need instructions for mitsubishi blinking light repair
591 posts / 0 new
flintjamesa
Please help, our TV has a
Please help, our TV has a blinking green light on the power indicator lamp and will not stop blinking.
I own a WS-55613 model and the TV won't turn on even after using a paper clip or equivalent to press the system reset button and after power cycling the unit by disconnecting power to the unit.
I have gained good insight from this thread.
Please provide service manual documentation and other relevant information to:
Thanks You
Wondering
I also have just lost my Mitsubshi WD-62725 to the dreaded blinking green timer light. I understand that you supply instructions on the fix for this. Could you please help me? Thank you very much. My e-mail is:
Monty72
Im having the flashing green light problem with my Mitsubishi WS65813. Could you please sent me the info on how to fix it. My address is [email protected]
Monty72
TallPaul
Larry (my next best friend),
The blinky green light on my WD-62825 is decidedly less entertaining than the shows that I use to watch on the TV. Would you be kind enough to forward the instructions to the following address.
Thank you.
Adam he.
i recently acquired a mitsu
i recently acquired a mitsu WS-55859 from an irresponsible room mate that was unable to pay bills. I was not too stoked to see that a blinking green light would not stop. So I seem to of found the right blog as to the hundreds of others that have the same issue as me. Shall i repair or dump? That is the age old question. if available please send instructions as to this blinking light of death.
if not i will part with this outdated hunk of plastic for a six pack of your favorite beer.
Adam
Richard Donnell
hello, i too have mitsubishi
hello, i too have mitsubishi ws 55859 wth the blinking green light of death.. please email me with instructions on how to repair...i have trying to find how to fix this tv for sometime now with no luck and found this site..hope you can help me... thanks in advance
Rich
Jimmyd
Does anyone have the repair
Does anyone have the repair procedure for Mitsubishi ws 65513. Same problem blinking green light. Thanks in advance
Redfire
This forum is awesome!
I just got the green blinking lights of death on my 2 year old Mitsu 57
Redfire
[email protected] , I
[email protected] , I have the WD-Y57 1080p. I have sound but no picture---only blinking green light.
Nova1784
January 24, 2009
January 24, 2009
Larry. I have just recently joined
Nova1784
January 24, 2009
January 24, 2009
Larry. I have just recently joined "the blinking light of death" club on my 55859. Can you send some repair instructions for me? I've already determined that if I can't fix it myself I'll have to throw the set into a landfill (a crying shame on Mitsubishi). My email is [email protected]. Thanks Dianne.
Nova1784
January 24, 2009
January 24, 2009
Mark478
I also have the green blinking light plague of death. Can you please send me instructions on how to replace the capacitors. [email protected]
Thanks You!
Hogan
I replaced the caps on my WS
I replaced the caps on my WS-65511. Then the IC Convergence and all the pico fuses. Then the E2P. Still the @&%#* green blinking light.
Then, I noticed several miniscule black squares with a smaller square inside them on two boards and the DEMOD-B. They are flush with the surface.
I looked on other boards and found the same "square with a square inside". Except they were copper in color.
My suspicion is that these are an internal fuse of some sort. And the black ones mean the board is fried. Can anyone confirm my suspicion?
-- Hogan
Ritch
I have a WD62525 with blinking green light, can you send me instructions on [email protected] Ritch
DAB
I think you hold the answer to the blinking lights of death. Can you please send the instructions for Model WS65813 to [email protected]. THANK YOU!!!!
DAB
We have experienced the same blinking lights of death on our Mitsubishi Model 65813. Can you please send the instructions to [email protected]
THANK YOU!!!
fgbatson
Larry--I hope you're charging
Larry--I hope you're charging for these. I too am depressed that my Mit.57731 has the blinking green light and not coming on. What do I do? How do I fix? Can you send the instructions? thanks Man.
Frank
fgbatson
Larry--
Larry--
Hey man, I too need help with my Mits 57731 Tv blinking green light and not coming on consistently--today not at all. What do i do? How do I fix.
Thanks man. Please e-mail and let me know. [email protected]
Helene
Larry:
Larry:
Can you please email me instructions on how to get rid of the blinking green light of death to get my TV working again? My family would GREATLY appreciate it.
Thanks a million!
Helene
tolberg
I was told by anouther guy to replaced the 16v compacitors with 35v compacitors on a Mit WS-55859. I replaced them and still have the green flashing light. Was wondering if I should have replaced them with the 16v. I did use the 1000 uf.
tfizz
can someone please send me
can someone please send me documents on how to fix this as well. [email protected]
tfizz
i have a ws-55513 and having the same blinking light problem. Can you please send me some information on how to get this fixed?
Thank you
RobinR
I have a Mitsubishi ws-55859
I have a Mitsubishi ws-55859 with the same blinking light problem. I removed the DM and checked the capacitors. They all look good and read properly with a Fluke. Is it possible that they are still bad and need to be replaced? Also, can you send me a copy of the instructions you have?
Thanks so much for your help,
Robin
ruesta
hi larry help me please this
hi larry help me please this mit ws65517 i changed the 4 caps on DM board same problem blinks all the times any wags i reset many times no power up somes times power comes out. thanks for your help.
John32
I too have the wd 52525 with a blinking green light. I have been without the set for a month but, decided today to go get a lamp with my four year old (he got a movie I got a lamp). After no change in its behavior I went online and found you helping alot of people with the same problem. Would you send me your instructions? I would appreciate any help you could give me.
Sincerely,
John
sboone1074
Larry I too could use the
Larry I too could use the instructions for the DM board fix. thanks in advance.
send to [email protected]
kimi
sorry half of my post did not
sorry half of my post did not go thru. Hello, I was shocked to see so many people with the same dreaded blinking green light issue with the Mitsubishi TV. I have the WD52725 and I have been unable to stop the madness of the blinking light of death. Please let me know if there is anything you can do to help me stop this flashing light and get the tv to turn on again.
Please send help! to: [email protected]
Thank you so much!
Hogan
Hey, Larry,
Hey, Larry,
Welcome back. Haven't seen you post in over two weeks. Hope you are feeling well.
Can you confirm my Jan. 25 post above?
-- Hogan
