computer
6 posts / 0 new
eric vista
eric vista's picture
computer
HI
MY SONS COMPUTER IS A AO.H34OD.OF1 AS THE NAME OF THE COMPUTER IS RUBED OFF
THE CASE.
NOW HE CAN NOT USE IT ANYMORE AS HE HAS FORGOT THE PASSWORD THE SOFT
WARE IS 2000 PROFESSIONAL AND TO ACCESS THE PASWORD YOU HAVE TO PRESS
CTRL,ALD,DELETE THEN IT COMES UP PASSWORD REQUIRED
THE PROBLEM IS HOW WILL I BE ABLE TO CHANGE THE PASSWORD AND WHAT WOULD I HAVE TO DO
ERIC VISTA
K_I_W_I
K_I_W_I's picture
Are you talking about the
Are you talking about the Amdin login and password window that comes up before it boots to windows ?
K_I_W_I
K_I_W_I's picture
Ok so this is what you do.
Turn your computer on.
Hold down the F8 key while it is trying to boot up.
you will be taken to a menu list on how to boot your computer up.
boot up in SAFE MODE
now it will take you to login window again but you do not have to put in password.
Click NEXT
windows xp will start up.
go into control panel
go into user accounts.
select the Admin name and then you can change password or turn password protected off.
once that is done you can then reboot windows into normal mode and type in the new password you created. or if you turned password protection to OFF then windows will boot up with no login details needed.
I hope this helps you.
Jason
eric vista
HI
HI
JASON (K I K I)
THANK YOU FOR LETTING ME KNOW HOW TO SOLVE THE PROBLEM
MY SON HAS TAKEN THE COMPUTER HOME AND WHEN HE COMES BACK HE WILL BRING BACK THE COMPUTER.
YOU ARE WRITE ABOUT THE ADMIN LOGIN AND PASSWORD AS WINDOWS COMES UP THEN ADMIN
LOGIN
I WILL LET YOU KNOW
ERIC VISTA
eric vista
HI
HI
JASON
K.I.W.I
I TRYED IT AND WHEN AFTER PRESSING F8 THE SAFE MODE CAME UP
I ENTER THEN NO LOG IN WINDOW CAME UP INSTEAD IT CAME UP 2000
PROFESSIONAL ENTER THEN MULTI DISK FILLS THE SCREEN THEN COMES
BACK TO CTRL, ALT, DELETE,AND THE LOGIN WINDOW COMES UP STILL
REQUIRED PASSWORD
ERIC VISTA
photo recovery
photo recovery's picture
Hi Eric Firstly try the above
Hi Eric Firstly try the above solution if that solution doesn’t work properly then try reinstall the windows files may be that will bypass your windows admin password if your command prompt is working through safe mode then At a command prompt, type "control userpasswords2" and press Enter to open the Windows 2000-style User Accounts application. On the Users tab, clear the Users Must Enter a User Name and Password to Use This Computer check box and then click OK. In the Automatically Log On dialog box that appears, type the user name and password for the account you want to be logged on each time you start your computer. At last I am suggesting you one website try to find out the software that will solve your problems.
data recovery services
http://www.datadoctor.biz
