783 posts / 0 new
Gussell
Gussell's picture
I am having the same problems
I am having the same problems with my WS55511. I hit the reset button and the green lights blink, then nothing comes on the TV. Can someone please send me the info and repair instructions I would greatly appreciate it.
bje230
bje230's picture
I have a Mits WS-55511 that
I have a Mits WS-55511 that has the same problem described here... green flashing light at plug in.... won't turn on.. clciks then shuts off after about 3-5 seconds. Could anyone please send me the derictions and parts list to affect this repair. Thanks, Jeff.
Larry Dillon's picture
The best advice I can tell
Larry D
chop
chop's picture
Came home from vacation and
Came home from vacation and ws55511 has blinking green light syndrome. seems a lot of the same on the forums. is there a common failure? Are there diagnostic charts or ? any help would be great. Thanks
chop
chop's picture
Larry Dillon said: I need an
Larry Dillon said: I need an e-mail address please LD
atsat2
atsat2's picture
Hello Lary,
Hello Lary,
I have Mits WD52525, DLP. I replace caps but green light it still bliking.
I follow other folk remove the power line go to FMT. the green light stop.
I replace 4 caps 1000UF, 35V 20% for FMT again. it still bliking. would you send me a suggestion how to fix this problem Thank you very much
GLIDDER33
GLIDDER33's picture
My Mitsubishi WS-B55 is
My Mitsubishi WS-B55 is having a similar problem. Green light comes on for 3-5 seconds and the set turns off. Any solutions?
send your e-mail address if
send your e-mail address if you want info please.
Bigguy9988
Bigguy9988's picture
Hello Larry
Hello Larry
I feel bad asking Larry but I have a WS-55511 with the dreaded blinking green light and I really need the service manual and any pictures that might help fix the problem. From what I have read, you are the Guru that has the answers to the problem. I have a 6 year old God Son who loves to play the Wii with with me and we are shut down right now. So if you could help me I will be forever grateful and my God Son said he will say a prayer for you.
P.S.--I do have the technical proficiency to do the repairs, I just need the correct info to get it done.
Raymond
I would love to help you ou
I would love to help you ou and your-God Son out but someone FORGOT TO SEND an e-mail address-as I DO not know where to send it to????
Bigguy9988
I'm so sorry, it has been a
I'm so sorry, it has been a crazy week, Christian starts the first grade Monday and I have been helping his dad get things ready.
My email is [email protected]
Thank you for your help Larry
Raymond
motorman
motorman's picture
I have ws-55511 green
I have ws-55511 green blinking light after power outage. (brown down)
have service manual but no specs on caps. I'd like to try the cap swap,
any help would be appeciated. thanks.
The best advice I can tell you is to go to tvrepairkits.com and order the blinking light kit for your model of set, the kit comes with the high temperature/ high frequency/long life 105 Celsius type capacitors (not those cheap Radio Shack caps) full easy to follow pictorial directions, AND free live on-Line tech assistance in case you run into a problem, all kits are shipped out within 24 hours in most cases, 2 to 3 day Priority mail. GOOD LUCK!!!
phillip
phillip's picture
I have a misubishi WS-55515 rear projection tv with the blinking light and a code 22.Went to the site tvrepair.com their kits fix a bunch of sets execpt model numbers ending in 5 whats different can you help? Do you have repair information on this model, If so could you send it to me please and thanks!
Email [email protected]
Rockinusa
Rockinusa's picture
Hello Larry,
Hello Larry,
It seems I also am a victim of the green blinking light. I have a Mitsubishi Electric DLP WD-62627 that has the green timer light blinking when it is plugged in. Pressing the power switch, a reset, or any other attempt to turn on the TV results in nothing bu the green light continuing to flash..
Could you Please send me any repair info for this TV that might help?
Please email me at "jrauk at hawaii dot rr dot com" with any Info, Docs, Pics, or Links that might help with this Misubishi WD-62627 (Feb2006 build).
Any help will be greatly appreciated. Thanks Much, John
John, "[email protected]
John, "[email protected] does not work man!!!!!!! wasting my time???
Rockinusa
Rockinusa's picture
Larry Dillon said:
Humm, that's wierd...that is my main email...I wonder how many other emails I've missed?
