783 posts / 0 new
jeannie c
jeannie c's picture
Larry are yu there?
Larry are yu there?
Any ideas (repairman?
Larry Dillon's picture
contact http://www.mitsubishi
contact http://www.mitsubishi-tv.com/support.html, there are also numbers to call there. sk thm about the chasis rebuild, Maybe just a dealer can send it in for you?
jeannie c
jeannie c's picture
Thanks Buddy ! Take care. i
Thanks Buddy ! Take care. i will let you know what happens.
Jeannie
GuardianZX9
GuardianZX9's picture
can someone send me the PDF
can someone send me the PDF manual for the WS65-611?
jeannie c
jeannie c's picture
I had Sears to come out and check my TV. They ordered me a lamp. I will have to put it in myself when it comes UPS. I new I should've just ordered it myself and put it in. I figured they would've done that for me. They had to order it. I didn't know it would be that easy to place it in the front. I thought it had to go in the back of the tv.
OH well. After $500.00 I learn my leasson.
Thanks for everything.
Jeannie
cCuld possibly be a bad bulb
cCuld possibly be a bad bulb or the power supply, First thing I wrote to you in the thread, always do what is the easier first
jeannie c
jeannie c's picture
Thanks Larry... He showed me
Thanks Larry... He showed me the lamp.. It looked burndt out. He said he knows what is is doing,. and that is what is wrong. according to him. We'll see when I turn the TV on. when I install the part. I sure hope so.
Larry thanks for all your support.
Talk to you later.
Jeannie
your welcome, and Good Luck,
your welcome, and Good Luck, please do not hesitate to ask for assistance if you need
The DM board is the main
The DM board is the main control board on the left side of the set. I will send you some info if you tell me what model you have and e-mail address.
jeannie c
jeannie c's picture
The TV I have is a Mitsubishi WD-52525. My e-mail is [email protected].
Jeannie
Eda03
Eda03's picture
you wrote
you wrote
The DM board is the main control board on the left side of the set. I will send you some info if you tell me what model you have and e-mail address.te
My model # is WS55809
my email is [email protected]
green light stays on for 5 seconds and goes out. nothing happens
ClanGannon
ClanGannon's picture
Larry -
Larry -
Found the instructions on replacing the suspect caps on my WS-55711 and had that done for about $15.00.
I put the DM board back in and reconnected it last evening.
I get a fast blink for about 25 or so seconds before the unit shuts down.
I am getting a diag code of 12 "no problem has occurred" using the front panel.
There was a reference earlier in this thread that said
"If it doesn't after the repair try disconnecting the from pwr/vol/chan circuit board and turning it on. Thats what I had to do to get mine to work."
I am thinking that I should try that but I am not sure what "disconnecting fro pwr/vol/chan" actually means.
I have the service manuals in PDF format and I am hoping you could clarify what needs to be disconnected from what.
Clan Gannon in Arizona
Yaz
Yaz's picture
Larry-
Larry-
I own a Mits WD-52628 (52") with the blinking green light. I've disassembled the set. The boards have the following:
DM board (three 25V and 680mF; six 25V and 680mF - 9 caps total)
MICRO board (four 35V and 470mF; one 16V and 270mF; one 10V and 20mF - 6 caps total)
FMT board (0 caps)
RISER board (0 caps)
POWER board (27 caps I can count)
Have several questions while I have the set apart:
1) Which caps on the DM board should be replaced?
2) Should any caps on the MICRO or PWR board be replaced?
3) Should I replace any of the PWR board fuses (I see two)?
4) Are there any other components that should be replaced (I've seen in other posts reference to power supplies, filters, etc.).
Thank you very much in advance,
Scott
AusRAP
AusRAP's picture
Hi Larry!
Hi Larry!
wow glad I found this site. I have the same problem many have encountered here. I have a WS-55711 which does not power up. Plug it in and green light blinks. Then try to power up and light stays green for a few seconds then nothing. Hopefully I could get a service manual from you and save my $5000 investment. Thanks. Here is my email: [email protected]. Thank you again
Will
josh558
josh558's picture
Sat down this evening and turned on the TV to watch the news with the Mrs and have been staring at nothing but a blinking green light for the last hour. Started searching the web and quickly found this site, and hoping that you can help me out! Can you send me your repair instructions (and service manual if available).
