Purchase the kit/kits from the site Larry posted. I did and set has been working ever since. Mine ended up being the convergence repair, but I bought both just in case. Good luck.
Hi I have Mitsubshi WD-65733 DLP, I was having problems with my cable, I was getting sound with no picture. I fixed the problem it was a loose cord, however right after the TV powered off for no reason, now I dont get anything. No green blinking lights or solid lights....Not sure what happened, tried to reset system but nothing happened, unplugged for six hours an still nothing. Any ideas?????
I have the WS-55511. The set turns on for a few seconds, then shuts off. I have 12V at pin 3 on PC9A21, no open fuses, and C9A60 does not appear leaky. Where do I go from here?
I had a continous blinking green light and the tv wouldn't turn on off or reset.
Remedy:
I have just had my ws55511 repaired by a tech. He found 6 out of 7 capacitors bad.
He replaced all of them and the t.v. now works great.
No more continous blinking light that I couldn't resolve.
Another cause for a continous blinking light:
would be that the coolant liquid in the guns leaks onto a circut board thereby making a repair impossible as the parts from Mitsubishi are no longer available.
P.S. Pardon my spelling
I have the WS 55511 where the green light keeps blinking and the TV will not turn on. Can you please send me the manual? thanks!
cjackson,
Did you ever get your set fixed? I'm having the same problem and wondered if it was easy or worth fixing.
Thanks.
Danny-
Remedy:
