need instructions for mitsubishi blinking light repair
591 posts / 0 new
shirleydh
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-55613 tv. The green light keeps blinking.
thank you for all your help
shirleydh
Where would you like me to
Where would you like me to send them too!? You will need to leave an e-mail address for me to send those documents out to you.
steven r
Please send me the
Please send me the instructions on how to remove and repair the dm board in my Mitsubishi ws-55613 tv. The green light keeps blinking. I really appreciated
Steven Rah
yulfo
Please send me the instructions on how to fix the DM board on my Mitsubishi ws-65513.  My husband can sodder if you can send instructions to [email protected].  Thank you.
yulfo and Steven, I will send
yulfo and Steven, I will send out the documents as well as the factory service manual this evening sometime. Good Luck with the repair.
Bkaye13
Please send instructions for WS55613 blinking light of death to [email protected]
Thanks, your help is much appreciated!
Bkaye13, I will send those
Bkaye13, I will send those repair documents out this morning to you. Good Luck
rblackmore
I also have the same blinking
I also have the same blinking light problem on my Mitsubishi  WS 55513.  Any help with instructions for fixing would be greatly appreciated.  I took it to a repair shop and they told me the control board was out and it would be $525.00 to fix.  I'm worried about putting that much money into a 4 year old TV.  What else could still go wrong after that is fixed?  Any help or advice would be greatly appreciated.  How long do the bulbs last and how much are they to replace?
 R Blackmore
Oklahoma City
Rblackmore, the bulbs, or
Rblackmore, the bulbs, or what we techs call the picture tubes, do go out, but not on these sets as they do on other manufacturers. I know a lot of Mitsubishi TV sets a lot older and the picture tubes are still working fine. Another common problem with this make and model is the convergence IC's that go bad sometimes  in these sets. The less you play with the convergence alignment, the better off you will be. I will add you to a list to receive the service manual as well as the repair documents that I will be sending out soon. Good Luck with the repair.
yulfo
You posted that you were going to send out the instructions to repair our tv on the 13th.  Could you please email me at [email protected] and let me know if you did send them, and where you sent them.
Thank you
Michele yulfo
G Craig
               I have the green light of death with my WS 55813. Could you please send me the instructions to repair the DM board to [email protected]
        Thank you
Michele, what was the model
Michele, what was the model number of your TV set?
G Craig, I will send those
G Craig, I will send those documents out this afternoon. Good Luck with the repair.
yulfo
our model is mitusbishi ws-65513.  you were going to send me the repair instructions for the dm board.  Do you need my address or will you email them?
Michele yulfo
I thought I did e-mail them
I thought I did e-mail them to you. I was just about ready to send out to another person. I will certainly add you to the list. Good Luck with your repair.
JeffFore
I am plagued by the green blinking light on my WD-52725.  Please send me the fix instructions at [email protected]
Thank you very much,
Jeff
Jeff, I mailed out the
Jeff, I mailed out the instructions. This model is done a little different. Simply get the DM board out, and follow the document on replacing the capacitors. This is the model that does not use the picture tubes but a light engine. Good Luck with your repair.
steven r
Hi Larry
Hi Larry
 I fixed my TV after a few days of delay. I just want thank you for your help. It was a great deal of relief.Steven
Great news steven r! Glad to
Great news steven r! Glad to hear you got your set working again. Merry Christmas.
dans_repair_service
A related question, sort of..
A related question, sort of...
Can this cap repair also deal with a set that is completely dead?  I received a question from another user indicating that this model was dead.  No blinking green light, but may have had that problem before it went completely dead.  Is this a good place to start?
Dan
Yes it can Dan, it is rare
Yes it can Dan, it is rare but it has happened. If you do get this symptom, most likely one or more of the fuses are blown in the power supply. They are labeled F9A02 and F9A03. These are the fuse that carry the voltage to the DM and as well to other parts of the TV set. Most of the time though when I find one of these TV sets bad, or lets say dead with no green light, the fuses F9A04 and/or F9A05 are blown. This is a really good indication that the convergence IC is the issue.  I have in the past also replaced the DM capacitors and then the green light goes out after about a minute, and have found the convergence IC(s) at fault. I say it like this because some Mitsubishi TV sets only have one convergence IC, I guess you would know that already though.
Tate
Can you please send me the instructions for the green blinking light.  I am having the same problem with my Mitsubishi 55" wide screen.
 Thanks....
Bruce Woods
Hey Larry, I have the same
Hey Larry, I have the same blinking green light on my WS-55613 that will not go away, could you please send me the information on how to repair this problem...Thanks, Bruce
Sure Bruce, i will get that
Sure Bruce, i will get that out to you this afternoon. Good Luck
nseidl
Larry Dillon said: Sure Bruce
Larry Dillon said: Sure Bruce, i will get that out to you this afternoon. Good Luck
I am having the same problem with my wd52525.  Would you be so kind as to send me your instructions as well?
 nseidl <at> wi.rr.com
Consider it sent already.
Consider it sent already. Good Luck and Happy New Year.
Utegeo
I also have the green blinking light on a WS-55613.  There seems to be a lot of them.  Would you please send me the instructions as well.  The address is [email protected].  Thank you.  Utegeo
Utegeo, I have added you to
Utegeo, I have added you to the list of recipients who will receive the repair documents in just a little bit. Good Luck with your repair and Happy New Year!
2of12
Hi Larry I too have the
Hi Larry I too have the blinking green light Model WS-55511 help DM board repair please [email protected]  is the E-mail.
2of12, I will send you the
2of12, I will send you the documents to see if this is the problem with your TV set. Good Luck and Happy New Year.
Utegeo
Larry Dillon said: Utegeo, I
Larry Dillon said: Utegeo, I have added you to the list of recipients who will receive the repair documents in just a little bit. Good Luck with your repair and Happy New Year!
Thank you for sending the link to the original thread.  I read through it and decided I could tackle it.  A friend and I did the repair today in about 3 hours.  We did have some issues with pulling the chassis out given the wiring.  I also used a step by step insturction that I found on another un-named site.  Again thank you. Utegeo
