Larry, Thanks for the info about PTS Electronics. I am shipping off my TV chassi for repairs. They will fix what ever is wrong with it for a flat fee of 295.00 plus shipping. Once in shop about 5 to 7 days for it to be shipped back. This sounds good to me. Thanks a lot for your help. I will let you know how this turns out. Have a good day. Skip [email protected]
Larry Dillon said: Your problem, very well could be the power supply, but in 65 to 70% of these blinking light cases, it is a 1200 dollar repair needed to get your set working again. I will of course, if your able to follow directions, to send you the documents i have to repair whats called the DM board. You seem like a bright enough person, as most do not realize, or tell me where to send the info, so i have to ask where they would like it sent to. Good Luck with this repair.
Guess what Larry, I have the same problem. I repaired copiers in a a previous life (which included some soldiering in new chips) so with your instructions/schematics I should be able to fix it. Can you please email me the DM board repair instructions?
Larry, I got my ws-55613 chassis back from PTS as un-repairable, It would cost more to repair than the TV is worth. They said this is a terribly designed TV because when something goes bad it usually snowballs through all the electronics. If you have any suggestions please let me know. I am at my wits end. Thanks Larry, Skip, [email protected]
I also have the blinking green light on the WD 62725. I'd like to try the fix you have posted here. Would you mind sending the repair pkg to me as well? My e-mail address is [email protected] . Thanks in advance.
Having the same problem with WS-55813, (green blinking lite) could you please forward any possible solutions. Have electronic and soldering experience. Thanks, Barry [email protected]
Same issue with GLOD... After trying the voodoo ritual of working the front panel buttons (still wonder about that forum), I popped the TV's cherry and removed the back panel. How I removed the DM board without breaking anything is a sign that I can really do this.
Ordering my caps online from Mouser, but sure would love the service docs and repair manual.
I have a mitsubishi 3 year old wd62865 with the green blinking light problem.
if this is a cap problem on the dm board with this model also i could replace
them except I don't know where the board is or how to remove it. Any help would
be apperated. I am retied and can't afford a $1000 repair bill.
Got it, Larry. Thanks! I haven't held a soldering iron since 7th grade... but I got my big screen back for only $.92 in parts! I thank God for this forum and people like you who go out of your way to share this info.
I have a WS-55813 set that also has a blinking green light on the front. I was hoping that you could send me instructions on what to do/which caps to change my email is [email protected] thanks a bunch
I have the 55813 with the same blinking light problem. can you email the directions on replacing the capacitors as well? I appreciate your assistance. [email protected]
I have the green blinking light and replaced the capacitors with 4 new 1000uf 35v capacitors and did a system reset and still have the blinking light. What could it still be?
Larry My Mitsu ws-55813's dreaded green light just came a blinking. Unplugging and resetting are not working. Need instructions badly, can you please help me. Thanks so much
Larry My Mitsu ws-52725's dreaded green light just keeps a blinking. Unplugging and resetting are not working. Need instructions badly, can you please help me. Thanks so much [email protected]
Hello Larry, Could you send me the instructions for the WS-55813. It is exhibiting the green light of death for a month now. Thanks You for the help. My email address is [email protected]
Could you possubly send me some information on the replacement of copasitors for a WD-62725 if you gave it. I also have th Green Light of Death on my TV.
Thanks so much!!
WR
WR, What's the model number and WHERE do I send it to?
Hello Larry,
Thank you for the reply, we have the WS-55813. Blinking light, no picture. Please send the info to email [email protected].
Thanks so much for your help!!!
Regards,
WR
Hey Larry,
The model of my TV is WS-55513 not WS-55813. Please advise. Will this make a difference in the replacement parts??
WS-65813
Much obliged!
Jeff
Barryo and Jeff, I will have those documents out to you shortly. Good luck
Thanks, Larry! Have you had a chance to send it yet? I'm hoping it didn't get tagged as spam and I missed it.
Take care,
Jeff
Jeff, I did send them out to you. I will try it again. Look in your bulk mailbox also.
Fergy, I do not have that info you are asking on this model of TV set. I will see if I can get a service masnual and get back to you.
Glad you fixed your TV set. If you have any troubles, contact me. Or leave a message here.
Larry!!! you sure are a popular guy. I am also in need of the repair manual for my WS-55859. I already have the DM board out. [email protected]
thank you and God bless
Dan
Dan, I will have the information out to you shortly. Good luck
Hi larry,
where would you like them sent to? e-mail address would be helpfuLL!
Send instructions to [email protected] thank you
thanks
Could you please send the documentation for a WS-55613 to ganderso at gmail dot com Thanks for your help.
/george
