Hi, Larry. New member here, awesome site. I have a Mitsubishi WS73713 with the blinking green LED problem. Can you send the repair instructions to [email protected]? Thanks in advance and Happy Holidays!!
Larry Dillon said: If you are handy, and can solder, you may be able to save about 700 bucks if not more. There is a very common problem with these Mitsubishi TV sets. There is a digital board inside these puppies called the DM board. A lot of times there are four capacitors that go bad inside of these TV sets. Sometimes, depending on how bad the capacitors are, and if the capacitors did not blow out anything else on the Dm board, you can simply replace these four capacitors and this will fix your TV set. The average that this works on is about 65 to 70 % of the sets can be repaired with this fix. The others are power supply issues or the DM board has other issues. If you would like to attempt to repair your TV set, I will send you the instructions on how to do so. If you do not know how to solder well, do not attempt to replace the capacitors yourself. Pay a pro to do this for you. After all you are already saving a bundle of cash. Leave an e-mail address, and I will forward you the fix with and without the light engine. And if the capacitors inside the board are not swollen on the tops, as the direction shows you what they look like, change the capcitors anyway. I have had a few that looked good but the capacitors were on their way out. Good Luck
I am having the same problem with the blinking green light. Can you send me the repair instructions? Thank you
Larry Dillon I have replaced the 7 caps on my WS-55859 from the dreaded green blinking light. Now the TV powers up after blinking for 60 seconds but no picture or sound and after about 5 minutes the TV powers off. I have tried resetting and unplugging but nothing seems to help. Any suggestions or mistakes I could have made.
Kahuna, Look on the main board, in the power supply and check the fuses marked, F9A04, and F9A05. Also check the fuses marked F9A02 and F9A03. let me know if any of these are open.
Yesterday I ordered those capacitors yesterday from diglink but have not heard anything other than the confirmation email that they received my order. How long does it usually take for them to ship your order out.
JWA, did I not send you the information? I have a link to get them right away from Mouser electronics in the e-mail I sent to you. Digi-Key has been on backorder for weeks now.
Big Kahuna said: JWA I found my capacitors at radio shack part # 272-1032 1.59 each had to call four stores to find them all. Worth a shot for you BTW Larry my email is [email protected] if you have anything to send to assist me. Thanks All
Was that the same compacitors that was the panasonic ones for the 4 on the DM board?
Larry, When you check the fuses on the circuit board with an Ohm meter do you get a correct reading when it is still attached to the board or do you have to take them off the board to accurately see if they are open??
The 35 volt capacitors will not fit on the board properly. If you can get them to fit with the case on, not a problem. You need at least 16 volt capacitors
Can someone send me a picture with all the connectors hooked up on the ws-65513 boards. I replaced my caps and there is one red wire with a 2 pin connector on it, not sure where that went , or maybe it wasn't hooked up?
Yes JWA. amos, where does the other side hook up to? There is an interconnection wire diagram on the first page of the schematics, in the back of the service manual.
Sorry it took so long to post back, but it has been crazy with the holidays and all. I followed these instructions and replaced the bad caps, and now the Tv is working like a champ. Thanks Larry you are awsome.
JWA, no, you do not have to take the fuses off the board to get a correct reading. It is open, or will measure a short acrossed it. The short across the fuse is what you want. If you get no reading , or very little reading, the fuse is bad. The 35 volt capacitors will work fine if you can fit them into the board and then into the case.
I will send out the documents and the factory service manual to you right away. Hopefully have the set repaired by Xmas. Good Luck
Larry, sorry I didnt put my email address for you to send me the info. It is [email protected]. thanks again
Sure, it is on its way. Good Luck with the repair.
Thanks in advance,
Kahuna
Thanks Larry, I will check those when I get hoe tonight
Do you have a schematic of the board to aid in locating them
I do not have a service manual
Thanks again
Kahuna
BTW When I do the error code I get 12 blinks
which I understood means everything is okay, although it is obviously not.
JWA
http://www.mouser.com/search/refine.aspx?Ntt=140-HTRL16V1000-RC%09
Ok Larry, Thanks Ill try them. I just checked and they are on back order until jan 08 so mouser is the way I will gol
JWA
Mouser has them, plenty of them and right away too.
I too am having this problem. Can you send me the repair procedure? [email protected]
Thank you.
JWA
Thanks All
Big Kahuna, the Radio Shack capacitors are fine and will work, but it is highly recommended that you use the high temp type capacitors.
GMD, what is your model number of the set you have?
JWA
Sorry, Model #WS-65513
Thanks again.
Its a WS-65713. I notice the RS compacitors are 35 volt vs the 16v that are in there now. Does that make a difference
JWA
JWA
I have a Mits WS-55813 that has the green blinking light problem. Could you send me the service docs ans info?
Ron
JWA, You do not need to remove the fuses to get the correct reading. It should measure a short across them.
Ron and GMD, I will send out those documents as well as the service manual a little later this evening. Good Luck with the repair.
Larry thanks for the info. So if I can get a reading that means they are still good, is that correct
