KP-46WT520 9 Blinks
244 posts / 0 new
MDP123
Larry, I stumbled on this
Larry, I stumbled on this forum after desperately searching Google for some insight to my initial 10blink then 9 blink problem. THANK YOU THANK YOU THANK YOU. I followed your advice ordered the parts, had a friend solder them on and presto tv is working again like new! You saved me a ton of money and aggravation. Side note..had a long call with Sony support rep, no matter how hard I explained the problem they were utterly clueless. They kept going back to "well unplug the tv and plug it back in, make sure its no on the UPS or surge suppressor"
Any thank you again for the excellent advice and instructions!
hoopsjsh3
I was not able to find the
I was not able to find the service manual on the technician's corner page for a sony kp-46wt520. Has it been removed or am I just not seeing it? Thanks!
Alnp
Your model kp-46wt520 has the
Your model kp-46wt520 has the same AX-1X chassis as the kP51WS520 manual listed on the download page.
mikeMinMTL
Larry Dillon said:
Larry Dillon said:
  • REF. NO.      SONY PART NO.            DESCRIPTION         GENERIC PART NUMBERS       D6116           8-719-081-97                 DIODE                       MMDL914T1  No longer available
  •  New D6116   8-719-074-43                 DIODE                       BAS316-115       D6301           6-500-567-21                 DIODE                      10ERB20-TB5  You can get these diodes from www.partstore.com
    There you go. The NEW updated parts list for this Sony TV set. Now where else could you get service like this for free? Good Luck with your repair.
  • DIODE BAS316-115   Sony   8-719-074-43   $6.49
  • Larry, this sounds like the fix for me. One problem- I live in Canada and partstore wont ship here!
    However, you can get it at: http://www.globalsemi.com/
    OK, Got the parts in one week. Cost was $28 shipping included.
    Used multi-meter to determine the polarity on the small D6116.
    Re-plugged everything and VOILA, the TV works.....
    Thanks so much guys.
     P.S. I called a Sony repair center before finding this site. The cost to come to the house and fix the TV was $250. That is a savings of $220.
    robsteel
    I am about to try to fix my G
    I am about to try to fix my G board but I have some questions and hopefully someone can answer them...here it goes...
    1. What wattage soldering iron should I use? 2. Should Rosen soldering flux be used when reheating the joint? 3. Does reflowing the solder mean reheating the existing solder joint only, without adding any additional solder? 4. Is there any type of meter that someone can recommend to test to see if the diodes are working?? Thanks.
    rajtyl
    HI LARRY,i have a sony
    HI LARRY,i have a sony kp53v90. Do you know the part #for sony ceramic fuse(125v-2amp).one is shorted.had a problem with convergence ic's .i replaced with original sanyo ic.if you have service manual could you email me a copy. email address;;;[email protected]...
    XFile69
    ok i ordered the two diode
    ok i ordered the two diode but one was a surface mount one. i hear i have the correct one but i'm sorry didn't get that far how to replace the surface mount that was a regular diode.
    Seaner
    MOtvGuy said:
    MOtvGuy said:
    The old 9 blink 46WT520 problem.  There are 2 diodes on the G board causing this. I don't have the referance numbers but you can use standard diodes.  I'll look them up today and post later.
    You sir are completely awesome...Thank you very much...
    I just got a free KP-51 with the 9 blink code. I just changed the d6301 (the larger one) and budda bing
    pepsigerry
    I have a question. If I
    I have a question. If I remove the G board is there anything that can ZAP me inside that I must look out for? I have the 9 blinks also, and want to try and fix it myself! Thanks for your time, Gerry
    Jeff-R1
    After following the great
    After following the great instructions for the 9-blink issue, I replaced the 2 diodes (6301 and 6116) on my KP-51WS520, and the TV fired up and all was well and ran great...until the next day when I went to turn it on again. 9-blinks and no picture again. Could this be the same diode(s) went bad again or is it something else on the G-board circuit. or could it be the D-board? Thanks ALL for the great info posted!
