Mitsubishi WS-65711 not turning on
64 posts / 0 new
glenn357
It blinks so fast you cannot
It blinks so fast you cannot count and there are no pauses, like when it's putting out a code. I think there is a problem in the HV circuit. When the K9A50 relay energizes you can hear a high freq noise then the realy clicks off and the light on the front start blinking. Then after about 15sec the whole thing starts over again, without pressing the "On" button. It's like it's trying to fire up the CRT's, but dosen't. I may be way off base, I don't really know. I'm willing to try anything except replacing every board. It's not worth that.
evil
After it does all that try
After it does all that try holding the menu and device button for 6 seconds on the tv.
glenn357
The code it flashed was 12.
The code it flashed was 12. I let it do this for longer than ususal and noticed the red CRT was lighting up, but nothing from the other 2. Also the time it stays lit is about 3 secs then it cuts off and the timer lamp blinks for about 5 secs and it starts over again. Why would only 1 CRT fire up?
