I have a GE 46" big screen TV and recently I experienced these small glitches in the screen, it did this for about 20 minutes and then all of a sudden the TV just shut down and won't power up. Also when I plug it in I can hear a beeping coming from the back.
i have a ge 13gp241 manuf may '98 that does the same thing. I see many complaints re ge tv's on internet. Sounds like a power unit problem? Have you found an answer to your tv problem yet?
Yours is the first response, If I need to replace the power unit do you know how much that might run me?
zenith tv picture is out but still have sound if i turn it on and off it comes on but it takes alot of times to work and then after a while gos back off
My 50 inch Hitachi rear projection has a shakey picture?
I have a 46" Zenith projection tv. Bought in 1995
Just recently it has been pulling in from the sides in an hourglass fashion. Top amd bottome are fine. It is very erractic in doing this. Sometimes staying for 5 minutes, other times staying for as long as 3 day.
any suggestions?
I have a hitachi rear projection tv. The tv is from 1993, never had a problem until now. The tv just shut off and will not go on.
Does anyone know what may be wrong?
Please email
I have a RCA 46" projection TV model P46810LV. Just stopped working and when plugged up it makes a chirrping noise. Any suggestions?
MY 50 INCH HITACHI TV WILL JUST COME ON FOR A MINUTE OR 2 THEN JUST TURNS OFF. THE MENU DOESN'T WORK EITHER. THIS IS ABOUT 8 YEARS OLD. WHAT CAN I DO TO FIX THE PROBLEM IF I CAN BY MYSELF AND HOW MUCH WILL THIS COST.
i have a zenith rear projection , and the picture is blurry. Is there anything i can do to adjust it?
did anyone get an answer to all these questions?
I too have the problem listed below on the same model.
"I have a RCA 46" projection TV model P46810LV. Just stopped working and when plugged up it makes a chirrping noise. Any suggestions?"
was there a response to this?
HELLO,
IM HAVING PROBLEMS WITH MY 1997 RCA BIGSCREEN PTK195BL
IT HAS A BOW AT THE TOP AND BOTTOM. RAINBOW COLORS AROUND THE OBJECTS IN THE PICTURE. CAN ANYONE TELL ME WHAT IT IS THAT NEEDS TO BE REPLACED AND WHERE TO FIND THE PART? IF I NEED TO ADJUST SOMETHING HOW DO I? I WOULD LIKE TO FIX IT MYSELF IM PRETTY GOOD AT FIXING THINGS I JUST NEED A LITTLE HELP FINDING THE PROBLEM AND WHERE TO GET THE PARTS THANKS, SHAGGY
nope i didnt get an answer either
I have A KP-57WS510 SONY TV IT HAS NO PICTURE OR SOUND THE SELF DIAGNOSTIC LIGHT SAYS THAT I HAVE A PROBLEM WITH THE IC406 AUDIO AMP OR PS401 AND 402. CAN I FIX THIS MYSELF AND IF SO HOW CAN I GET THE PARTS I NEED AND CAN YOU TELL ME HOW TO FIX MY TV MYSELF. THANK,S CRAIG
I have A KP-61v80 SONY TV IT HAS NO PICTURE OR SOUND. When the problem started it the tv had a electrical smell. thanks Moman
I have a 43" rear projection Philips HDTV with convergence problems. Any advice?
Hi Everybody!
Did anyone figure this one out, my friend has same problem, it was working fine then they went on vacation(unplugged everything...came home plugged it back in and wala..no turn on...same problem as below , it starts to turn on but turns off right away..thanks for help :-)
i have a thomson rear projection t.v. model 44rw65u, manufactured 2002, some of the coolant has leaked from red c.r.t. coolant chamber, have cleaned leakage with alcohol, all else seems o.k. obviously besides red focus problem.
Where is best place to obtain coolant, to refill chamber.
thanks leebro.
The fact that its making a chirping means the power supply is most likly ok. It probably the horizontal output transistor is shorted. Now the flyback transformer could be the cause of this or the small coil between the horizontal outut transistor Base and the horizontal driver transformer could need to be taken out and the leads scrapped of paint and resoldered or the the HI voltage caps in the horizontal section could be shorted or leaky. Most of the time when these are bad the caps are split or show burning. They are the 1.5kv disc caps Good Luck
My power button is not working properly, It comes on for about two seconds and goes off again. The light is always red when it is turned on. What is the problem? Model #PT810A
RE THOMSON 44RW65U NEEDED SUPPLIER OF C.R.T. COOLANT, THANKS TECHMAN FOR HELP. HOWEVER HAVE CONTACTED WWW.MCMINONE.COM, AND THEY DO NOT SHIP TO THE U.K.
SO IS THERE ANYONE OUT THERE WHO KNOWS OF A U.K. SUPPLIER OF C.R.T. COOLANT.
THANKS LEEBRO.
i have a samsung sp42w5hf rear projection tv, was excellent picture until 3 months ago when i tried to fix the ariel into the tv the ariel socket joined to the tv had fallen inside and we were not able to connect the ariel, The picture was terrible like double vision and the colours were all wrong, i called out an engineer who said that there were 2 seperate thing s wrong with the tv. and that my converger ic needed replacing. and that it was nothing to do with the ariel socket.
I know everything was perfect until this happened, and when i have tried to claim for accidental damage this engineer said it was just wear and tear.
i have tried to get reports from other companies who have said they will do one for me but that although wear and tear is wrong (the tv is only 18 months old) they would not be able to prove that it was accidental.
i contacted the samsung helpline and they tell me that the converger ic does not just go, some thing has to happen to make it break.
just like to know if anyone else has had the same or similar problem and what you did to fix it. i know that both things happened together but how cn i prove it.
thanks for any help
I have a 32 inch RCA tv model # F32632SB in which just recently the screen went black and started making a high pitch sound. I have been advised that it may be the power supply that went bad. looking to see if this is a simple process to fix or should i just trash the TV.
Nope. Its most likly the Hi Voltage/horizontal sweep circuit my friend. These sets are very common to have the Horizontal output transistor short out because of a defective Hi Voltage transformer. This is why the sets making a high pitch sound, as the short is loading down the switch mode power supply. If this TV was mine, I would buy me a new HD model. Sorry to be the caller of bad news. Good Luck
