783 posts / 0 new
Richard Donnell
Richard Donnell's picture
hello
hello
Please Help !!
I have mitsubishi model ws 5589 and have the same problem with the blinking green light and does not power on.. i have left it unplug for several days plug it in and reset as well with no luck.. can you please send me manual to replace capacitors, it would be greatly appreciated...
thanks
my email is [email protected]
Richard Donnell
Please Help !!
Please Help !!
I have mitsubishi model ws 55859 and have the same problem with the blinking green light and does not power on.. i have left it unplug for several days plug it in and reset as well with no luck.. can you please send me manual to replace capacitors, it would be greatly appreciated...
*************sorry i got the model number wrong on previous post*************
thanks
Wildrat
Wildrat's picture
I was reading your info. How is your radiation treatments going? I hope you are doing OK. I am new to the forum I have a Mitsubishi WD-73733 with the regular issue with blinking lights etc. I have the Service Manual for the set. I have parts of the TV sitting in front of me. The bulb has been replaced. The flow chart that I followed in the manual says the ballast is bad, but having been an aircraft electrician working with flow charts, I found them to be somewhat lacking to say the least and usually ended up troubleshooting in the end. I see having been reading this post that you are emailing info to people. If possible could you send me this info also. My email add is ( [email protected] ).
Thank You!
Wildrat
Mark
GuardianZX9
GuardianZX9's picture
Not a dead forum, just slow,
Not a dead forum, just slow, be patient someone will get back to you.
I did get the info i needed here, and was able to fix my WS65611, turns out the
SMT fuse blew first in a big way, it actually melted the trace off the board.
I ended up replacing it with a mini atc glass fuse 4A 125V fast blow, that along with the bank of caps on the DM power supply board fixed my issue, I am back up and fully running.
Thanks to everyone here that assisted!
G
Wildrat
Wildrat's picture
Yep, I know about slow. I am
Yep, I know about slow. I am putting the tv back together. I found a ballast board, so I will try that. If the charts are wrong, the tv is easy enough to get back apart. I have already checked all the board fuses, they were all OK. I did have a couple of caps that I checked that were acting odd, but I will replace them if the ballast board does not take care of the problem.
ITEngineering
ITEngineering's picture
Hello - Many of the
Hello - Many of the Mitsubishi manuals are available in other forums online.
I found the Mits Manual for the "WD" DLP series (MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927)at http://fileshare.eshop.bg/equipment_mfg/MITSUBISHI_2.html
There is other Mits documentation/service info there that may be helpful to other people.
The disassembly procedure for the WD-73927 to inspect the DM board is somewhat different than what is posted for the other "WS" models listed in this forum.
If you have any of the WD models listed , it is highly worthwhile to review the service manual disassembly instructions before attempting to inspect for any faulty capacitors.
--Chris
William H
William H's picture
Issue: Flashing Green Power
Issue: Flashing Green Power/Timer light
TV info: HD1080 Mitsubishi Diamond WS-55711
email: [email protected]
Please send the info :)
xplantdad
xplantdad's picture
I just wanted to check back
I just wanted to check back in a let everyone know that even though my capacitors looked normal...I used the ones suggested by Larry via his .pdf file and my TV is now working again!
Thanks so much Larry...for taking the time to let everyone know what to do for the deadly blinking light syndrome.
The total cost for me to repair my set was:
Solder removal tool-$10.60 plus tax at Radio Shack
Flux-$5.99 at Radio Shack
Capacitors I bought 14...double what I needed...in case this ever happens again!-$5.46
Shipping for the capacitors -$6.00 (LOL)
I already had a soldering iron
So the total cost was $28.05!!!
I have to stress that you NEED to get the solder removal tool. It took me less than 2 minutes to remove all seven capacitors. In two more minutes the new ones were soldered in!
Thanks again Larry. If you PM me your address I will send you something for making this available to everyone!
To everyone else who has this problem...good luck!
Bruce
GuardianZX9
Finally got all my parts to
Finally got all my parts to do the CAP swap on the DM power supply board, no go after the swap, the 4A 125V surface mount fuse is blown with a considerable heat trace left behind, also, I am not sure if it was blown before I changed the caps or not.
I am going to try to find a replacement, I may just try a non SMT fast blow glass fuse and see if that pops quickly.
