783 posts / 0 new
dr919
dr919's picture
Hey guys,
Hey guys,
I finally found a weekend to do the capacitor replacement project and it worked like a charm! Thank you! Thank you!
that guy
that guy's picture
hey expert guy larry, i have
hey expert guy larry, i have an older HDTV its a mitsubishi model number WT-46809, and im having similar problems with the tv as the others describe, the blinking green light for three seconds then a click noise as it powers down followed by static noises in back, but the screen does not show any form of display. also when its turned on again right after it turns off the light doesnt blink it stays on for three seconds and shuts off again with the static. Ive checked as the fuse i could see and its good...help me... e-mail any instructions i will need for a self-repair [[email protected]] thanks
jatarro
jatarro's picture
My friend gave me his ws
My friend gave me his ws-65511 because he could not get it to work...so I figured there is no harm in pulling it apart and trying to fix it myself (bglod). The light blinks and the tv does not turn on - no error codes are given, just a constant blink. I am going to change the caps and perhaps the Convergence IC, but I live in a town with no electronic stores so everything has to be ordered. Other than those parts that cause the issues with the tv is there anything else? I want to try to make one order as most parts a pretty cheap. Thanks!
MitsWS65411
MitsWS65411's picture
You might want to look at one
You might want to look at one of the last posts in this forum regarding the blinking light.
http://www.hdtvoice.com/voice/showthread.php?t=20219&page=10&pp=20
Good Luck
Chris Smith
Chris Smith's picture
Ok you know the story I have
Ok you know the story I have the Mitsubishi 55589 with the same death ray blinking light could you please sent me the repair instructions?
Thanks so much
Chris
AndyHatesMitsubishi
AndyHatesMitsubishi's picture
Larry or anyone who can help,
I've got a Mits WS-55711 that turns on for about a second before powering itself back down. The green led light comes on during that second, but the screen is completely black. I've got a service manual and tried looking for the error code, but the TV doesn't provide any info when the menu and enter buttons are pressed together and held for 5 seconds. I've read similar problems here at this forum and could use some help. Is the TV ready to go to the dumpster or is this fix as simple as replacing a couple of fuses and the convergence IC? This TV used to have the blinking light of death, but I fixed that a few months ago. Please email me at [email protected] with any info. Much appreciated.
Eric23
Eric23's picture
Hi Larry or anyone with a
Hi Larry or anyone with a helpful idea,
I have a Mitsubishi WD-52725 with a continuous blinking green timer light. I have pressed the reset button and the light continues to blink. I have unplugged the TV for 24 hours plugged it back in and the light still blinks.  I can't turn the TV on.
I have had my TV for 3+ years. Could I get a copy of the repair instruction and/or the service manual.  My email is [email protected].  Any input on how to fix this would be greatly appreciated!
Thanks!!
Eric
C2
C2's picture
I have a WS-55613 and I have
I have a WS-55613 and I have the same blinking green libht problem. Iv'e read everthing everyone wrote to you and would like to recieve information on how to fix my problem.
green guy
green guy's picture
hello Larry,
hello Larry,
could i get a copy of the repair guild thanx
devo--
devo--'s picture
If your still in the business of aiding those of us who have been stricken with
techchallenged
techchallenged's picture
Can someone send me the
Can someone send me the directions and manuals to the problem aerosvc was having please
techchallenged
I have the same problem aeosvc had, I have a ws-55513 can i get the manual and directions please
jatarro
jatarro's picture
A quick update. I ordered and
A quick update. I ordered and replaced the 7 caps on the board of my ws-65511...buttoned up the tv and plugged it in. The light flashed for 30 secs continually and then stopped - so I pressed the power button. The green light came on for about a second and it sounds like the TV turned on as well , but then everything turned off. I get the 2 - 2 error code indicating a short. What should I do next?
orrboy
orrboy's picture
I just bought a mitsubishi wd
I just bought a mitsubishi wd 52525 and i've read all the horror stories now about the set. I had a little trouble with the flashing green light initially but it seems fine for now. I blame that on the below zero wind chills we have tonight when i hauled it home. I have also read about the screen flickering and waving a bit on these sets and notice it a bit on this one. I only gave $500 for it so i can afford to put some cash into it if need be, but if possible i would like to do the work mostly on my own. Any advice!!! thanks
Boss Hoss Don
Boss Hoss Don's picture
Thank you for the great
Thank you for the great foroum and advice, again thank you. What I do not understand is why the answer to the questions do not seem to be answered in the same forum. Where do we as outside the topic get the answer to the question that was asked? Thanks for helping me understand what I do not Know !!!
