tv troubleshooting
How can I fix my tv? When the power switch is touch it make a sound, but after it is powered up, there are no picture or sound.
karla
karla's picture
I have a RCA tv less than a
I have a RCA tv less than a yar old. I went to turn it on and only the red power button comes on, nothing else. No sound, no picture. What could be wrong? I tried different outlets and still same thing.
Justuc
Justuc's picture
I have a 2005 model 27V412T
I have a 2005 model 27V412T it is an RCA and when i plug it in it goes on and off continuously. I have to then unplug it to turn it off. But the minute I plug it in it starts over again on and off on and off over and over what the heck is wrong with this thing. I let it sit for 2 weeks plugged it in and it worked fine for a week and then all of a sudden went off and started doing this thing again. Any help would be appreciated.
Larry Dillon's picture
check all the buttons on the
check all the buttons on the front panel and make asure non are sticking and they all feel the same when you press them
janso
janso's picture
my TV is goldstar,the problem
my TV is goldstar,the problem is the sound is ok but the picture is scattered...
jjhayden187
jjhayden187's picture
I have an RCA P52731WK that
I have an RCA P52731WK that keeps blowing fuses everytime it is plugged in.I have replaced the fuses and to no avail, they just keep blowing.Is this an expensive fix?, and is it even worth the repair?
David e
David e's picture
I have a RCA mod# J25435 and
I have a RCA mod# J25435 and I'm unable to get the X-box to work on it. Whats the problem????
David e
David e's picture
I have an RCA Mod# J25435 TV
I have an RCA Mod# J25435 TV and I'm unable to get our X-box to work through it. Wtas the problem???
Traci
Traci's picture
i have a mitsubishi HDTV 1080
i have a mitsubishi HDTV 1080 and the screen is so ditorted, it seems to sink to the center and it is all purple and green....Whats the deal?? Can u help???
Thank you
Traci
need a model as well as an e
need a model as well as an e-mail address
RTW13
RTW13's picture
RCA 35v432t
RCA 35v432t
Picture went black. Turned set off and it wouldn't turn back on. It just clicked a few times. Dusted the inside as per this tip (http://www.fixya.com/support/t1086734-rca_35_no_picture_clicking_zapping) and now it just buzzes kind of like high power electrical lines when plugged in and still won't turn on. The power button has no effect - it's as if the TV is unplugged.
If the unit try's to turn on
If the unit try's to turn on three times and then stops could be one of two problems there is a small coil between the output of the horizontal driver transformer and the base of the horizontal output transistor has bad connections. If you only re solder it the problem WILL reoccur! You need to remove the coil and scrape off both sides and reinsert into the circuit OR the fly back transformer is bad. and I am told that is no longer available!
RTW13
RTW13's picture
RCA 35v432t
RCA 35v432t
The local shop says it needs a new power supply at a cost of $195 + 9.5% state sales tax.
Any comments/suggestions? Should I spend $214 on a 4 year old CRT TV or invest in a LCD?
NAZ
NAZ's picture
Larry... you seem to be the
Larry... you seem to be the man with the Mitsubishi big screens. I have an issue that is just developing and am hoping you might be able to point me in the right direction.
Long story short, I have the Mitsubishi WD-73827 73 in. HDTV DLP TV... and it's been a beautiful picture up until just recently. Now, the picture is extreamly saturated, and the colors don't blend smoothly, but more in segments... almost as if the tv was not able to produce as many colors.
Any advice would be very much appreciated, sir.
Thanks, and my best.
NAZ
I personally would not invest
I personally would not invest that kind of cash into a dinosaur like that RCA set
Just my opinion!!!!! what does everyone else think or have to say about this matter?
Butchdunn
Butchdunn's picture
I'm changing the STK ic chips
I'm changing the STK ic chips and I can't find any bad fuses.
Is it possable for an ic chip to go bad and not blow any fuses ?
I checked all 7 Pico fuses on my D board and 2 on the G board with an ohm meter, all good
highly unlikely man but does
highly unlikely man but does happen all the time but if the set all of a suddenly goes out of convergence alignment but the picos all check good, a bad chip, resistor, or coil on the G or/D and the D board are bad as most chips do have three amps built in to them. some have all six in them. always measure the negitive and the positive voltasge on both sides of the coils and resistors unless measuring resistance , then always test those with one side disconnected from the board that includes the d and the g boards, if that is the case do not try to adjust the or touch up the convergence in the manual mode as it could make the TV set harder to adjust and or set-up when the set is repaired.
jonjon
jonjon's picture
I need help with my kv-xbr36
I need help with my kv-xbr36-800 sony tv. standby is blinking 6 times. anyone knows an honest repairman in chula vista, ca. Is it worth it to fix this tv? how much do you guys think i will spend to fix it?
that model of tv was very
that model of tv was very expensive!!!! Your best bet is to call Sony and ask for the nearest authorized Sony repair station in your area, then call the local BBB and see what type if any complaints were filed against that repair station. You might get one that operates above board.
AdyB
AdyB's picture
Hi, have a Sony KE42TS2E 42"
Hi, have a Sony KE42TS2E 42" plasma with a 4 blink code. Can anyone give me any pointers as to what the fault is? Many thanks in advance.
