tv troubleshooting
How can I fix my tv? When the power switch is touch it make a sound, but after it is powered up, there are no picture or sound.
dale haus
dale haus's picture
my 65"hitachi projection
my 65"hitachi projection makes a rapid snapping/cracking sounnd then shuts off and comes back on again.Also when it does this it makes a hissing sound. Any suggestions as to the problem
Larry Dillon's picture
You have a high voltage
You have a high voltage transformer or the high voltage distribution block is bad. If you have no TV repair experience, or know the safety facts about high voltage in a TV set, you really should play it safe and call in a pro to assist you in this repair. This set has enough high voltage inside it to kill you. Not worth  that to save a few bucks. Good Luck
Savannah
Savannah's picture
I have a Mitsubishi CK-3514R
I have a Mitsubishi CK-3514R which suddenly has no sound.  Does anyone know what I can do to fix this?
Yes, if you have no TV repair
Yes, if you have no TV repair experience, call in a pro. You probably have a mad capacitor in the sweep power supply causing this problem. Not a repair I'm afraid fro a novice. Good Luck
marilynclaire
marilynclaire's picture
Larry Dillon said: I would
Larry Dillon said: I would write Best Buys customer service department and complain that they are selling sets that by law, they are suppose to support for three years or replace the TV set. Do not let them fool you. if this does not get you anywhere, call the State Attorneys off and file a complaint. You will get an answer from best buy. they will all of a suddenly come up with a board for your set, or a new TV set. Good Luck.
Thanks so much for your reply and suggestion.  I am currently reseaching to find the law that you refer to.  The latest from Best Buy is "we are not responsible if the manufacturer is no longer making the parts."  I am also researching to see who the manufacturer is, as so far, they have been unable to tell me.  I now have the number of the part, which unfortunately is for the main board, as they do not replace individual parts only complete boards.  They still are unable to tell me how to find it, or how to find service for the tv.  Will keep you posted on my progress.  Thanks again.
vinnie97220
vinnie97220's picture
   I have a older Magnavox 52
   I have a older Magnavox 52" projection tv Model # RL8564 AK04. It was manufactured in 1991. I really love this tv, but a problem has arrisen. The picture is dark, and no matter what I do with the settings, I can't get it to lighten up. lso, the picture has a red tint and the whites are sort of luminescent. It's to big and heavy to take to a shop, and I've found only one person who will come to the house, and he charges $75. an hour...Any suggestions? Thanks
You will need new picture
You will need new picture tubes I'm afaraid. These will noit be cheap to replace. The set is not worth puting that much money into it. Good Luck
442
442's picture
My ws-55807 went totally
My ws-55807 went totally "blue" yesterday. When I went to menu the words were
different colors and 3-d like. My convergence would not respond?? Could not enter advanced convergence, the tv said press info? All that did was explain how to configure....
Sounds like you need to first
Sounds like you need to first replace the convergence IC's an then trouble shoot the voltages in the power supplies as it sounds like the convergence IC's might have blow a circuit protector or two.  Most of the time when a convergence amp shorts out on a Mitsubishi TV set, it will blow out a small device that acts as a fuse in the output of the power supply called a circuit protectors or some people call then pico fuses. Good Luck
burick
burick's picture
Mitsubishi WS-65513
Chassis: V23
Thanks for the service manual. I replaced the four DM capacitors in my tv, without any improvement.
I decided to pull out the main chassis and found one of the convergence amplifiers to be leaking what appears to be oil; also there wasn't any heatsink paste between the convergence amplifer and the heatsink.
My questions are should both convergence amplifiers be replaced, could this be causing wavy lines on the screen, and the tv to loose video.
Convergence amplifier (1)  Ref: IC8C01; Part #: HIC - STK394-250
Convergence amplifier (2) Ref: IC8C02; Part #: HIC - STK394-250
burick
No your problem is the
No your problem is the convergence IC's and then you will need to repair the bad seal on the leaking picture tube. That oil is coolant from a leaky picture tube.
Frank Marshall
Frank Marshall's picture
My Symphonic TV comes on for
My Symphonic TV comes on for about 1 second and then turns itself off. But if I keep pressing the on button a flash comes to the screen. Is there a shortage in the plug or do I need to buy another TV?
Frank, you probably have
Frank, you probably have whats called a bad regulator IC. It really is not an expensive part but the labor to replace it will cost you most likely more then the set is worth. if the set is more then a few years old, yes buy a new TV set. Good Luck
bruceclem
bruceclem's picture
sisterlysounds said: i am
sisterlysounds said: i am having a problem with my rca television. I have no sound. I have called a tech in the past, but they say they only reset it and wouldn't show me how. I tried unplugging it waiting a while and turning it back on, but nothing seems to work.
bruceclem, I do not
bruceclem, I do not understand your question. Can you be a little more specific?