Anyway here is my alternate:
atsat2
atsat2's picture
Hello Lary,
Hello Lary,
I have Mits wd52525. I just fixed the green light issue by replacing caps. Now, after 70 second, green light went off then I turn power on its run for about 10 second then it shut down and the SOLID RED "STATUS" light come up. Would you tell me what is problem ? and would you give me instruction how to fix this red light problem. Thank you very much for your help. My email address is: [email protected]. (Note: I can see the the lamp is light up in that 10 second before it shut down)
miley22
miley22's picture
Hi Larry, This seems to be a
Hi Larry, This seems to be a pretty popular request. I have aMitsubishi WD-62627 with the green timer light flashing and then nothing. I was trying to switch to one of my other devices and the tv kept going to a blue screen then would shut off with green lights flashing. It did this a while back but always came on eventually, not this time. Any help on the fix for this problem would be greatly appreciated. Thanks! [email protected]
chop
chop's picture
got the [tv-kit-2063] and my
got the [tv-kit-2063] and my ws55511 does not look like the info pictures sent? this is a HI-def set and I dont see any visually damaged caps and the DM is not there where pictured? Do you have any instructions with closer likeness to my set. Imsorry I just dont see the problem or the DM board. thanks Rick
chop
chop's picture
Found the dm remote mounted
Found the dm remote mounted next to main components and replaced all 7 caps. Found 1 for sure bad- reading 1m ohms.
nice clean install but green led stops flashing after a minute and then nothing, will not power on? power switch connector pin terminal 3,4 I have 5 volts Keyboard is not locked - what is the E2p PCB #934C121001 ? or is there something I missed in tests, is there anything else I can test or check? thanks for any directions/diagnostics/help
TV Problem Tina
TV Problem Tina's picture
We have a Mitsubishi Model WD
We have a Mitsubishi Model WD-52525 and the blinking green light is flashing and the tv will not turn on. Had a tv repair man out here and he said it would cost $550 to fix to install the FMT/DM Kit. This seems outrageous, do you have a cheaper solution?
Tina
VLR
VLR's picture
Have same issue with flashing
Have same issue with flashing green lite on WS6551 HD. After power outage TV will not come back on. This happened once before but was able to push reset button to restore but not this time. Would you please email the instructions on how to repair the DM board. Thanks.
JohnMc
JohnMc's picture
I've got the same problem on
I've got the same problem on my WS-55711. It's crazy, was replacing the set and moved it down stairs nad I have the same problem. I guess I simulated a power outage by tuning it off and unpluggin it.
I would greatly appreciate the details to fix this myself.
VLR
VLR's picture
Need help with same issue
Need help with same issue "Blinking green light" on my Mitsubishi Model WS-65511 HD TV. Will not reset after a power outage. Larry if you would please forward to me any information you have on this issue I would greatly appreciate it. My Email address is [email protected] Thanks!
Mitsdlpwd52525
Mitsdlpwd52525's picture
Having same issue with
Having same issue with blinking green timer light on my Mitsubishi WD-52525. After having a power outage. Followed owner's guide instructions and troubleshooting to no avail. Purchased TV in Nov. 2004, rarely used. On last service (Sears yearly maintenance plan), repairman said lamp was in great condition - no need to change out yet.
Larry Dillon seems to be the GURU of fixing the "Green Light" issue! Other members have also gone or going through this - Anyone, please send me information on repairing..
I love this TV, even though it's not used much (wasn't cheap), it's definitely like a piece of furniture.
I appreciate any information you can provide.
Thank you - [email protected]
Mitsdlpwd52525
Have u had any luck in fixing
Have u had any luck in fixing your TV yet? Having same issues...
Tina
Danellis
Danellis's picture
I think I have the
I think I have the Convergence IC Problem. The green light comes on for 3 seconds and shuts off.I have the Mits Training Manual, what section tells me about this.
Danellis
Danellis's picture
I forgot to let you know that
I forgot to let you know that I have a WS-55613 and was hoping this problem were the light comes on for 3 sec and goes off is the same problem?
iluvsterling
iluvsterling's picture
Where can I find a schematic
Where can I find a schematic for the ws-55511 hdtv? I have a couple of solutions posted to http://www.fixya.com/ThreadAsker.aspx?thid=2629878 . We need the repair manual to proceed.
thanks for your assistance
Jody
email:[email protected]
