This is a mid 90's projection with chassis PTV620 ? Chassis number may be on back label. I don't see a manual in the download section.
You can read some of the articles on tv safety then unplug the tv and pull the main boards and look for burnt components or bad solder joints or leaks from the crt's onto the boards.
You might turn up some info by searching the web for PTV620. These tips are places to check:
PHILIPS PTV620 HIGH VOLTAGE ARCING AND THEN DEAD SET CHECK/REPLACE R934 AND Q906 - ALSO CHECK FOR LACK OF RTV CEMENT ON ANODE LEADS WHERE CONNECTED TO THE CRT'S
PHILIPS PTV620 DEAD SET CHECK/REPLACE T900 (PINS #3 & #4 SHORTED TO COLD GROUND)
PHILIPS PTV620 DEAD SET CHECK/REPLACE R416 (P/N# 483511657064) AND Q402
MAGNAVOX FP4630 PTV620 PICTURE IS FINE BUT NO SOUND - DOES HAVE A HISS IN SPEAKERS THAT CAN BE CONTROLLED WITH THE VOLUME CONTROL CHECK/REPLACE IC200 (P/N# 483520988019)
