783 posts / 0 new
dcranda
dcranda's picture
I have the same blinking light issue on my ws-48513 and the tv won't turn on. will you please email the instructions to: [email protected].
Thanks Dan
tws
tws's picture
Hey Larry.
Hey Larry.
New member of the green flashing light club since my mits ws65909 experienced a power outage. This one is just a constant flash that doesn't seem to change, and tv won't come on. I expect is the dm module capacitors based on what i have read. Can you please provide instructions so i can fix it?
thx,
tim
CRT23
CRT23's picture
Larry Dillon said: Sure I
Larry Dillon said: Sure I could send them to you if I knew your e-mail address. This repair has helped a lot of peeps fix their sets, but there are some that it does not. Always worth a try I guess.
Hi Larry I have the same problem everyone else is having the green timer light blinking. I have the model Wd-62725 Mitsubishi. My e-mail is [email protected].  Thank you very much.
JEK24
JEK24's picture
I have aMitsubishi WD-62627 with the green timer light flashing and then nothing. The tv keeps going to a blue screen then shuts off with green lights flashing. Any help on the fix for this problem would be greatly appreciated. Email me @ [email protected]
hellofriends
hellofriends's picture
welcome to my site......
[URL="http://www.google.com"]click here[/URL]
Danellis
Danellis's picture
Larry
Larry
I think I have the Convergence IC Problem. The green light comes on for 3 seconds and shuts off.I have the Mits Training Manual, what section tells me about this.I have a WS-55613 and was hoping this problem were the light comes on for 3 sec and goes off is the same problem?
please respond to [email protected]
Larry Dillon's picture
The best advice I can tell
ctscott18
ctscott18's picture
Larry - I have the "green
Larry - I have the "green timer light blinking" problem too. I have Mitsubishi Model Wd-62725. Can you please help me? My e-mail is [email protected]. Thank you!
wally1
wally1's picture
Larry:
Larry:
Purchased the "Blinking Light Repair Kit" and installed the caps. The fuses tested OK. Now when I turn on the set, hear a click but do not get a power light and screen does illuminate. Any suggestions? [email protected]
what is the model number of
what is the model number of this set??????? Larry D
if that Wd-62725, is the
if that Wd-62725, is the model number that is NOT the correct kit for that model, there are almost over1 00 caps that need to be replaced i am sure that model is not on the list as we do not support the DLP tv sets!!! you need to go here for that set this e-mail is an attorney who is filing a class action lw suit against Mitsubishi. for there DLP SET that is breaking down completely and there is only one fix. send the entire electrical chassis to Mitsubishi for a repair. but they say only an authorized service can send in ther chassis for repair. l.comdavid Trinh9([email protected]
wally1
wally1's picture
LARRY:
LARRY:
Sorry ... Model 55613
Checked my previous email.
Should have read "screen does not illuminate"
Wally
ROGERs
ROGERs's picture
I have a ws -55511 and I have
I have a ws -55511 and I have a blinking green light. I had a tech check it out he replaced the caps. green light still flashing tech. said dm is shot he could not give me a reason why other than it would cost 800.00 need help
garymanp
garymanp's picture
Larry
Larry
I also have the dead WD 62525 and would really appreciate the repair info, service,manuals and any photos U have that will help.
U R the MAN.
thanks
Joseph1971
Joseph1971's picture
Hello Larry,
Hello Larry,
Green blinking light on WD-52628. I would like to have the instruction.
Joseph
B.Kent
B.Kent's picture
Hello Larry, I experienced
Hello Larry, I experienced the blinking green light of death on my WS-55511. TV would not turn on at all. I performed the capacitor change out on the DM module (replaced all 7 capacitors). The blinking stopped on the first power up after approximately 30 seconds. The TV powered on and I was back in business (Or so I thought). About 2 hours later I attempted to change the channel and adjust the volume on the TV but no response to either. The TV would not even turn off. I used the reset button and the TV shut off and the green light blinked for about 30 seconds and then turned off. The TV would not turn on now. When I let the TV sit for a few hours I can get it to turn back on but the same thing occurs. TV will not turn off or respond to any remote functions or the front panel buttons either. When I use the reset button it will blink for about 30 seconds but that's it. Any advice would be appreciated. Email [email protected]
iluvsterling
iluvsterling's picture
Please email documents for
Please email documents for the blinking green light problem to [email protected]. Model is ws55511
Jody
[email protected] need to
[email protected] need to change out the cap s as well as the convergence kit,
B.Kent
B.Kent's picture
Thank You Larry! Can you
Thank You Larry! Can you email the instructions for the convergence kit change out and also advise on what parts are needed (if that is not already in the instructions)? Best Regards. [email protected].
Shooter
Shooter's picture
I have been searching and searching for information about this problem for about 2 years!! Thank you for providing it. My Mitsubishi WS55511 has the blinking green light also. Manufactured in Aug 2002. Had problems with this off and on for about 2 years. Usually have to unplug for about 24 hours to reset. Could you please provide the information needed for this repair? My e-mail is [email protected]
Thank you SO SO MUCH for your help!!
Take care, Dave
garys electronics
garys electronics's picture
i have a wd-73733 the green
i have a wd-73733 the green light flashes for bout 15 seconds when you plug it in and finally stops! when it stops you can turn on the set and looks great for bout 20 seconds then the tv shuts down w lamp light flashing and the status light on as well! already changed the lamp can any one help! thanks gary
Sounds like bad caps on the
Sounds like bad caps on the power and fmt board.
Xclipse
Xclipse's picture
Hello Larry
Hello Larry
I gather from the previous posts that you are the go to man. I could use your help, and offer my appreciation for doing so. I have a WD-62627 Mitsubishi t.v. I was watching t.v., and it turned off, I tried turning it on, nothing happened. I reset it several times, and the green timer light flashes for a bit, but the t.v will not turn on at all now. My e-mail address is [email protected].
Thank You
Xclipse
Xclipse's picture
Hello Larry
Hello Larry
Thank You
tvrepairkits.com are going to
tvrepairkits.com are going to have the dlp repairkits available very soon you will be notified. if you do not hear from mein 10 to 14days let me know please.
tvrepairkits.com are going to have the dlp repairkits available very soon you will be notified. if you do not hear from me in 10 to 14days let me know please.
DarlingNicky
DarlingNicky's picture
Does anyone have the
Does anyone have the instructions on how to fix the blinking green timer light on 1080HDTV. Tried unplugging and pressing reset button
Model #WS55517
DarlingNicky
does anyone know how to fix
does anyone know how to fix the blinking green light WS55517 Mitsubishi 1080HDTV
jacob0550
jacob0550's picture
Hey Larry, Hope everything is
Hey Larry, Hope everything is going well with the holidays... I hate to ask this but i need some help... My Mitsubishi WS-55859 is on the fritz... I replaced the capicators on the DM Board but that didn't work... I found out that there is some code by pressing the device and Menu button I did that and got a code 22... they say its a Short Procect Circuit... Is there any way you can send me some schematics or pictures on were the problem is and how to fix it... I would deeply apreciate it.. Thank you
Xclipse
Xclipse's picture
Hello Larry,
Hello Larry,
I e-mailed you about two weeks ago about the green blinking light on my wd- 62627. You replied that tvrepairkits.com should have what I need pretty soon. I've been checking that website and I haven't seen anything for any wd models. You asked me to e-mail you in 10-14 days if I haven't heard from you. This is me, doing that. I sincerely appreciate the help, I know that it takes time for you to reply to all these post for help. You have to be a pretty stand up guy to take time out of your life to help strangers. Sincerely, THANK YOU.