Any Ideas Welcome :)
G
dr919
dr919's picture
I am having a similar problem
I am having a similar problem with my WS-55711 and would like to get the instructions for checking the capacitors on the DM board. my email is [email protected].
. Many thanks. Jon
xplantdad
xplantdad's picture
I just sent it to your email
I just sent it to your email address...
Good luck!
Bruce
Larry Dillon's picture
the caps do have a positive
the caps do have a positive and a negative side on them and they do have to be installed with the proper polarity the fuses will probably look burnt if the caps are installed incorrectly
xplantdad
xplantdad's picture
And like Larry said in his
And like Larry said in his wonderful instruction sheet...The caps polarity is marked. There is a series of minus signs (-) down the negative side...and the positive side has a longer 'lead' on it!
Bruce
jjsheedy
jjsheedy's picture
I have a similar blinking
I have a similar blinking green light issue on model WS 65713. Please send me the instructions to change the capacitors. Thank [email protected]
Richard Donnell
hello
hello
Please Help !!
thanks
Richard Donnell
Please Help !!
Please Help !!
thanks
Wildrat
Wildrat's picture
Thank You!
Wildrat
Mark
GuardianZX9
G
Wildrat
Wildrat's picture
Wildrat
Wildrat's picture
Well I fixed my TV in time to
Well I fixed my TV in time to eat wings and watch the loser bowl.
Kev W
Kev W's picture
Larry I have the same problem
Larry I have the same problem with the green light of death. I have the ws 55859. Could you send me the instructions to fix? Thanks in advance. K
kent
kent's picture
i have a ws 55511 with the
i have a ws 55511 with the constant blinking green light after a power surge. tv wont turn on at all tried the reset button with no effect or code tried pressing the av and menu button at the same time to get a code but didnt work please email me at [email protected] with any pics and info you might have it would be greatly appreciated.
kent
kent's picture
shawn007
shawn007's picture
Hey larry I have the same
Hey larry I have the same problem.When powering on green light comes on for 2 sec with a click, the shuts off with another click.I have a Mitsubishi WT-A42.
Can you send me repair info please.My email is [email protected]
Thank You
coralx12
coralx12's picture
I have WD62525 DLP set. It
I have WD62525 DLP set. It started blinking a while ago, so I pulled DM board out, found bad caps and replaced them. Still blinking... I've heard that DM boards in DLP sets are more difficult to get them going, compared to WS series.
Anyway could you send me detailed repair info on [email protected]?
noblesk
noblesk's picture
I have the dreaded blinking green light on my Mitsubishi ws55511 and had a TV repairman look at it.  He said it needed a new DM Board and will cost about $500-$600 to fix.
Could you help by sending the Service Manual please!
Thank you so much!
My email: noblesk @sbcglobal.net
Eda03
Eda03's picture
Larry
Larry
I have a model WS-55809 with a grenn light for 3 seconds, then a click and green light goes off.
Please email me pictures and what to look for.
Email is [email protected]
Any help you can give would be great.
MitsWS65411
MitsWS65411's picture
My Mitsubishi WS-65411 projection TV has done the following things:
1) It would not turn off with the remote or on the front panel buttons. After I unplugged it for nine hours and replugged TV seemed to work normally for a couple of days.
2) After a night of TV watching that was normal and turning off the TV at bedtime, the next morning the TV would not turn on by either the remote or the front panel.
3) Tried unplugging and replugging again which did not work. When I replugged the TV the green light on the front would illuminate for a couple of seconds and then the illumination stopped.
4) Punched the A/V reset on the front panel which successfully allowed me to turn the TV on.
5) Now when the TV is playing the TV video will flash intermittently and the volume will change either up or down. Neither the remote nor the front panel volume controls are being used when the volume changes. It will either go all the way to highest volume setting or all the way to the lowest volume setting. It seems to get worse the longer the TV is on.
Any suggestions would be appreciated. If you have any instructions on repair you may email them to [email protected].
yang w.
yang w.'s picture
I have a model of WS-55807. When I turn on power, the green light comes on for 3 seconds, then it clicks and the light turns off. Could you please email me the repair instruction to [email protected]?
Thank you very much.
Yang
yang w.
yang w.'s picture
Yang
