mitsubishi ws-55613 repair
167 posts / 0 new
holchar
We have the same problem with the blinking light.  We tried unplugging it for a while, and hitting the reset button.  It will not power on.  Could we, please, get some help?  Thank you!!
TASHA034
Our TV wont turn on at all
Our TV wont turn on at all and the green light is blinking, any suggestions?
jessie1071
I to have a mitubishi ws
I to have a mitubishi ws 55613 and my green light is blinking. Repair guy said it would be $500 bucks to fix. Any ideas on how to fix without paying all the money.
Thank You
Jessie
I might have a repair for you
I might have a repair for you to do for your problem but I will need an e-mail address to send it to you.
ntreed
Hi Larry, another blinking
Hi Larry, another blinking green light of death. I understand that you have a solution to the problem. Just my 2 cents worth. If we leave the tv alone and don't try to turn it on the light will eventually stop and the tv will turn on. It may work a few hours or a few days. The light my blink for a few hours or a few days. No rhyme or reason. I haven't read all the forum but some people were wondering about a surge supression helping the problem. I have had a Monster Power surge protection and filter. This is a $700 unit and Monster garuntees to replace anything lost if you are hit with a surge. I have had my WS 55516 on it since day one. Could you pleae forward the repair information to me? Thank you in advance.
 [email protected]
tvman629
How many times does it blink? Or does it blink forever?
No problem to figure it ,I am a tv repairman.Just need more info.
Should have bad caps in the DM module.A common failure -almost all are going bad.
ntreed, the fact that the set
ntreed, the fact that the set will eventually come on when the light stops blinking is for sure an indication that the capacitors in the DM is going bad and if left unchecked and you do not replace them asap, you will destroy the DM board itself. Are you sure of the model number though. Is it a WS-55513? If it is, and you can solder, there are some documents you will need to do this repair. You can save big bucks doing this yourself or having a friend who knows how to solder do it for you. Leave an e-mail address if you would like the repair information. Good Luck
tvman629
tvman629 said: . How many
tvman629 said: . How many times does it blink? Or does it blink forever? No problem to figure it ,I am a tv repairman.Just need more info. Should have bad caps in the DM module.A common failure -almost all are going bad.
Make sure you replace all the 1000/16v caps
Yes it most likely is the
Yes it most likely is the capacitors but they should be replaced at the very first sign of a problem, such as wiggly lines, the set gets unplugged and light blinks for a short time and comes back on. Sure tale sign that the capacitors are going bad. I have repaired at least 300 of these sets and more on-line.
ntreed
Larry Dillon said: ntreed,
Larry Dillon said: ntreed, the fact that the set will eventually come on when the light stops blinking is for sure an indication that the capacitors in the DM is going bad and if left unchecked and you do not replace them asap, you will destroy the DM board itself. Are you sure of the model number though. Is it a WS-55513? If it is, and you can solder, there are some documents you will need to do this repair. You can save big bucks doing this yourself or having a friend who knows how to solder do it for you. Leave an e-mail address if you would like the repair information. Good Luck
Please for give the typo, it is a WS-55613
[email protected]
No problem man. I will have
No problem man. I will have that ifo to you very shortly. Good Luck!
I thought so. I do not know
I thought so. I do not know of a TV set with that other model number. If your handy or know someone who is, get this done ASAP!! I will send you out the repair instructions and if your successful, you will save about 800 plus dollars! Giood luck with the repair.
fishergi
Larry, Please help Mitubishi
Larry, Please help Mitubishi WS 65909 Blinking and wont turn on would you send me the information on how to repair.
Thank a lot  [email protected]
fishergi, You should be
fishergi, You should be receiveing the repair documents anytime now. Good luck
tvman629
larry please help me
how do get out dm module
[email protected]
i will send you the
i will send you the information to help you. Good luck!
hoss5504
Larry Dillon said: i will
Larry Dillon said: i will send you the information to help you. Good luck!
Can you send me the ifo on how to get the dm module out and replace the caps.  I have the same problem.
[email protected]
Dan K
Larry--you are a very busy
Larry--you are a very busy man...  Just wanted to see if you can pass me the fix info for the DM module and service manual I may need to fix my blinking light issues whenever you get a chance.  I have the WS-55513 and have the problem of no power up.  Quite frustrating I must say.
 My email address is [email protected]
Thanks...Dan
Sure! Not a problem guy. Good
Sure! Not a problem guy. Good luck with your repair
bigjer25
Ok, I too have the blinking
Ok, I too have the blinking green light of death, and it is lasting hours so far.  My Mitsubishi WS-55613 is a few years old now, and besides the blinking green light, lately when powered on, the picture is wavy for a few minutes.  I am hoping that Larry can help.
I am a former electrician in the Navy, so doing the work myself would not be an issue, but I really need some guidance.  Thanks on Advance.
[email protected]
bigjer25
Dan K said: Larry--you are a
Dan K said: Larry--you are a very busy man...  Just wanted to see if you can pass me the fix info for the DM module and service manual I may need to fix my blinking light issues whenever you get a chance.  I have the WS-55513 and have the problem of no power up.  Quite frustrating I must say.   My email address is [email protected] Thanks...Dan
[email protected]
The wavy picture when you
The wavy picture when you first turn on the TV set is the first indication that the capacitors were going bad. Hopefully it is not to late. I will send out the repair documents and service manual. Good luck with the repair.
bigjer25
Thanks to Larry for the quick
Thanks to Larry for the quick response.  I could only find 50v 105v 1000 micro-farad caps at the store, will upping the voltage be a problem, or should I do a straight 16v replacement?
Use the link I sent to you to
Use the link I sent to you to order the right capacitors. most of the time the 50 volt caps are way to big for the case and forceing them into the board could break it.
bigjer25
Ok so far the journey has
Ok so far the journey has been fun, but now with lessons learned.  I used some 50v capacitors instead of the 16 v ones, and it looks like I blew a fuse because of it, other than that the process seems to work.  So now I am soldering in the 16v cap's and hopefully I can track down a new fuse.  The fuse appears to have not completely blown, as the resistance is aout 2K ohms, still way too high for a fuse.  Wish me lick
The fuse would not have blown
The fuse would not have blown because of the voltage difference. You probably installed them incorrectly or you had a solder splash on the board. Each capacitor has a plus and a minus connection and has to be installe correctly.
bigjer25
interesting, well the fuse
interesting, well the fuse F9B02 has a resistance of about 2K ohms, so I assume I should replace it, the other 2 fuses nearby have zero resisitance, thanks again for your help.  the weird thing is that the tv booted last night twice, then crapped out again after the cap replacement. So maybe I will leave the 50V caps in and just replace th fuse.
That's fine, but why did it
That's fine, but why did it blow?  Fuses do not blow for no good reason in this set. Maybe the board gets flexed and shorts out against the case when the covers are put on?
bigjer25
I think solder splatter is
I think solder splatter is the culprit.  I had to clean some off of various parts of the board.
Also, there are 2 small dots very close to the cap solder points, they are so close I was wondering if a small amount of splatter would short out another component.
After your last email, I did notice some small splatter, maybe just enough to short something out.  So I have done some clean up work, and hopefully after the fuse replacement we are back in business.
Off we go again.
Lets hope this will be OK.
Lets hope this will be OK. Sometimes though solder splashes can be disastrous.
ppdoeden
I am experiencing the same
I am experiencing the same blinking green light problem on my WS-65909.  Could you please send me the instructions for the cap replacement.
 [email protected]
 Much appreciated!
