I have a 55" Mitsi TV with the flashing light problem. It flashes about 50 times, and if I am right there and repush the power button it will come on. The remote quit working too. I have been fighting this for a long time. The company I bought the extended warranty through went out of business. Can someone send me the instruction on the cap repair to see if I can get this fixed? Thanks
What is the model number of this TV set?
It is a ws-55513 and it says it was made in April of 2004
i will send out the repair instructions if I knew where to send them too!?
larry could you send me the instructions for fixing this problem too. i have a
Mitsubishi WS-65869
thanks alot
adam
Adam, to where? LOL I am not a mind reader man! LOL
Larry I have Mitsubitshi wd62825 with the same flasng green problem. I would appreciate those instructions. Thanks. jkenney
Larry I have Mitsubitshi wd62825 with the same flashing green problem. I would appreciate those instructions. Thanks. jkenney
Where would you all like them sent to. I need an e-mail address!
Thanks Larry. Please send to [email protected]
Thanks Larry: Could you resend to [email protected]. Thanks. jk
Already sent them man. Yesterday, three times.
If you could send them to [email protected] I would appreciate it. Thanks for your help.
Larry, I have a WS 55859 that is about 6 years old and have the "blinking green light" after a recent power failure. I have a "whole house surge protetor" supplied by the electric company and a 50000 joul surge protector on the power plug but apparently it made no difference.
I have contatcted Mitsubishi on the issue and am waiting for a reply from their customer service dept. Apparently you have some "fix it" instructions for the DM board from what I am reading in the forum. I would very much like to have those instructions sent to me and what ever you may have that will aid me in fixing this problem. <[email protected]>
Thanks Much
K Goodnight
cleg and krgood, I will send out the repair info to each of you ASAP. Good Luck
I have the same model and the same problem. TV is on a APC battery backup. A minor power flucuation - and now the continuous "Blinking Green Light"
Would you so kind as to send the "FIX" instructions to [email protected] ??
TIA,
Lew
Larry
I also have a WS55859 with the continuous green blinking timer light. Could you send me the repair instructions as well. I would appreciate it. [email protected]
Thx
Dwayne
Lew, what model? There are many mentioned here.
Dwayne, they are on their way. Good Luck
I have a WS 55859 Mitsubishi tv. It has a blinking green light. The tv repairman put a DM board in and said I needed a signal processing board. He took out the DM board and told me to get a new tv. How can I fix these problems? I would appreciate any help you could give me.
I have a Mits WD-62825 with the blinking green light problem experienced after a power failure.
Would you be so king as to email the fix instructions to me at [email protected]?
Thanks in advance.
JPB
Thanks in advance.
JPB
Larry, seems I have the same problem as many others...the flashing green light!! I have a Mitsubishi WD62825. Would you be so kind as to email the fix instructions to me at
Thanks in advance for your assistance in helping me fix this problem.
Karl
Larry, I have a Mitsubishi wd6825 2004 and I am having the same problem with the blinking gren light. Can you email me at [email protected], the instructions to fix this problem? Thank you in advance!
Larry, I also have the never ending green blinking light on a WS-55513. Could I get those repair instructions to and could you tell me where to get the parts also?
Thank you, and please send to: [email protected]
Thanks for your fast response. I now wish I had found this Forum before I paid $17 for the manual at ServiceManuals.net. Oh well! Still a cheap fix if it works.
Will let you know.
You seemed to be the man in all this...Long story short...BJORNS...want about 750 big ones to "supposely" fix my WD-52525. The problem is I don't have faith in the whole process...I am an amateur PC technician myself, so you know about when you get the funny feeling.
They are blaming the powersuppy and a bunch of other stuff that to me further makes them sound/look clueless. No disrespect.
Please send me anything you got on my Mit WD-52525. YOU ARE AWESOME FOR BEING SO HELFUL TO ALL OF US.
GODSPEED!
ALEX
Mr. Dillon
I have been playing lucky or unlucky with my Mitsubishi WS-55513. Of course the wonderfully humorous blinking green light. I would greatly appreate the instructions on how to fix this problem if you wouldnt mind. My wife would be even more appreative. Thank you very much!!! Do the instructions come with a service manual or is this not needed?
E-mail [email protected]
I am sending everything to you. Good Luck
The 4 caps worked for me,fuses looked good.You saved me from buying a new TV, Many THANKS. I have sent you $50, hope all others will to!
Total fix still under $150 with new toys from Radio Shack,and extra parts for next repair.
Hi, I am also having the green timer light flashing problem. I have a WS55859, would you be so kind to send me the instructions on how to fix the problem?? It would be greatly appreciated!
