1707 posts / 0 new
CAYPIANAN
hey Lsrry how are you? i
hey Lsrry how are you? i wondering if you can send me a copy of the schematic for the mitsubishi wd52525, i have one of this set and another tech replaced the caps but he did not use the same exact values and also some info as how much the DM board cost just in case mine is bad when i fix the power supply i will really appreciated it,i am trying to solve this problem. thanks
miles14
I appreciate your generosity and am in need of taking advantage of it. If you could please forward me copies of your paperwork for this repair, I would be very grateful. My email address is [email protected].
Thank you very much!
Doin12volt
Larry! How have you been
Larry! How have you been doing since the surgery?
My Mitsu wd65513 is still working perfect, but now I need more information from Larry the "mitsubishi man"..
I NOW have a Mitsubishi WD-52525 (52”) that will not complete shutting down when it’s unplugged then replugged. The timer light just flashes all of the time. I used to be able to reset via the reset button but that will not work any longer (the reset button works, but when it’s released, the timer light just goes back to blinking continuously). Also, it’s starting to get some vertical lines on the screen. I have been led to understand this may be a sign of need to clean something in regard to the Light Engine... or does this sound like a DM board repair like on my wd65513? Either way, the TV is totally inoperable at the moment. Appreciate your help
Email is [email protected]
my wife deleted my Pando, so can you include that as well?
Wayne Carter
Hello Larry looks like you
Hello Larry looks like you are the guy to talk to. I am having the same exact problem as the guy just above Doin12volt. Would you also be able to help me I love this TV and am not ready for it to be dead. My email is [email protected] if you could possibly help me it would be greatly appreciated.
Email - [email protected]
ECT
I seem to have the same
I seem to have the same blinking light problem on my WD-52525. It could be the DM capacitor problem. I would appreciate a copy of the schematics as well to see if I can fix the problem and save a service call. Thanks!
lilxrich
larry can you sent me the
larry can you sent me the repair docs for the 52525
thaks masttech at netzero dot com
TIA
wrwelect
Hey Larry, on my 52525 I have
Hey Larry, on my 52525 I have the blinking green timer light that wont shut off, it doesn't seem to power anything up other than that light, My old man is fluent with schematics and all, and im hoping he has the knowhow to test alot of this stuff. so I was hoping I could get some repair manuals and any other useful info from you, My address is [email protected]
Thanks for helping us all!
Ryan
fleur
Hey fellow Blinking lighters.
Hey fellow Blinking lighters. I have not recieved an email back from Larry. I don't think he is on this site any longer. Just wanted to let you all know that I took out all three boards and dropped them off at a local tv repair shop and they are putting in new transistors on all baords whether I needed them or not. I will be putting my Tv back together within two days and pray that it works. The Shop charged me 175.00 for the repairs. Still cheaper than 6 to 8 hundred. I did not want to get involved with sodering. I will let everyone know how I it turns out. Dont junk your tv's yet.
miles14
Thanx for the heads up Trich,
Thanx for the heads up Trich, looking forward to your follow up post.
replace transistors? I hope
replace transistors? I hope you mean Caps, as I heard reently.Mitsubish knows about 100 caps that go bad in this model. wish I had tht list.
Doin12volt
LARRY!! Welcome back!! It
LARRY!! Welcome back!! It looks like your doing a bit better! Did you see my earlier post?
I have been here for the past
I have been here for the past 30 days or so all month. no sory did not see our post.
Doin12volt
Doin12volt said: Larry! How
Doin12volt said: Larry! How have you been doing since the surgery? My Mitsu wd65513 is still working perfect, but now I need more information from Larry the "mitsubishi man".. I NOW have a Mitsubishi WD-52525 (52") that will not complete shutting down when it's unplugged then replugged. The timer light just flashes all of the time. I used to be able to reset via the reset button but that will not work any longer (the reset button works, but when it's released, the timer light just goes back to blinking continuously). Also, it's starting to get some vertical lines on the screen. I have been led to understand this may be a sign of need to clean something in regard to the Light Engine... or does this sound like a DM board repair like on my wd65513? Either way, the TV is totally inoperable at the moment. Appreciate your help Email is [email protected] my wife deleted my Pando, so can you include that as well?
