1707 posts / 0 new
caseybragg
Larry Dillon said: Check the
Larry Dillon said: Check the bulk or junk mail also. I am sending them again now.
Larry: I have the WD-52525 blinking light of death too (sort of).  Can you please send your documentation to [email protected]?  Thank you so much!
Are you accepting paypal thank yous?
For anyone interested, here's my set's behavior.
1) playing playstation, flicker, blue screen
2) ejected ps2 disc and reiserted, screen came back, shaking sort of.
3) switched to tv channels, no problem
4) noticed that net command IR repeaters to other devices were no longer working
5) end of day
Another day
1) PS2 again.  Flicker, blue screen.
2) switched to TV channels, no signal on any channel (menu works, on off works)
3) switched to dvd, no signal
4) power off, very long green light blink
5) green light blinking, pulled power cord
6) restored power, long green blink
7) went to bed
8) next day, no green light
9) power on, no signal on any device or channel, menu works, on/off works
10) reset
11) power on, same as (9), reset
12) power on, same as (9) except for some garbled tv channels
13) power off, pull power cord, wait 20 minutes
14) power on, same as (9) except got one tv channel fine, other channels garbled
15) reset
16) power on, solid green, red lamp, power off
17) power on, solid green, red lamp, power off
18) power on, same as (9)
19) still messing with it...
In other words... flaky!
Thanks again!
mbryant
Aloha Larry,
Aloha Larry,
I am having the flashing green timer light problem also. I have model MB-52525. Please send the information on how to fix this to [email protected] I also was wondering if this is a long term fix or will I need to do it again in six months to a year. This television was given to me so I was wondering if it is even worth fixing or should I take it straight to the garbage dump? Any help would be greatly appreciated.
Best Regards,
Matthew
On their way to you casey and
On their way to you casey and Matt, Good Luck!
Big Dufus
This appears to be an active
This appears to be an active thread on the WD-52525. I have a problem
I can't find anywhere. TV powers up, screen displays a narrow long
rectangular black and white (blue & white?) checkerboard pattern.
No menu or video function response. Any idea?
Thank you.
The formatter board is bad.
The formatter board is bad. Most likely you have several bad capacitors on it. ptscorp.com can rebuild the board for you. Go to their website and contact them by phone. The number is posted there. Good Luck
mbryant
Aloha Larry,
Aloha Larry,
Can you please send the repair instructions for the MB52525 again. I checked my inbox and junk folder and cannot find them. [email protected]
Best Regards,
Matthew
mbryant
Sorry Larry what I meant was
Sorry Larry what I meant was model number WD-52525.
Big Dufus
Hey Larry,
Hey Larry,
Thanks for pointing me in the right direction
on the bad formatter board. I'm pretty good with
component level repairs.
So I'll give it a shot.
Greg
Chris Hall
i seem to have the same
i seem to have the same problem as everyone else with the red blinking light with the WD-52525 model. could I get your help also please.Thanks in advance! [email protected]
shellbell
Larry, could you please send
Larry, could you please send me the WD-52525 repair info at [email protected]?
Symptoms FYI:
1) Powers up with the normal solid green light.
2) No display of any kind comes on the screen.
3) I can see through the grills on the rear left corner that the new lamp I just installed after this happened is burning brightly.
4) It then turns itsefl off after a minute or so and displays the solid red lamp light.
Thanks in advance!
Tim
Prideauxx
Mr. Dillon, Would you please
Mr. Dillon, Would you please send me the information on replacing capacitors on the electrical chassis for the Mitsubishi 52525 DLP set, as well as the hints on the targeted capacitors to check out, and the block diagrams on voltages to check? I've already replaced 8 today, become an expert on quick and careful disassemble/reassemble of the set, but still am troubleshooting the issue. Thank you for your time and patience. If I can get this thing to work (it's become a matter of principle at this point), I'll definitely send some green in your direction.
Justin.
UTNordic
Have contracted the blinking green light disease on my Mits 52725, would you pls forward instructions for repair.
Mark
DFWMike
Hi Larry, I'm about to
Hi Larry, I'm about to replace the lamp in my Mitsubishi WD-52525, but have also experienced the blinking green light anomaly in the past. Would you be so kind to email me any/all technical repair docs you have for the WD-52525? I want to know what I'm getting myself into if I still have problems after replacing the lamp, and like to take a shot at troubleshooting before asking for more help. I do not have the service manual, either, but am willing to buy one if needed.