    jgiguere17
    I have a 46wt520 and I counted my blinks and received to what I think is a 10 and a 9 error codes, but it blinks 10, 9, 9, 9. I thought I could have made a mistake when counting but I counted again and I still get 10 for the first and the rest 9's. thoughts on what to do? I think I may have more than one board to fix right?
    robsteel
    I had a problem with my G
    I had a problem with my G board and I was going to fix it myself but then I stumbled upon a company called Tri State Module 800-203-7484. More than likely it is the 2 diodes that are not working. The way they work is that they charge a $20 bench fee to look and diagnose the G board to see if it is a problem. Once they do that, they will call you and fix the board. It only costs $45 dollars to fix and that price includes the $20 bench fee. Then they ship it out to you for $5. So for $55 dollars (5 to ship, 45 to fix and 5 to ship back), I got a rebuilt G Board that I popped into my TV and (Knock on wood) is still working great 2 months later. Don't give yourself a headache, just call Tri State Module and everything should be fine.
    pepsigerry
    Can the G board be safely
    Can the G board be safely removed with the power off? I don't want any surprises! thanks
    phototakinfool
    My Sony kp-fx432m91 TV red lt
    My Sony kp-fx432m91 TV red lt blinks 10 time and does not switch on. On resetting the elecrical power from main socket,it does switch on but on next start up does same thing. Pls help.
    johnny10
    My Sony trinitron KV-29CL11K
    My Sony trinitron KV-29CL11K went off and the power led blinks 11 times.
    It's all dead - in fact I think that it is in a state of protection, when it try to gen high voltage.
    Can you please send me a schematic of this model.You have my email.
    this manual should be
    this manual should be available in the techlores technician corner under the resources tab on the home page.
    phototakinfool
    LARY
    LARY
    I AM POSTING THE SAME QUESTION/PROBLEM AGAIN. PLS DO REPLY. THANKS.
    "My Sony kp-fx432m91 TV red lt blinks 10 time and tv does not switch on. On resetting the elecrical power from main socket,it does switch on but on next start up does same thing.
    D6116 8-719-081-97
    pepsigerry
    I'm still hoping for an
    I'm still hoping for an answer to my question. Can I unplug and remove the G board safely? If I can I can send it out to be repaired. Everyone wants at least $100 just to look at it! Thanks, Gerry
    Claus
    Over a year ago I replaced
    Over a year ago I replaced the two diodes like you recommended and the TV is still going strong. Thank you very much for posting the excellent info! I was lucky that my city has a Sony parts dealer so I found your forum and made the repair on the same day. That SM diode is the smallest thing I've ever soldered. Thanks too for posting the manual.
    Alnp
    pepsigerry said:
    Gerry, what model do you have and what is wrong with the set.
    If ac has been unplugged for a while you can safely pull the chassis to access the boards.
    pepsigerry
    I have a Sony KP-46WT520 with
    I have a Sony KP-46WT520 with the dreaded 10 blinks then 9 blinks. I want to know if I can safely unplug and remove the G board without getting zapped? If I can then I can have it fixed. Thanks for your help, Gerry
    Bobby P
    Hi! I have a Sony KDS
    Hi! I have a Sony KDS-55A2000 and have the dreaded 9 blinks. The info. on this thread is GREAT! I know exactly what to do. I found D6301 but for the life of me, can't find D6116...can anyone tell me where to look exactly on the G board, or at least a diagram of where it is??? PLEASE!
    Thanks, Bobby
    ableswh
    I have a model KD-28HR500
    I have a model KD-28HR500 with the power failure problem and the 9 red blinks code.  I understand about changing the two diaodes on the G board, but since this is a Japenese model TV that operates on a 100 volt transformer, I wanted to make sure that the values of the diaodes qouted in this thread are the same for my set.  It sounds like these components are on the power supply board, so I thought there might be a difference in the values for a 100 volt system vs a 120 volt system.
    I do not have any schematics or service manuals, so I don't have any way to verify this.  The link for service manuals could not provide a manual for my system.
    Wallace
    johnny10
    phototakinfool
    LARY
    LARY
    D6116 8-719-081-97
    pepsigerry
    Claus
