I recently moved my Mitsubsishi TV (model WS-B55) from my back room to my front room...over some tile and bumpy grout lines. I was careful and went slow. What I discovered though is when I plugged it back in I now get the "Blinking green light". Did I jar something loose? The TV is five years old and the convergence chip was replaced about a year ago.
Hoffdad said: Larry, My WD-65732 has come down with the green light of death as well. Luckily it was the day after my superbowl party! Could you please send me the info I need to fix this issue? My email address is [email protected]. Thanks so much!
Hi Larry, just checking back to see if you could help me out by sending the info on fixing my WD-65732. Thanks again!
I am sorry my friend, I am not familiar with that model number. Perhaps if you go to servicemanuals.net, download the manual, send me a copy, maybe I can assist you. Good Luck
Sub, That model is the same as a WS55511, andhas 7 bad capacitors inside of the DM. An easy repair, but to where would you like me to send it to? E-Mail? LOL
I am yet another victim of the green flashing light on my mitsubishi tv. The model number is the ws-65511. If you could send me the service manual i would appreciate it greatly. My E-mail address is [email protected]. Thanks so much!
Larry Dillon said: I am sorry my friend, I am not familiar with that model number. Perhaps if you go to servicemanuals.net, download the manual, send me a copy, maybe I can assist you. Good Luck
Larry, what email address would you like me to send my WD-65732 service manual to so you can check it out? Thanks.
I also have a Mitusbishi 55" (WS55511 - purchased in 2002) with the Blinking light problem. Have been reading lots about this on several blogs. I thought I might be able to fix it myself so I went ahaed and took the TV apart. My probelm now is that I don't see the DM power board. In looking for the board I did find what looks to be a blown cap on the DBF Board and am considering replacing it just fo **its and giggles. Could someone point me in the right direction? Any help on this would be greatly appreciated.
I have a VS-50111 Mitsubishi Projection tv and looks like it might have the sickness that so many others have encountered. I have located the DM but all the caps are surface mount. I just got this tv for free and I am a some what of a tinkerer and am going to try to fix. The person that had tv before attempted to try to fix but did more damage than good. All the leads for the flyback were ripped out and the tips were busted off. Dug one out of the tranformer and fabbed my own out of ends of a glass fuse. Do these anode leads need to contact at bottom of transformer? All three springs are still in there and the fuse ends contact spring and im not sure if they need to touch all the way down to bottom? The wires are still same length just might have to put a bead of solder on end to become more of a point. If you could maybe get me goin in the right direction with DM and the flyback leads I would appreciate it greatly. You guys are providing a great service keep it up. Done alot of soldering before just not surface mount dont want to "F" it up Thanks
the capacitors you need to change in the DM board are not surface mounted my friend. They are regular capacitors and there should be 4 of them all in a group. Maybe they are missing?
You're the man Larry. I had the Mitsubishi WS-B55 with the blinking light problem. Replaced the 7 capacitors with the ones from Mouser.com and the TV working fine now.
Thank you for the great instructions and pictures. Only thing we had to do differently from the instruction was disconnect the wireings that came out of the DM module from the TV. The module pulled right out after that. We tried taking out the wood shelving above the module (but with our model we couldn't do it.) Just becareful not to bend the connector pins on the tv if you have to disconnect them. We had a problem with one the connector and it took a little while to put it back.
Larry, Ok well I have a PCB-Doubler (2HDW). Thats what the service manual I downloaded calls it. that was taken out of PCB-Signal.The Doubler was located in the middle with a heat shield and everything on this board is surface mount. There is however two missig caps that I found after you had said something bout missing caps. Though there is no through mount at all maybe I am lookin at wrong board. It is loaded with IC's and one big one labled DPM4. Is this right board? But is onlu board plugged into tray besides terminal board. You defenitely seem like an expert any Help would be greatly appreciated. I am going to replace two caps that are surface mount and see what happens. They are located in upper right of board side A. The manuals I downloaded dont have any listing for the cap #'s on board they are C7H43 and C7H51. I can e-mail you the manuals if you would like to take a look. My email is [email protected]
Looks like the previous owner of this tv already had someone work on it then they found out how much it was going to cost and told them not to do it. Is there any sure fire way of testing caps other than just taking them off?
Tom and JM, I do always send out the request as asked. I do not ever play favorites. Please check your junk mail or bulk mail or better yet TELL ME WHAT you need again and I will send it to you. Maybe your mail cannot accept larger files as these happen to be large files. Believe ou me I do send them but there are a few that do not get them due to the firewalls or whatever. I DO RESPOND to everone here! If there was a mistake on the e-mail addresses, I will tell you most of the time. Please tell me again exactly what you need, for what model number of TV set.
The model number is ws-65511. Email address is [email protected]. I am going to attemp to repair the blinking light problem so I think I just need the service manual.
Hi Larry, I checked my mail box and I still have not received the instruction yet. Please send to a different account: [email protected] Thank you so much. Tom
gowell, what model number is the TV set? LOL
Hello Larry,
Sub!
Yes please!
Sub
Oh [email protected]
Sub
SUB!!! What is the e-mail you wish to recweive the documents?? Geez.
Could I get a copy of the docs for a ws55513.
Thank you,
Hello Larry,
Hi Larry/Gary,
I had the same problem with my Mitshbishi HDTV WS55511 (year 2003).
Please send me the manual/instruction on how to check the problem, where to order the parts and fix it.
My email is [email protected].
Many thanks.
Tom,
Tom and chaseguy, I will send those out to you very shortly. Good Luck with the repair
jeff, I will certainly send out that information to you shortly. Good Luck
Joe
Joe, I do not think there is a DM in this model. You can send the manual to
Use whats called an ESR meter and this test the capacitors on the board and in-circuit.
I have not recieved the manual yet. Just want to make sure you had the right email. It is [email protected]. Thank you very much.
Hi Larry, I have not received the instruction yet. Please send to [email protected].
Thank you so much.
Tom
Hi larry,
Thanks so much.
chaseguy, I have mailed out the manual and repair docs. for you. Good Luck
Hi Larry, the model is: WS-55511
Tom
got it. Thank you so much!