One unique thing about the TV's environment is that today it is very cold here in New England, and the heating zone for the room which the TV is in has failed, such that the room is about 10 degrees cooler than normal (about 60F). Is there any history of there being a connection with low ambient temperature to the onset of this problem? Might this clear itself up once we fix the heat? (wishful thinking)
Model is Mitsubishi WS-65813
My email is [email protected]
Sincerely,
Paul
Suzan Vega
Suzan Vega's picture
We replaced the IC's and the
We replaced the IC's and the two pico fuses and when we turned the set back on the fuses blew again. Same error code 2-2. We had someone who knows a lot about sodering do the job and I am confident that he did a good one. Any ideas?
cecil_stock
cecil_stock's picture
I was just given a WD-52825 which is exhibiting the green flashing LED. Could you also send a copy of the repair/troubleshooting details to me? [email protected] Thanks!
GuardianZX9
Can someone send me the
Can someone send me the service manual for the WS-65611?
I hope to try some of the repair steps listed here, my TV has been working fine for 6 years and then green blinking light GBLOD :)
Boss Hoss Don
Boss Hoss Don's picture
I am not sure how to add my
I am not sure how to add my blinking light to the list , so I hope this works!! My tv model is ws 55613 with s/n 155886. Reply to Boss Hoss Don with info or can someone tell me how to better work this forum. Thanks Don.
ShaunJ
ShaunJ's picture
Larry, Could you send me more
ponyboy27
ponyboy27's picture
Help ! We too have the green
Help ! We too have the green light could you be so nice as to send us the info on model WD-62725. ANY help you could give would be wonderful
Thanks! email [email protected]
Thanks so much,
Aved
Aved's picture
I seem to have this same
I seem to have this same problem. I have the WS-48513 and the lovely blinking green light. Any help would be greatly appreciated. Email is aaron5deva at gmail.com
GuardianZX9
WS65-611 anyone have the PDF
WS65-611 anyone have the PDF PLEASE!!!!!!!!!!!!!!!!1
try this link https:/
ITGUY
ITGUY's picture
Happy Holiday's Larry,
I have a WS-65611 that does not respond to the power button or remote ( no green light at all) I have looked at the capacitors and all look OK - not swollen or burst (7 on the DM Power). I have tried disconnecting the control panel on the front and use the remote with no luck. Tried various power sources (HDTV has Monster Power conditioner). I hear voltage when plug in - out. Please send the service manual to [email protected] and any advice/directions on what I should do next.
Thank You...
Thank You
dan22
dan22's picture
need help have same problem
need help have same problem with my tv ws65813 what should i do
ocner63
ocner63's picture
Lary,
Lary,
I have a Wd-52725 with the non power up issue and the green blinking light. I have purchased the new caps for the DM board, I now have decided to ask for a service manual if you can send that info via email and any step by step instructions if you have those to: [email protected] it would be appreciated.
Guy
Leo Serrano
Leo Serrano's picture
Mr. Larry Dillon,
Mr. Larry Dillon,
Looks like you are the " Master "....I have the MITS WS-65411...Not to long ago the picture just turned off. I turned the set back on...the blinking green light came on and the turned itself off...need your assistance of how to fix this,,,don`t to lose this set...
Nick Guillory
Nick Guillory's picture
It seems like you are the one that I need to talk to. I need some help please. I have the Model 55511 and the red projector is offset. I went to the setup menu and I can adjust the blue, but the red won't move at all and it's offset about an inch and a half or so to the left. It makes my screen play in that old school "3D" affect. I was wondering if you could help me or send me instructions on how to fix this. ([email protected])
Thank you;
Nick
tws
tws's picture
Hi Larry. Like all the other
Hi Larry. Like all the other poor saps I read here, my ws65909 has been manifesting the green blinking timer light after the power went out during the storm the other night.
After searching the internet, I can't believe how pervasive this problem is on Mit TV products, and seems to me to be a serious design flaw. Can anybody else spell
