Hello Larry. My name is Bill & my WS-55513 also suffers from the blinking light problem. It would do it every once in awhile, then always eventually turn on. Now its not working at all. I tried to wing it today & took it apart & replaced the 4 1000uf 16v capacitors inside the metal box on the left of the rear of the tv. I could not find any 1000uf 16v capacitors, but found some 1000uf 35v capacitors. Are these ok to use? Also, is there some fuses in there as well i should check? Please send me the info on replacing the caps so I make sure I dont miss something. [email protected]. Thanks a lot!!
Bill and others
You may have seen on other threads that Larry recomends going to tvrepairkits.com you can get everything you need to do the repair including the High temp 10,000 hour panasonic capacitors. It also includes the service manual that shows you how to get the board out and where the capacitors are. It's only $35.00 the cheapest TV repair you'll ever have. It work for mine and I didn't need to replace the fuses or anything else. Only use the high temp long life capacitors and take your time. Good Luck
bob
Bill
I've seen other posts where Larry said that the 35v will work but he really stresses to use the hightemp(105 degree) long life versions. Also I believe those capacitors are physically bigger in size, so you may have to be creative in getting them to fit into the space.
Bob
Larry. Looks like you have sent the blinking green light instructions 100+ times. Could I impose on you to send them one more time.
Model WS55613.
Thanks in advance. [email protected]
Bill
When I did my repair it didn't work at first either. Larry suggested removing and reseating the DM board. I did and then it worked. Maybe that will work for you.
Larry Dillon said: rob I need an e-mail to send you any info on this repair info.
I have the same green blinking light problem with my Mitsi ws-55613. If you are still on this list and would be willing to send me the instructions, I would be most grateful! My addy... [email protected]. Thanks.
Hi Larry I am also having the blinking green light problem on a 65819. Could you please send the instructions on how to fix. THANKS!!!! [email protected]
55513 Blinking light syndrome. [email protected]
Any assistance on re-set proceedures would be helpful. Thanks in advance. The manual proceedure does not work at all.
Larry:
Bought the repair kit, replaced the caps, tested the fuses(OK) now I don't have a blinking light. I have a click when I turn the set on but the screen does not illuminate. It is as if there is no power but there is.
Any suggestions???
Model WS55613
Walt [email protected]
Larry, can you please help me.
I have a ws-65869 I just changed out the Caps to the 1000uf/ 35v and now I no longer have a blinking light, but a steady light. but no picture. and no sound? the heaters are on the three tubes, but no picture.
I was going to buy the kit, but im a bit strapped & dont want to throw away $35. I already replaced the caps. Is there something else the kit includes besides caps & fuses?
I read how many people had this same blinking green light and was shocked. Now, I have the SAME THING! My WS-73909 has been perfect until now. If you have a way to address this problem, please, please send the info to me.
Hi Larry, I am also having the same problem with my Dad's Mists WS-55513. Can you send me the same information on the fix for the blinking green light. It continues to blink no matter what I try on the troubleshooting. Thanks for your help. My email is [email protected]
suprise - surprise - I am having the same problem with blinking green light on Mitsubishi WS-55513 after a power outage any help would be very appreciated.
MANY THANKS!!!
Hi Larry. It sounds like you are the Mits. wiz. I've got the same green flashing light problem with my WS-55513. Could you please send me the repair instructions also. Thank you. [email protected]
Can't believe I found this site. The power went off this morning and now my tv won't turn on by I too have the blinking green light. I have unplugged it and tried the reset and NOTHING worked it is still blinking. I have a HUGE problem. I am having company this weekend and need my tv. I can not afford to call anyone to come fix it since I am broke. If someone can please please help me with #WS65611 my email is [email protected] Thanks Bev
Okay Mitsubishi sent a tech to my house today and they said I need a new DM board - $500.00 which I can't afford now. He said it is basicly the computer part of the TV?
Okay I have 2 posts above and went back reading other posts. Can my DM Board be fixed or do I really have to pay $500.00 for a new one which I can not afford. If you could please email me I would greatly appreciate it. Thanks Bev email: [email protected]
Hello, I am having the same problem with my WS-55613. The blinking light will not stop, nothing else on the TV will work. I have reset, unplugged, waited and the light keeps flashing. Please send me the repair instructions. Thank you- [email protected]
Bill
Bill and others
bob
i too have this blinking light death wont turn on. what do i do? [email protected] thanks
i too have blinking light of death ws-55513 any body help? [email protected] thanks
same problem blinking light on WS-55513 fix would be greatly appreciated!
Brad
Thanks Bob. This TV is driving me nuts. I'll have to give that a try. So will the 35v capacitors not work then??
Bill
Bob
Model WS55613.
Thanks in advance.
Ive never received them either. [email protected]
Yeah, the 35vs were a bit of a pain to get to fit in the case, but I managed, but still no luck.
Bill
same problem here. [email protected]
THANKS!
Larry:
Any suggestions???
Model WS55613
Walt
thanks
mike
Having problem with blinking green light on Mitsubishi WS-55513 after a power outage any help would be appreciated. [email protected]
blinking green light, t.v. wont turn on. HELP
Thank you!
MANY THANKS!!!
I have the dreaded flashing light. Please email info to [email protected]. Thanks
Larry I have the same problem with the blinking light can u help me please?
Hi Larry;
