Mitsubishi ws-55813 Green Light blinking...
557 posts / 0 new
M Hadcock
I have the same problem;
I have the same problem; sound available, no picture, blinking green light.  Repairman coming tomorrow.  Is there anything to prevent same problem in future?  Does this TV "guzzle" electricity?  M Hadcock
M Hadcock, I do not know what
M Hadcock, I do not know what you mean"guzzle electricity". I do not know any set that does that. Maybe I do not understand the question?
RedMonkey
Larry Dillon said: Redmonkey
Larry Dillon said: Redmonkey where you located?
I am near Akron, Ohio.
No, I think northern Michigan
No, I think northern Michigan is too far to deliver. Too bad, but I am getting closer. I have been looking for a used set as mine are all over 10 to 12 years old and on their last legs. Getting to a point of having to do something to them every few months or so.
M Hadcock
My colleague told me that
My colleague told me that this type of TV adds significantly to your utility bill because it is always drawing some electricity so that the picture comes on quickly.
HuskerFan
Think my Mitsubishi WS-55813
Think my Mitsubishi WS-55813 got fried last night by a power surge.  Today all I get is the blinking green light and doing the reset doesn't change it.  Can this be fixed with the instructions you provide?  I'm assuming I need to find someone more technologically inclined than I to do it.  Would a regular repair shop charge an arm and a leg?  We're missing football!!  Surprised  Please send instructions to [email protected].  Thanks in advance!
If you have a friend who can
If you have a friend who can solder, this will for sure save you at least 800 to 1000 bucks on this repair. I will send you the repair Info a little later this evening. Good Luck with the repair of your TV set.
Richie
Did repair over the weekend
Did repair over the weekend and everything worked great.  Was not bad at all thanks to the info provided from Larry.  Thanks alot for the help Larry!!!!   I also have questions about a Hitachi model 57S500 if you have experience with that model?
Thanks Richie
DKDigger
I have the similar problem of
I have the similar problem of the blinking green light of death I have read about so much here. Could you send me the picture instructions so I can take a look at the DM board and compare.
Thanks for your help.
Eric
CFEcindy
We have all supplies needed,
We have all supplies needed, and have the tv apart, and the board ready to desolder. The new capasitors have these two wires coming out one side...are we to cut this off? thanks
Mark Lyman
Larry, I am another in what
Larry, I am another in what must be a long line of Mitsubishi WS-55813 owners with the green blinking lite problem. The set was working last night; today only an endless blinking light. Unplugged from the wall, reconnected, didnt help.  If you have a repair solution, I'd love to see it. You can send it to [email protected] with my deep appreciation. If the instructions are on your site, you can just point me to them.
Thanks again
Mark
CFEcindy
Hello Larry,
Hello Larry,
I pleased to say that our TV is now working again !!! Thank you sooooooooo much for your help and information. We appreciate this so very much. We were not going to be able to replace the TV if it couldn't be fixed, and could not afford to have it fixed, so your help was truly appreciated. You are doing such a wonderful thing helping all of us to give this a try and do something new.
God bless you :-)
Cindy
Great news CFEcindy! Alsways
Great news CFEcindy! Alsways glad to help.
Mark, I am sending out the
Mark, I am sending out the repair documents as well as the factory service manual as we speak. Good Luck with the repair.
DKDigger
Well I removed the DM board,
Well I removed the DM board, the capacitors were buldged.  I changed them, res-assembled everything and plugged the TV in.  I still have the blinking light.
 Larry - you had a list of other things to check.  Do you have a copy of that still you can send me so I can check  for other potential problems.  Please send to [email protected]  Thanks.
DK, Triple check where the DM
DK, Triple check where the DM plugs into the main board. I cannot count how many times folks think the board is seated correctly into the bottom board and it turns out it was not inserted correctly. I have been told by several that they had to take off the metal case and insert the board and then install the metal casing. So like I said unplug the set, take off the case, insert the board properly, plug the set in to see if it will work. If the light goes out after 60 to 90 seconds, turn on the TV set. If it works, UNPLUG the TV set before installing the metal case. Do not use the set for any period of time without the casing attached.
hawkman
Larry, I see alot of problems
Larry, I see alot of problems with the ws 55813 blinking light, I've changed the power supply and when the set was plugged in all I got was the dreaded blinking light that won't go off.  Could you send me the instructions or any advise that would help get some of my life back....
hawkman
Hey Larry, I forgot to give u
Hey Larry, I forgot to give u my e-mail address, send help to [email protected]
hawkman, I sent out the
hawkman, I sent out the information for you. Good Luck with this repair.
DKDigger
Larry:  I took your advice,
Larry:  I took your advice, removed everything, and re-inserted the DM board without the cover, hooked it all up and it worked.  I then re-assembled the the cover in place.  Thanks a million for the help.  Nice to have this unit running again.
DK
hawkman
Larry,  Thanks for the
Larry,  Thanks for the instructions, I noticed that the manual that you sent me was for different models than my own 55813, it appears to be for the 513 models.  Will this manual work for me also..                            hawkman
hawkman
Hey Larry, disregard my last
Hey Larry, disregard my last statement, I had a huge brain fart, I got it                                                   hawkman
hawkman, no problem. It
hawkman, no problem. It happens to the best of us.
DK, great news!
Johnny
And of course it's football
And of course it's football day!  I've been attacked by the blinking green light monster.  Have a Mitsubishi WS 55513 if it matters.  Can you please send me the instructions to fix.  My thanks in advance.  [email protected].
Sure man, no problem. We are
Sure man, no problem. We are here to try and save you at least 800 to 1000 bucks with this repair! They will be in your mailbox in a short time. Good Luck.
M Hadcock
Can you send me instructions
Can you send me instructions how to fix the blinking green light problem?  Thanks, M Hadcock
jms-needhelp
WOW, Is it me or does it seem
WOW, Is it me or does it seem as though there are a mess of these problems in pretty much the same time frame?!?!
BTW, I too came home after shift to my boys letting me know of the 'blinkin' blinking light!  I'm thinking that there is a problem with this particular module as I had mine on a UPS filtering the power therefore taking the spikes out so that it was much cleaner getting to the set.  Faulty parts, faulty module, bad design?!?!
Larry, it would be greatly appreciated if you could add me to the list that is in need of the repair and manual, mine is the WS-55813.  Thanks in advance,
M. Hadcock and KZXten, I have
M. Hadcock and KZXten, I have added you to the list of recipients for the repair documents. Good Luck
TMuhammad
Hey Larry. Of course my
Hey Larry. Of course my Television is having the green light of death.Ours is also a Mitsubishi WS-55813. Me and my dad are looking at the DM module and trying to get it out. The screws are all out but it won't slide out can you please send me the complete directions before we break something. My email is [email protected]. Thanks in advance.
I does NOT slide out, I will
I does NOT slide out, I will send you out the documents and the service manual. Good Luck.