Thanks much in advance! Just joined Techlore today after reading through much of this thread. Excellent forum. You are extremely helpful (and patient).
brianmonty
Hello Larry, you seem to have
Hello Larry, you seem to have the answers with Mitsubishi WD 52525 problems, I am hoping you can help with mine.
My Red "Lamp" is lit. No picture at all.
I replaced the lamp, plugged the tv back in, turned on the tv, green light came on, sound then came out of my external speakers but no picture (no light out of the vent on the left side either). Pushed reset button, red light went off and green light flashed for 30-45 seconds then green light turned off. I powered on the TV, green light went on and stayed on, sound from external speakers, no picture, after 30-45 seconds sound off, green light off, red light on. I then removed the light to make sure all was in ok, and repeated the process 2 or 3 more times trying to get the tv to work, no luck...
To help (or more likely complicate) things, I had a similar problem a year ago. I called out a service tech (who had no idea what he was doing, he was on the phone with Mitsubishi support the majority of the time). Long story, after about 4 service calls and 6 weeks he replaced the Optical Engine and the Lamp Ballast (Mitsubishi covered the parts, I paid for the labor).
my e-mail address is [email protected] if you would like to contact me.
thanks in advance for any help you can offer.
shellbell
Larry, I replaced all of the
Larry, I replaced all of the suspect caps identified in your documentation. The tv fired up and works great!!
Both of the 3300µf caps were swelled to the point of fracturing the scored ends and a few of the 1000µf caps were also slightly swelled.
As a side note, my tv exhibited the exact same symptoms as the post above from brianmonty.
Thanks for the help!! I'll be getting in contact with your paypal account later today.
Tim
MrGreg
I had the bulging capacitors
I had the bulging capacitors problem on my WD-52525, and it was out of warranty. I sent the following email (see below), and I got a call 15 minutes later from Mits! They offered to pay for half of the repairs, plus give me a 6 month warranty on the tv. I ended up doing the repair myself for dirt cheap and took the warranty. The good news is I'm expecting my bulb to burn out any time now, so the new warranty should cover it for free :-))
To: [email protected], [email protected], [email protected]
Mitsubishi,
My name is xxxxxx. I own a WD-52525 DLP Projection Televsion, which was purchased on 4/17/05.
I have been very happy with this TV until today, when it stopped working. At first the picture started flickering, and then it gradually got worse. The TV will not display anything correctly anymore, no matter what type of input is being used. I am a bit disappointed, but I know that even the best products can't have a 0% failure rate.
Before getting the TV fixed or replaced, I decided to do some research into what may have caused this failure. To my surprise, I came across a wealth of information and discovered that my problem is actually very common. Many people with this (or a similar model) TV are having the same failures, and they have become much more frequent as of late. It appears that the problem stems from bad capacitors, either on the power board, format board, dm board, etc. I doubt I need to go into details, as I'm sure you are aware of this problem.
Now my question becomes this: you know that many of your TV's contain bad capacitors which likely lead to failures. What are you doing to fix the problem? Many of these TV's are out of warranty, but they are still relatively new, so owners are spending a lot of money fixing this problem, sometimes more than once.
I wouldn't be upset if this was an isolated incident, a run a bad luck. I understand that can happen. But this is clearly a pattern that is affecting a decent percentage of your products. It appears that your quality system failed somewhere along the line.
I can relate to this. I work for a medical device company, and I spend some of my time in the top tier of technical support. When we see product failures, we try to identify them as an isolated incident or a trend. If we recognize a trend, we work hard to fix it and do whatever it takes to make the customer happy.
So right now I have a non-working WD-52525 television set that failed because of an unfortunately common problem. What will you do to help me?
I appreciate you taking the time to listen. I look forward to hearing back from you soon.
Regards,
xxxxxxxxx
Kevin13
My TV has also stopped working and has the green blinking light. It is a Mits 52625. Could you email me your directions for possible fix at [email protected]? My kids are going through TV withdrawls.
42willy
MY TV WHEN I PLUG IT IN G
MY TV WHEN I PLUG IT IN G LIGHT FLASHES FOR ABOUGHT 1 M THEN I PUSH POWER- NOUTHING PUSH RESET G LIGHT FLASHES CONTINUALY sorry didn't meen to yel forgive my spelling.