 This was my original post, - you never answered though - hows the noggin doing? seems like your typing a bit better!
Tommie
As I was preparing to leave
As I was preparing to leave for work this morning, the electricity went off then immediately back on again. While making my rounds to fix all the digital clocks in the house, I noticed a green blinking light on the TV (WD-52525). I tried the reset button and cycling power for a minute as described in this forum but neither option helped. After seeing all the references to the lamp, I gave something a try. I pulled off the front face plate (just below the green flashing light and the width of the television). When I put the plate back in place, the green flashing light was gone. The television powered up and I was asked whether or not I had replaced the bulb. I pressed Cancel on the TV remote (for No) and now the television is working as expected.
Hope this might help someone else.
fleur
TO tommie, THis is how the
TO tommie, THis is how the problem starts. eventually the problem will not be easily fixed.
wayne f
I have a wd52525 with the blinking green light. Could you send me the information for replacing the capacitors? [email protected]
Thank you
Wayne
TMitch
Hi Larry. I have a Mitsubishi
Hi Larry. I have a Mitsubishi 55813. I have the green light blinking at the front and the TV wont turn on. Could you send me the manuel on what and how to fix this. Thanks [email protected]
Tommie
To Trich: Thanks for the
To Trich: Thanks for the warning, I'll see if the blinking continues.
As for replacing the bulbs often, I'm still on my first bulb (purchased the tv in Jan. 2005, so I've gotten my money's worth out of that bulb.
suzee
Seems like you are the man to help. I believe I have a bad ballast on my Mit 52527 tv. Do you have the repair manual that will show me how to replace? Also do you know where to buy one on the web.
Many Thanks
Brian
Doin12volt
I know I will probably shoot
I know I will probably shoot myself for this, But I have the WD-52525 (V-26 Chassis) Service manual in PDF form, If anyone needs it..
Is there anywhere where I could simply upload it so it will be an available download?
Upload it to the technicians
Upload it to the technicians corner upload thread.
Doin12volt
DONE!!
DONE!!
Others may find it here as soon as it is approved...
http://www.techlore.com/download/24424/Mitsubishi-WD-52525-v26-v26-v26-c...
Ryo_Ohki2
Wow.. it's almost a full year
Wow.. it's almost a full year since this post was made.
Andynohio
I found this site searching
I found this site searching for the Mitsubishi fix for a set that doesn't respond. It had green lights across it for a few seconds and now it doesn't seem to do anything picture wise. Can you send me the info on how to get to the boards? I don't know who Larry is, but man, you sure are helpful to a lot of folks with the same issue. Andy.
email is [email protected] Thanks!
tony gregori
Larry can you please send me
Larry can you please send me the info. The tv would blind for a minute the stop. I could see the light turn on for a second and hear static through the speakers. After a while it would show
tony gregori
Larry please help. I was get
Larry please help. I was get the green flashing light for about a minute then I could see the bulb light up for a few seconds and the grren light was off. Then the lamp light came on until I reset it.I saw this thread and decided to take it apart. I found the power board and saw two 3300 uf 10v caps with blown tops. So I replaced them. Now the tv will just blink the green light all the time. I doulbe check the joints and fuses and the blue line on the caps going to neg as the oringinal were. Please help [email protected]
[email protected] Thank you so much
tony gregori
Dennis Ramos
Greetings! I have the Mitsubishi WD-52575 and won't turn on anymore. It has the blinking light as well. Can you please send me the repair docs and the service manual for it. It is out of warranty and I want to fix it myself. My email address is [email protected]
Thank you very much.
Dennis
On it's way to you, but this
On it's way to you, but this set is a very unfriendly set for a consumer repair!
joo
my mitsubishi wd 62525 is not
my mitsubishi wd 62525 is not working. keep getting the blinking green timer light. finlly turned on and just checkered screen. i got code 12. how do i check to see if the Capsare bad on the DM board and were is it located at. could some one send me the service manual and instructions to get to the DM board to [email protected]
thanks to anyone that helps
