Larry Dillon said: If you are handy, and can solder, you may be able to save about 700 bucks if not more. There is a very common problem with these Mitsubishi TV sets. There is a digital board inside these puppies called the DM board. A lot of times there are four capacitors that go bad inside of these TV sets. Sometimes, depending on how bad the capacitors are, and if the capacitors did not blow out anything else on the Dm board, you can simply replace these four capacitors and this will fix your TV set. The average that this works on is about 65 to 70 % of the sets can be repaired with this fix. The others are power supply issues or the DM board has other issues. If you would like to attempt to repair your TV set, I will send you the instructions on how to do so. If you do not know how to solder well, do not attempt to replace the capacitors yourself. Pay a pro to do this for you. After all you are already saving a bundle of cash. Leave an e-mail address, and I will forward you the fix with and without the light engine. And if the capacitors inside the board are not swollen on the tops, as the direction shows you what they look like, change the capcitors anyway. I have had a few that looked good but the capacitors were on their way out. Good Luck
I have a ws55513 with a blinking green light and the repair man said it was the dm board, i was wondering if i could get the info and diagrams to do this repair, my e mail is [email protected], thank you very much in edvance, i really apreciate the help!
Alright I am also having this problem, thank you for the info on this forum and could you send the instructions and manuals to [email protected]. Really appreciate it, this problem seems simple, I can solder so I am excited.
Larry Dillon said: Yes I will send out the documents so you can see if this is indeed your problem with your TV set. Good Luck with the repair.
thank you so much for the help! it took $10. and 30 minets and my tv was up and running, it had 4 boulging caps and that was it, you saved me houndreds!! thank you, Casey!
My Mitsubishi WS55909 has been working fine for over 5 years. We had a power outage lasting 3 days. When power was restored we get the never ending blinking green light. Pressing reset has no effect. I was wondering if it could be the capacitors on the DM board. I realize there could be several possibilities. If you have instructions on a possible fix for this model along with a service manual, it would be greatly appreciated.
Thank You in advance for any help with this issue.
You seem to be the guy my light only blinks 3 times then stops do you think i have the same problem. TV would not start after moving it to new house ws-55513. If you think i should replace please send the plans. Thank you.
JWA said: Kenny G, I have the same tv you have and I had the same problem, replaced them and now it works fine JWA
would you happen to have the directions still? i have not heard from Larry and would like to get this thing working again before all the bowl games begin....
Ken You just asked for the direction at about 8 PM man. Patience my good man. I was working man. I am sending them out shortly also to nysc3141. Good Luck with your repair.
Can someone please email me the schematic and the repair manual for the Mitsubishi WS65813? [email protected]. Christmas is not a good time for the TV to go out!
I don't know how but last night I got the TV running. I did so many things I have no clue what worked. But thanks for all your help and the information. I could never have done this without you. Many many thanks
I have a Mitsubishi Diamond WS-65813 with the blinking green light syndrome. Can you please email the repair instructions??? I am dying to watch bowl games on my big screen... Can you help please??? Email is [email protected]
You probably want the service manual. If you want the owners manual, you can download that for free athttp://www.mitsubishi-tv.com/support/ownersguide/default.asp. I will certainly send you the service manual as well as the repair documents. Merry Christmas.
Larry, Please send us the instructions to replace the capacitors in our Mitsubishi. Thank you in advance and Merry Christmas! suzie_dahle<at>hotmail<dot>com
SuzieD, I certainly will send out the repair documents as well as the factory service manual so you can attempt the repair of your Mitsubishi TV set. Merry Christmas to you as well!
Sorry, I just joined this group because mine is doing exactly the same thing. It has had its moments ever since I bought it where it would suddenly turn off and do th4e flashing green light thing. This time it took three days (over Christmas) before it would come back on. I think I'm heading down the capacitor route. If anybody had the instructions and can mail them to me that would be great. Thanks in advance to anyone that can help.
I, too, have a WS-65813 with the blinking green light problem (Seems like the Christmas Grinch just visited...)
I thank you in advance for a copy of the instructions to repair this problem and about how to get to the DM board. Thank you!!!! And thanks for brightening the holiday again. :-D [email protected]
I will be sending out the information you are requesting a little later this morning. Good luck
Hello Larry,
I have a WS-55859 and this morning I set down to watch my favorite recorded Sci-Fi show and all I got was the dreaded blinking Green light.
Could you please send the capacitor info and svc manual to fix this annoying problem.
Email: [email protected].
Thanks for taking the time help the less knowledgeable.
GammRX and transmitionman, I have sent out the repair documents you asked for. Good Luck with your repairs.
Glad to here it worked Casey. Merry Christmas.
Thanks to all for your replies. Larry I was so stupid, all the connectors are marked. My tv works great.
Thanks again
Jim, It certainly could be an issue with the DM Module. I will send the documents out to you this morning. Good Luck
Great news amos, Your not stupid I'm sure of that or you would not have fixed your TV set. Glad to hear you sorted everything out.
I have the same darn problem with the green blinking light on my Mitsubishi WS 65513. Would you mind sending me the fix regarding the capacitors?
Thanks a Bunch !!
Ken
JWA
thanks for the reply JWA !!
Let me look and see if I can find them. Ill email them to your email address above
JWA
JoD, I will send out the repair documents to you shortly. Good Luck
Larry
Many many thanks
Mitch "Big Kahuna"
You probably had it fixed when you changed the capacitors and might have had a loose connector or plug. I have seen this many times. Merry Christmas.
Forgot to ask for the owners manual too, if you have it! [email protected]
You probably want the service manual. If you want the owners manual, you can download that for free at http://www.mitsubishi-tv.com/support/ownersguide/default.asp. I will certainly send you the service manual as well as the repair documents. Merry Christmas.
Mark Oliver
