WORK.ANYTHING I CAN USE TO GET HER RUNNING WOULD BE GREATLY APPRECIATED. THANKS.
I sent you the info via PM as you didn't list an email. Let us know how it goes.
fatkit
Stin said: Larry, I'm also
Stin said: Larry, I'm also looking for the instructions to repair a WD-62825. Please send them to jburgod at yahoo dot com if you don't mind.
Sent them today
fatkit
CARRILMM said: Larry not
CARRILMM said: Larry not sure if the instructions are still availlable for green blinking light in Mit wd-62825. If so please send to [email protected] thanks
Sent today
fatkit
don 1 said: i need help
don 1 said: i need help getting the schmatics on the ws-55711 model because i have the same blinking light problem if anyone can help please send them too [email protected] thank you
I sent you what I have, not sure if this model was included but they may help, especially the photos. The cap problem is easy to identify, all you have to do is look to see if the top of the caps are swollen, those are the bad ones.
fatkit
Timmy49 said: Dreeded
Timmy49 said: Dreeded Blinking green lite on a Mitsubishi WD-62825 are these repair notes still available?Thanks for any help [email protected]
Sent today
fatkit
Dman2772 said: I need a
Dman2772 said: I need a repair guide too. Is it even worth trying to fix? How often do the other boards in this unit have problems? Are these parts ok to use building a whole new designed projection tv? Could these boards be replaced by an alternative board? Any other information that would be useful please let me know Thank you very much DAN [email protected]
Dan, I can't really answer all your questions, too much on my plate to look up the info right now, but I did email you the info on pulling all the data I have.  There's tons of good stuff there.
fatkit
johnny_no5 said: Larry, can
johnny_no5 said: Larry, can you send me the diagrams and info to fix the blinking green light of death for the 62525? I opened the back and don't know how to access the DM? [email protected].
John, I sent you the info today, the pictorial will help you see how to access the DM.  IT's pretty easy, just make sure you don't mix up all those wires.
Also, SMU? As in Dallas?  My hometown, I miss that place.
fatkit
Jaimito43 said: Hey Larry,
Jaimito43 said: Hey Larry, Looks like you have been a savior here for regular folks who need some help. If you are still giving out the repair documents for the Mitsubishi WD-62825 would you mind sending me a copy? My e-mail is [email protected] . Thanks in advance. I'm on my third bulb in four years (Have also had the chassis rebuilt in the 2.5 years while it was on warranty). I replaced the third bulb and it worked for 2 months when I woke up yesterday and had the green blinking timer light. Your help would be greatly appreciated :)
Sent today
fatkit
pdcollins6092 said: Hey Larry
pdcollins6092 said: Hey Larry, if you are still giving out the repair document for the Mitsubishi WD-62825 would you mind send me a copy? My e-mail is [email protected] . Thanks in advance.
Sent today
fatkit
I'veHadItWithMyTV said: Hello
I'veHadItWithMyTV said: Hello all, I also have the WD-62725 and got the green blinking light (blinky), a tv repair guy/friend changed the caps for me. This lasted about 1 week then blinky came back with error code 37, then nothing at all. I followed some instructions off the internet and it was the FMT board. I bought a FMT board off Ebay, 3 days later after working great, back to blinky with error code 37 which is a lamp fan error code. I replaced 4 out of the 5 fans which did the trick, then, after 8 days of blissful tv heaven it shut down and went back to old blinky and now I cannot even get the error code. I am now thinking the DM board is faulty. Can someone please email the instructions service manual??? My email is [email protected] Thank you all so very much
Sent today
fatkit
dacarrera said: I have a
dacarrera said: I have a Mitsubishi WS-65615 with the same green blinking light problem. Could you please send service manual, repair instructions, or pictures that might help me with the thermal sensor or caps. My email is [email protected] Thank you
Just emailed it to you!  Good luck!
bryan lofton
Larry It seems I am on the
Larry It seems I am on the same boat like other posting here with blinking green ligh. Would you please help and any help can be send to [email protected]. I have WD-62725. I have seen the replacement DM board selling on ebay for 100 buck, would you think it will help to fix flashing green light. Thank you very much.
Brian Hillesland
I have the flashing green
I have the flashing green light of Death as well on my Mitsubishi wd-62825. The TV was working fine after replacing bulb for about 10 min. & then it cut out and started the green flashing light routine. Could you send the repair info to me at [email protected]?
Very much appreciated.
Radarguy101
Hi Guys,
Hi Guys,
I have overcome the green blinking light of death and set has been performing well. Well until now. I now have a random video noise showing up. I can see it on every input (Ant 2, comp 1, comp 2 and hdmi. Cannot see it on antenna 1. Strange huh. It looks like random lightning strikes on an analog video. There is no sound associated with it and it tends to not show up until the set is warm. I have the service manual with schematics and cannot seem to see how the antenna 1 signal is separated from the other inputs. Anyone have any clues? Anyone want to adopt it?
Angry_Radish
Hi there!
Hi there!
Looks like I'm in the same boat with the blinking light.
I do arcade repairs and have dealt with dried caps in many old games, never thought they would be in something this new :)
Could you please send me the caplist/info you have on repairs?
The wife and I are going mad actually having to talk to each-other :)
Joyce
Larry, same prob with the wd
Larry, same prob with the wd-52825. "Blinking green light of death" My email is [email protected]. Can you please send repair instructions?
Thank you,
babcoca822
Treboreous
I am having the same problem
I am having the same problem with my model WS-65315. I can't even find the DM board. It looks different than the other models I have seen. If anyone knows the location in this model please let me know.
rogsilva
I have the WD-62825. I don't
I have the WD-62825. I don't have a green blinking light but have a red blinking light. The error code is 36 which I know is the 36 Exhaust (Back Cover) or Lamp Ballast Fan failure.
What causes this failure?
Kai
Wow - It's unbelievable that
Wow - It's unbelievable that we're all having this problem and Mitsubishi can't/won't fix it.
Larry, would you be be able to send me the instructions for fixing my wd-52825 "Blinking Green Light of Death" ? Many, many thanks in advance. My email is [email protected]
Thank you,
Kai
Hedhunter
As long as you are sending
As long as you are sending out the repair info we could also use it. The TV is a WD25275. Blinking green light.
kirk80s
Hey I also have the same
Hey I also have the same problem as everyone else is mentioning (Blinking green light of death). Robin could you send me the fix to my email? It's [email protected]
