783 posts / 0 new
MikeeeD77
MikeeeD77's picture
I have a WS-65869 with the
I have a WS-65869 with the dreaded green blinking light after a power outage in my area. Could I get a copy of the repair instructions? [email protected]
Thanks, Mike
jenjen55944
jenjen55944's picture
Dear Larry,
Dear Larry,
I see you are pretty good at fixing this problem with the green light turning on the turning right back off with no power to tv. i have a Mitsubishi WS-55711. could you please send me which capacitors on the DM board i need to replace? my e-mail is [email protected] Thank you!!
Jennifer
HAPPY
HAPPY's picture
I have a Mitsubishi WD-62725 set that is now suffering from the constant green blinking timer light. Please send any repair instructions that you might have to btallent at duke-energy dot com.
polomom
polomom's picture
mitsubishi tv 65869 with the
mitsubishi tv 65869 with the blinking green light prob....please send repair [email protected]
thanks!!!
backwardb
backwardb's picture
Xclipse,
Xclipse,
Check out tvrepairkits.com's hours. You can do the live chat and Ed can probably come up with a kit for you. It was almost too easy and took less than 5 minutes. He sent me a link to look at that had a kit with 7 caps and 2 fuses. I have WD-52525 and already had the TV tore apart and knew I wanted to change out all the 1000uf 16V caps. 4 on power board, 4 on dm board and 4 on another board. He sent me kit with 12 caps and 2 fuses. Turned out all my fuses were OK, but I wish I had seen a swollen 100uf cap on term board 2 when I was ordering.
bobbafett
bobbafett's picture
I just bought a 65869, which was working when I looked at it in the seller's house. When I got it home, I got the dreaded green blinking light. When I hit the power button I get no response, no video, no audio, nothing. I'm guessing something came loose or broke during the mov
Do you have any ideas about what might have bumped out of place inside the TV?
Anyway, thanks for the service you do for everyone here!
Happy new year!
Take care
Ecl
Ecl's picture
I have a Mitsubishi Wd-57831
I have a Mitsubishi Wd-57831 manufactured in 2006, friend told me that needs the lamp,
but friend said he hear a pop sound and the dlp not working any more, I plugged it but hear sound from the fan? or color wheel? blinking green light ( timer) then power goes out red light comes on indicating lamp issue?
please help! did someone has the services manual? or where can I get it for free.
can you please email it, at [email protected]
Thank you,
EL
Terio
Terio's picture
Hello Everyone,
Hello Everyone,
Can someone help me? I have a WS-65611 and I need a service manuel for it. I have a blinking green light and the reset button and unpluging it does not fix the problem. If any one can help I would really apricate it. My e-mail is [email protected]. Or if you have any suggestions.
Thanks Teri
DaveM
DaveM's picture
hay i got the blinking light
hay i got the blinking light to. would like the fix myself
DaveM
DaveM's picture
sorry mitsubishi hdtv1080
sorry mitsubishi hdtv1080 diamond 65" modle ws-65909 green blinking light will not power up
Larry Dillon's picture
Replace the seven capacitors
Replace the seven capacitors in the DM assembly board. Larry D.
The best advice I can tell you is to go to tvrepairkits.com and order the blinking light kit for your model of set, the kit comes with the high temperature/ high frequency/long life 105 Celsius type capacitors (not those cheap Radio Shack caps) full easy to follow pictorial directions, AND free live on-Line tech assistance in case you run into a problem, all kits are shipped out within 24 hours in most cases, 2 to 3 day Priority mail. GOOD LUCK!!!
DaveM
DaveM's picture
larry it looks like the last
larry it looks like the last repair that was done the high temp cap were installed. or does the tv come with them. and are they know to go out as well? the blinking light kit comes with a couple of fuses. would that be the problem?
yes they do go out, that is
yes they do go out, that is why the kit comes with them you need to test the fuses for continuity with an ohm meter.