Standby/Sleep Light
Standby/Sleep Light
The front panel Standby LED blinks to indicate a fault. Refer to Figure 2-1. If the TV does not start up, the
LED continually blinks to indicate a problem.
Standby/sleep
light
TV
Figure 2-1
If the TV starts and shuts down, the LED will repeatedly blink to indicate the reason for shutdown or A/V muting.
Table 2-1 shows the boards that can cause the Standby LED to blink continuously and Table 2-2 shows the
boards that cause shutdown.
Table 2–1 - Causes of Continuously Blinking LED – No TV A/V (black screen)
Cause Suspect Board
EEPROM ID check error B board
EEPROM read /write error B board
Color Decoder IC error B board
Panel will not initialize (start) Plasma panel
Low B+ at start up Plasma panel, power supply board
Table 2-2 - Cause of Standby LED Blinking in a Pattern - TV Shutdown
Times Standby
LED blinks
Cause Suspected board
2 times Plasma panel error Plasma panel
3 times Internal TV temperature at critical Q board, Fan, or possibly B board
4 times Digital 5Vdc output voltage excessive or
too low.
Power Supply Output CN1/pin 9 / 10
B board is the load - CN101.
5 times Digital 3.3Vdc output voltage excessive or
too low.
Power Supply Output CN1/pin 5 / 6
6 times Analog 6Vdc output voltage excessive or
too low.
Power Supply Output CN1/pin 13 / 14
the boards that could cause the symptoms listed. The most likely board is designated #1,
second likely #2, etc. Two #1 means both boards have an equal probability. To resolve the conflict, testing is
performed in the Standby/Power ON, Fan Drive, Video Flow circuit descriptions (Chapters 10-12) or the Plasma
Panel picture defects (Chapter 4).
For isolation purposes, the TU (tuner board) may be unplugged and the TV will work, displaying video inputs.
Table 3-1 - Plasma TV model KZ-32TS1U / KZ42TS1U Board Selection by Defect
Probable Circuit Board Failure
Symptom B* H1 Power
Supply**
Q TU Plasma
Panel
Audio Problem – all inputs 2 1
Audio Problem – TV channels (deselect SAP) 2 1
Dark Screen – sound OK 1 2 1
Dark Picture – sound OK (deselect Power Save
on the remote)
1 1
Dead Set - No relay click at plug in 2 1 3
Dead Set – Stby light OFF. No response to
front panel pwr button. Plug-in relay click
heard.
3 2 1 4
Dead Set – Except for Stby light ON. No
response to pwr button. Plug-in relay click
heard.
2 1 3
Fan not cooling (front panel Standby indicator
blinking.) See the TV menu and Fan block
diagram in Section 7. Fan NG = No voltage to
fan. Temp NG = Fan not working.
3 2 1
Noise Bars across the screen (horizontal) The rear metal shield must contact the conductive mesh
on all four sides and be screwed to the center TV board
assembly.
Standby Indicator blinking 2 times 2 1
Standby Indicator blinking 3 times 3 (2 = fan) 1
Standby Indicator blinking 4, 5 or 6 times 2 1
Video Distortion – With composite and S video
input only.
2 1
Video Distortion – With component (Y, R-Y, BY)
input only.
2 1
Video Distortion – With both composite and
component inputs. Try using the menu’s
“picture inversion” to “clean” the screen first.
1 2 3
Symptom B * H1 Power
Supply
Q TU Plasma
Panel
*After B board replacement, adjustments for brightness and color balance are necessary. See Adjustments.
**The entire power supply board is listed in the service manual as “Switching Regulator”. The 32” and 42”
TV sets do not use the same Switching Regulator power supply and therefore have different part numbers.
Thi above thread is taken
Thi above thread is taken from the Sony plasma training manual
AdyB
AdyB's picture
Hi, many thanks! Had to
Hi, many thanks! Had to change both ysus and 'b' boards to cure in the end. Lucky I found another with a broken screen. Thanks again.
hope we helped you out as
hope we helped you out as plasma TV repairs can be very costly!!!!!!
Larry D
yo momma
yo momma's picture
my tv just shut down and now
my tv just shut down and now it just shows colored stricks in tha monitor when i turn it on. what causes that?
tbf
tbf's picture
I have a 52 inch RCA tv. When
I have a 52 inch RCA tv. When you turn power button on it blinks about 3 times then a little black box in back starts sparking. Has no pic or sound while doing this. Model# D52W198. Any help would be appreciated..Thanks.
rooster970
rooster970's picture
My Mitsubishi VS-50VF1
My Mitsubishi VS-50VF1 Projection TV has a distortion problem when it is on BUT my problem now is that it will not start or turn on by remote or on/off button on television. Is there an easy way for me to trouble-shoot and fix this amazing TV by myself?
nizaminst
nizaminst's picture
I have a panasonic tc-21ks30
I have a panasonic tc-21ks30 that has an intermittant problem. Typically, once I turn it on, it will play normally for 3-4 hours, then power back off. Doing this a few times in a row, it will eventually stay on indefinitely. However, sometimes it does not come on at all. please help me to solved this problem
nizaminst
nizaminst's picture
this does not sound like an
this does not sound like an American model?
Larry D
is this set what I ask before
is this set what I ask before? about the model??