My motto , There are no stupid questions only stupid answers ! So please don't regard as ignorant' I just need assistants . Thanks again D. G.
DANAE
DANAE's picture
I also have a ws-55711 with a
I also have a ws-55711 with a blinking green light. Can anyone email me the instructions on this fix. [email protected]
Thanks so much.
BOB
ForrestG
ForrestG's picture
I have a Mitsubishi model #
I have a Mitsubishi model # WS-55511 that developed the blinking green light problem following a power outage. I've tried disconnecting power for awhile but that did not work. Can someone please email me instructions on the capacitor replacement at [email protected]
Thank you.
Forrest
Myer1263
Myer1263's picture
I have a ws 55511 with the constant blinking green light after and the TV will not turn on at all tried the reset button with no effect or code tried pressing the av and menu button at the same time to get a code but it did not work. Please email me at [email protected] with any pics and info you might have it would be greatly appreciated.
Can you send me repair info please...Thanks for your help
tbrightjr
tbrightjr's picture
I have just joined the blinking light crowd for my WS 65615. Could you email me the instructions on the replacement. [email protected]
Rich Dean
Rich Dean's picture
Hi Larry and All..
Hi Larry and All..
Add one more to the blinking LED club. My WS 55511 started doing this the day before yesterday. Larry, could you please email me the spec sheets as you have done for others? [email protected] After following all these comments, it seems like it would be good if you could put those documents somewhere on the net and save a great deal of emails.
Many Thanks...
Rich
MarcC
MarcC's picture
I hope you're still around since the last post. Would you please send me the instruction as well at [email protected] to repair the blinking green light issue? Many thanks!!
Marc
Donna
Donna's picture
Larry, could you send me the
Larry, could you send me the repair instructions for the blinking green light ?
thebaum
thebaum's picture
Hey Larry,
Hey Larry,
I have the ws-55511 and I replaced the 7 capacitors on the DM Board and no luck. Is there something else I should do? I see that you can email the repair instructions, that would be awesome. my email is [email protected]
Thanks a ton
Zack
thebaum
thebaum's picture
oh and i meant to say that I
oh and i meant to say that I had the blinking green light and tried all the simpler options, Thanks!
Ken'n'oregone
Ken'n'oregone's picture
Hello,
Hello,
I have the same blinking light issue and the tv won't turn on. will you please email the instructions to: [email protected].
thx
Ken'n'oregone
will someone please send me
will someone please send me the documentation for replacing the caps in a WS55511 to: [email protected]? I just got nailed by the same issue i'm reading about. thanks, Ken
Zack'N'Texas
Zack'N'Texas's picture
I have a ws-55711 that just started the green blinking this morning. If you could please mail the repair instruction to [email protected] I would be very thanks full.
Have a great day.
Bill47
Bill47's picture
I have the blinking green
I have the blinking green light problem with my WS55511 after moving it to another outlet. Can someone please forward fixiing instructions to my email at
[email protected].
many thanks
ryan mcguire
ryan mcguire's picture
i also am having the same
i also am having the same problem with my 55511 mitsubishi hdtv, i would appreciate the info on how to fix the capacitors, my email is [email protected], or if some else who has already gotten theres working could email me the instuctions thank u so much
Eric B.
Eric B.'s picture
My Mitsubishi TV went out
My Mitsubishi TV went out yesterday. My kids and I were watching a batman cartoon when the picture started to look like we needed to be wearing 3d glasses. I power the set off and back on and it would have normal picture for a while but returned to red blue blurry lines on the screen. Eventually the tv powered off on its own. When I power it back up it will not come on and turns off after a few seconds. Used the reset button and the power light would blink but the tv never came to a picture. Right now if you power the tv on the green power light comes on and then turns off after a few seconds.
Is this the capacitor problem? If so can you send me PDF for fixing? I am at work but I think I have one of the WS 1080i 65 inch rear projection models.