Larry, you are an electronics saint! I've read most of this board ... its nice to know there are helpful people out there. I'm having a similar problem with my WD-52525 (blinking light and what not). Could you please send me the repair info. Thanks in advance.
42willy email [email protected]
Mag305
Hi there I will like to get
Hi there I will like to get the repair manuel for the tv My E-mail is [email protected]
ChrisR1969
I have the frikin blinking
I have the frikin blinking light also.
Larry, Can you send me the info also?
ws- 55813
Thank you
DFWMike
GREAT WEBSITE FOUND for
GREAT WEBSITE FOUND for purchasing new WD52525 OEM replacement LAMP, complete with video demonstrating how to install, along with a helpful troubleshooting guide for common symptoms (blinking lights, noises, power on issues, etc.).
http://www.dlplampguide.com/915p020010.html
Robb S
Yet another blinking green
Yet another blinking green light... Larry, if you would be so kind as to send me the repair instructions I would greatly appreciate it. Mitsu Model# WD-52525
Please send to [email protected]
Thank you!
napmasterg
Hi Larry.
Hi Larry.
What you're doing is a great assistance to those of us holding a Mitsubishi screw up our butts. Good karma man. Thanks again.
Could you send me a copy of this repair manual - aka "Mitsubishi survival guide". I have a WD-52525 and it has weird yellow dots and lines on the screen and nothing else, but it does have audio. Occasionally I had the green blinking light syndrome as well.
What happened to this once great company? Did Samsung run them off the road? Their TV's now are so cheap. Did Sanyo buy them out or what?
mistahgook
Hi Larry I am experiencing
Hi Larry I am experiencing the exact same problem with my Mitsubishi WD-52525 DLP Rear Projection HDTV. The TV set will turn off and the green timer light will blink rapidly. I have been doing some research online and found the it may have to do with bad capacitors in the board. I found directions from WS models but I cannot follow it exactly. Can you please send me the directions to this particular set and how to replace whatever is wrong. Anything will help. Thank you. My email is [email protected]
powertrippin
hello larry.
hello larry.
 Excellent service that you are providing us Mits. owners here... we would be screwed w/o you.
Could you please email me the repair info on the WD series (DLP)? My mits WD-52825 started the blinking light o' death after a quick power flicker the other day (TV wasnt even on). My 3 samsungs and 1 pioneer elite plasma (all of which WERE on) all survived w/o a prob., but the mits (again, NOT ON) decided to commit suicide on me. yay mits.
if you could PLEASE send me the info to [email protected] i would forever be in your debt.
p.s. - got the P.S. and the D.M. boards out... the PS and DM fuses look/meter good, but the 4 caps in question are definately bulging. also, I was a bulging cap on the next board over, the analog video board, cap C2M29 had a distinct bulge, where the one next to it, C2M28, does not.
man... this is NOT going to be fun to re-assemble.
DebiVO
Hello,
Hello,
I have a Mit WD-62525 that is not working. I have replaces 6 caps so far, and now have the green
blinking light everyone is talking about.
I am interested in the repair instructions that are talked about in the discussion.
My email is [email protected] and would appreciate your sending them.
I have read that a lot of people of had this problem, has anyone actually fixed it???
hawkeyes
Hello,
Hello,
I have a Mitsubishi WD-62525 that has a problem with the picture. The error code I get is 21. It powers up, but the screen stays blue with random noise in the middle of the screen. Any help on troubleshooting this issue with repair manual also would be appreciated.
Thanks....
Lord Crystallion
Hi,
Hi,
My name is Steve I have a WD-52725 model. The T.V. will go into a blue screen then shut itself off with the green light blinking. I can turn the T.V. on again and about 10-20 minutes later in will do the same thing. I would also appreciate a repair manaul. Also if their are some detailed instructions on what to do would be nice. I had a stroke 2 years ago so I have a hard time sometimes doing stuff. I use to be good with electronics so whatever you can send I would be greatful. Thanks in advance, Steve
Here is my email: [email protected]
Dmitriyx
Hi, i have the timer led
Hi, i have the timer led blinking for some time and then stops, then after few minutes it will start blinking again after a relay click. may i get the repair manual or anything else other then owners guide.
Thanks everyone,
Gene65
Hello Larry,
Hello Larry,
Looks like this Mitsu problem is very deep. I also have a 62525 blinking light issue. Would greatly appreciate sending me the fix documents also. Have read multiple threads here on this and looks like you are the man. Thanks from all of us!!
