mrtoner, Great news Man!! Glad to hear you saved tons of cash. If you read the original e-mail i sent you, it will explain the reason I sent you the original factory service manual so you can take apart the set and clean the morrors and lens after you repaired your TV set. Read the entire e-mail, it will explain about the cleaning. Good Luck!
Larry Dillon said: I will certainly send you out the repair information for your TV set. Good Luck!
Thanks so much!
I removed and repaired the DM. Someone else worked on this unit before me and pulled the doubler out for some reason. After repairing the DM I noticed a little surface mount cap laying on the tuner board. I pulled out the doubler and sure enough it had fallen off that board. I was getting the flashing green light before I replaced the four caps on the DM but now I get nadda... no lights at all. I checked the fuses (all the ones I could find). I have the 9v standby voltage (9VS) but the 30vs test point reads 0. Would a problem with the doubler cause this? Any other ideas about what to try next?
Thanks again for all your help. I'll let ya know how this turns out.
Frank, double check the soldered in pico fuses in the main power supply. They would be marked on the main power supply board as F9A02 through F9A06. One of those could be bad.
Larry Dillon said: mrtoner, Great news Man!! Glad to hear you saved tons of cash. If you read the original e-mail i sent you, it will explain the reason I sent you the original factory service manual so you can take apart the set and clean the morrors and lens after you repaired your TV set. Read the entire e-mail, it will explain about the cleaning. Good Luck!
Larry - would you be kind enough to resend the e-mail? Seems to have disappeared..... [ probably me ].... [email protected] Thanks!!!!
My 2 year old WS65813 developed the blinking green light of death this weekend. Can you send me the repair with pictures. My email is [email protected]. Thanks for your help.
either way larry, as you can tell from the other post I replaced the 7 caps on my ws65869 and its still blinking. Any suggestions before I go Jihad on this tv?
Larry, I would appreciate it if you could send the document to me. I have the blinking green light too. My TV is a 65813. My email is [email protected]. Thank you.
Larry Dillon said: You will need to check the small fuses on the main board, in the power supply. Theyt are marked, F9A02 through F9A05. Check them all for continuity.
Larry, I'm JonP's friend with the TV... checked the fuses, all have continuity... what next?
Jihad on the tv? Maybe a cap came bad, I'll check those tonight, but I doubt it... Larry will the tv still blink if the boards housing isnt properly grounded or will it just be dead?
Make sure the capacitors are all in the board correctly. They all do have a polerity on them. Next thing would be to check all of the standby voltages in the standby power supply. You know there is the possibility that the capacitors have indeed blown out the chips in the DM. I have seen bad DM's in about 21% of these cases.
Larry Dillon said: Make sure the capacitors are all in the board correctly. They all do have a polerity on them. Next thing would be to check all of the standby voltages in the standby power supply. You know there is the possibility that the capacitors have indeed blown out the chips in the DM. I have seen bad DM's in about 21% of these cases.
Made sure (and double checked) before installing DM power supply that all capacitors were put in with the correct polerity... How would I go about checking the standby voltages in the standby power supply? Any suggestions on where to by a used/refurb/new DM for the WS-65869 from at a good price? Thanks again
Oh now I see? You are on the wrong board man. Look at the model number of this thread. Check the on board fuses on the DM board. They are marked F9B00 and F9B01
Larry! Help! Im a college student who just purchased on these tv's (Mitsubishi WS-65813). The person who had it was nervous about fixing it and gave it to me for an amazing price. However they had no manual. Could you send me the manual and how to fix it?(blinking light of death) I have read other reviews on how to fix it, but would like to see yours. Me email is: [email protected] I have already ordered parts from Digikey. They should be getting here tommorow. Please help me out! Thanks Larry!!
larry I just checked the fuses on the ws65869 dm board and they are fine, also when I put the meter on the diods the voltage keeps going up so it seems the caps are charging even off of the meters power... Any other suggestions??
Oh my Gosh, That would make a neat You Tube video? Although you could probably get Mitsubishi to do something for you. I would at least ask before you destroy your TV set.
do you know where we could find a dm board? If not what do they usually go for? I dont want to get stiffed by the repair guy. whatever the culprit you can assure yourself SOMETHING on this tv is going to have some holes in it when this all over! I'll post it on here for all the others that feel our pain LOL. Anyway, thanks again in advance you've been very helpful.
I have the same problem as well. My 65813 used to have the blinking problem more often but Mits told me there was a software update. They sent me the card free of charge and seemed to fix it. About 6 months later had the blinking green light but was able to get reset some how. Now it's back and I can't clear it. Would you be so kind and send me those instructions and diagrams to [email protected] Thanks!
James, I will certainly send you out the repair information in a short while. Good Luck with the repair.
Thanks so much!
Frank
DTS
Scott
Scott And mrtoner, I will be sending out the documents a little later today. Good Luck with the repair.
hey larry I posted a new thread for my particular TV if you could take a look at it I would really appreciate it, thank you !
http://www.techlore.com/forum/thread/20592/Mistubishi-WS65869-Blinking-Green-Light-OF-DEATH/;jsessionid=D579CBE92A85417D516CAC7AE6156EA2
nerua196, I will send out the repair information in a short time. Good Luck.
Larry, I would appreciate it if you could send the document to me: [email protected]. Thank you.
Larry:
Your a pretty popular guy with those repair instructions!
I have the same problem for my 65813. Can you please forward me the instructions and diagrams as well? My email address is: [email protected].
Thank you so much!
-D-
Derek, I have sent out the repair documents for your TV set. Good Luck
Awesome, thanks...never worked on electronics before...but here goes!
Take care.
Larry!
-Caleb
ONE SHOT LEFT AND I'M GONNA ENJOY IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Blinking green light, meet blinking red light...
Caleb, that repair info will go out in this mornings mailing. Good Luck with the repair.
Go to ptscorp.com, Get the number and call them. I think they will rebuild your board for 175 bucks or so.
Chris