NCF
NCF's picture
Hi there Larry,
Hi there Larry,
   I'm a new member, and I've been having some trouble with my Mitsubishi WS-55807. I noticed that you seem to be pretty smart with the solutions to everyones problems so I thought I'd ask you about my set. My in-laws have this this 55807 that they were gonna throw out. They said I could keep it if I can fix it. Apparently out of no where, the tv just turned off. After having it unplugged a couple days it would turn on for a few minutes then turn back off. If you tried to turn it on again it would power off immediately. I noticed that if the tv remained plugged in, after it turned itself off, it would start clicking inside real loud like machinegun fire nonstop until you unplugged it. So I have no idea what to do about fixing it. I checked the caps, and the fuses and they seem to be fine. Any help would be greatly appreciated. Thanks!
Take off the back and see if
Take off the back and see if you can see where the machine gun sound is coming from. Is it a high voltage arching?
ziggy1
ziggy1's picture
tiggerpi said: My mom has a
tiggerpi said: My mom has a 1995 RCA t.v. Model#P52731WK. The elec. co. updated the meter. The t.v. was on when they did this. The power went off when they took the old meter out and came back on when they put the new meter in. This was in a matter of a couple of minutes. When the power came back on the t.v. made a loud popping noise and nothing else. The elec. co. employee came inside and unplugged the t.v. and waited a minute and replugged it. Nothing happened. Checked the breaker and it was fine. The outlet that the t.v. was plugged into is fine. Push the power button and nothing happens. It is as if it is not plugged into an outlet. Is there a reset switch? If so, instructions on how to do this? Or will this even help? If not what is wrong? The t.v. had no previous problems and has worked fine until this happened. I think there was a power surge when this happened, but no way to prove it and mom has no finances to pay a repairman because my dad passed away within a few days of this happening. The elec. co. says they are not liable. Go figure?? I need any assistance in what the problem is and an easy fix if there is one or the knowledge to prove the elec. co. is resonsible for this problem. Please help.
ziggy1
ziggy1's picture
hi you need a new control
hi you need a new control panel call 1888237-8289 and give them the paryt number and it costs you $37.18 replace it your self very easy i had the same problem
NCF
NCF's picture
Larry Dillon said: Take off
Larry Dillon said: Take off the back and see if you can see where the machine gun sound is coming from. Is it a high voltage arching?
not sure exactly what it is but it seems to be coming from the main power board. I want to say its a solenoid. Its a very loud clack. Like that click sound a tv makes when you turn it on.. but non-stop and really fast, like its trying to turn on over and over and over. Speakers make popping sounds too like power is being put into them, then removed over and over as well.
Carmen Cercone
Carmen Cercone's picture
Hi; new member and of course
Hi; new member and of course having a problem with Panasonic widescreen TV. When we turn it on, the light blinks green and when we turn it off it blinks red. I have unplugged it and still no reset, no sound, no picture, nothing. Just over the last week we were getting a replace lamp message but when we turned it on/off it would be fine. Any suggestions would be appreciated.
thanks
Replace the lamp man. First
Replace the lamp man. First thing you want to do.
jd5449
jd5449's picture
warpete said: I have a two
warpete said: I have a two year old Panasonic CT-32HC43 HDTV. One minute it was fine and the next time I turned it on it would not power up at all. My wall recepticle is fine--everything else works, just the TV is completely dead. The remote won't turn it on and the main power button will not either. What could have happened and what can I do? Any help will be greatly appreciated!
If you are ok with opening the back and know how use a Dvom ck the fuses for open
jd5449
jd5449's picture
hey larry will the tubes out
hey larry will the tubes out of a kp-53hs10 work in a kp-51hw40 just the red tube is bad in the tv
Nope, you cannot. The CRT MAY
Nope, you cannot. The CRT MAY, I am not really sure, but the optics on the lens and the mounts may be different. They use totally different tubes and part number. You can go to partstore.com just like I did, insert the model number then for the part you need enter CRT. It will bring up the different part numbers for each color tube for each model.
jd5449
jd5449's picture
Thanks larry was just tring
Thanks larry was just tring to get some of my projects out and learn more so far i have been able to repair about 12 tv's but still learning someday i will be as good as you or close to it
Thanks man. I have 39 years
Thanks man. I have 39 years of practical experience with this stuff.
akit65
akit65's picture
Salute to all the genus
Salute to all the genus trooble shooters: I have a samsung 56" flat sreen TV
I got not sound and i got no picture. but there is pilot lamp or power indicator ( LED )
what would you recommend that i should do?
please help
akit65
akit65's picture
please help