Yes check the fuses as well
Yes check the fuses as well as the dm power supply
backwardb
backwardb's picture
I used tvrepairkits.com to
I used tvrepairkits.com to get my WD-52525 going again. Listen to Larry.
featherhead
featherhead's picture
I have a ws55711 that tends to shut it self off often. no blinking green light of death. somtimes it will work for 30 min other times click on then right off again. when the codes are checked i get "23". will the convergence kit help or do I have other problems? email is [email protected]
Thankyou for the help :)
jlnovak
jlnovak's picture
I have the same continuous green blinking light problem. Can you send me the instructions to fix this. I read above that it is a matter of replacing some capacitors. If that is correct I appreciate your help.
emai: [email protected]
llmelton
llmelton's picture
Larry: I have the Green
Larry: I have the Green Blinking Light of Death on my Mitsubishi HDTV 1080. Need help. Very frustrated. From a fellow Larry. Can you help.
HD 1080 is not the model
HD 1080 is not the model number maybe I can help you but I am not a fortune teller??
kelly
kelly's picture
I have a WS-55511. When I try to power it up, the green light comes on for a few seconds, and then the set shuts down. I tried unplugging it for a while, and tried the reset, but no luck. I get the normal flashing green light when I plug it back in. Diagnostics test turned up error code 12 - no error detected. I am willing to take on the repair myself if you could send me your advice and the appropriate documentation.
The best advice I can tell you at this point is to go to TV repair kits.com and order the complete convergence kit for your model of TV set, click on here please: http://www.tvrepairkits.com/xcart/home.php?partner=larry
no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK ICÂ’S , not those cheap aftermarket or china made ICÂ’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases,
kelly
kelly's picture
Just curious...after reading
Just curious...after reading the other posts I was expecting that you would send me the instructions for the capacitor replacement. Why do you think my set needs the convergence kit? Would I be getting a different error code if it were a capacitor problem? Thanks again for your help.
because if your set needed
because if your set needed the caps it would not even attempt to come on and the green light would continuously blink.
Larry
kelly
kelly's picture
I have not pulled the trigger on the convergence kit yet, but I am close. One new piece of information: I stated earlier that I get Error Code 12, but that is only after first plugging the set in. After I try to power it up and it shuts itself down, then I get Error Code 22. Is that behavior consistent with the convergence problem? Thanks again!
yes it is as long as you are
yes it is as long as you are posting under the right model number and this set IS NOT THE DLP TYPE SET!!!! Good luck
Larry
jim Mejia
jim Mejia's picture
I have a mitsubishi TV
I have a mitsubishi TV wd52525. Green light still blinking after replacing 2 bad cap at the power board with a higher voltages. Also replaced 3 bad cap at DM board with a higher voltage ratings. Checked if there is any pico fuses that are blown. None. Still geen light blinks. Also I don't know where to reconnect the fans. I need help please.
NickR
NickR's picture
I have a WS-55111 that a friend had given me because the green convergence was not working properly. The screen looked like it was melting. I was just about to replace it when I turned on the set and it seemed to work properly, for a minute, then it shut itself off. I went ahead and replaced the Sanyo made IC because I knew it was bad hoping that also the tv would come back to life. Alas it didnt.
Now when I turn it on the green light comes on for about 3 seconds and then goes off with an audible click.
I did look at the capacitors the the DM ( large Silver box the the left of the A/V connections) they do not look swollen like what some users have reported.
Is the blinking light kit listed here http://www.tvrepairkits.com/xcart/home.php?cat=2664 what I need?
Please help shed some light on what I have to do to fix this issue.
Thanks in advance
did you o0rder a complete
did you o0rder a complete convergence kit with the heat sink compound or did you just order the stk ic's from a different source?? this is a very important step? if you did not you most likely replaced the chips with non original chips but if the answer is that you just replaced the chips with the most inexpensive cxhips you could find, You need to use original replacement chips and these ill cost a lot more than the knockoff type chips but if you wish to get a complete kit to repair this problem properly??? go toThe best advice I can tell you at this point is to go to TV repair kits.com and order the complete convergence kit for your model of TV set, click on here please: http://www.tvrepairkits.com/xcart/home.php?partner=larry
NickR
NickR's picture
Larry Dillon said:
no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases,
I got an original Sanyo IC from eletronicrepairkits (dot) com and already replaced it.
ok now answer the rest I ask
ok now answer the rest I ask but a kit will be the best thing you can do now
