mitsubishi ws48313 diagnostic code21
5 posts / 0 new
thomas6857
tv will not turn ran diagnostic showed code 21 what could be the cause of this problemand how can it b repaired
The 21 code is an indication
The 21 code is an indication that the set is shutting down because of excessive High Voltage. The 21 code is an X-Ray protect mode. Could be a power supply problem, a horizontal sweep problem, a sweep power supply problem, or maybe a problem in the X-Ray Protect mode itself. Some troubleshooting with a multimeter, ESR meter, and the service manual would be the way to go now. If you have no printed circuit board repair experience or any circuit flow troubleshooting, play it safe and call in a tech to assist you in this repair. Good Luck
Gremlini
Ok same problem, I have WS
Ok same problem, I have WS-48313 and she just stop work, I am getting 2 - 2 = Short protect code...
Just remove main board and all pico-fuses are ok, two resistors are burned, but bad...
R5K01 and R5K04, I have extra set of STK394-25 adn TDA on power board, but I have no idea about a value of this two resistos.
Can somebody help, and did I need to exchange anything else
Alex
It would be a little nicer to
It would be a little nicer to ask for help in this problem instead of acting like your owed the answers?. Man you seem a little tense. Ask nicely and maybe you will get some help man. We do not get paid here to look up information for you, as you could simply buy a service manual and look up this info. Ask like a nice questions man!
Gremlini
Huh, yeah I am participating
Huh, yeah I am participating on allexperts and trying to help people out, soory didn't want to ofend you , just looking for advice and help.And yes Iam asking for help, dont know how I can ask to not ofend you...
Just need your advice and some tips and tricks...
 Sorry If I didn't use correct words for this question, but if you can help me I be more than happy to revard you and help you out with any of my experiences
Aljosa
