WD-52525 Green Light Flashing
59 posts / 0 new
cgtjr
A few months back my lamp went out. Last week I replaced it, and everything was fine. I watched T.V this morning, but when I got home I turned it on and it started to warm up and then shut down. Now the Green Light of Death is flashing at me. What are my options, preferibly cheap ones?
You may need to change the
You may need to change the four capacitors in the DM board assembly. You will need to know how to solder and have some mechanical ability to do this. It is not all that hard to do. If you leave an e-mail address, I will send you the documents that might help you repair the TV set.  Good Luck
GANZORUBEN
[email protected] . thank you
I will send the information
I will send the information out sometime tonight. Good Luck
GANZORUBEN
I never received the info.
I never received the info. Could you please try again? [email protected]
john cosgrove
i also have wd52525 with
i also have wd52525 with blinking green could i get more info?
thanks [email protected]
I will send the repair docs.
I will send the repair docs. out to you ASAP. Good Luck.
CUBAN37
Hello. I have a wd-52825 2004
Hello. I have a wd-52825 2004 model  last week  I was watching a movie and a heard a sound from the tv .. it went off.. i tryed to turn it back on , but not a good luck for me.. I did replace the lamp and cleaned the filter. put everything back together . turn it on green light blink for at least a minute then a red light appear with a noise from inside de tv (same noise) uummmmmmmmmm sorry.. any suggestion ..
CUBAN37
My e-mail address is  osvaldo
My e-mail address is  [email protected]..
thanks
The repair documents are on
The repair documents are on their way man. Good luck!
CUBAN37
Larry thanks. I just ordered
Larry thanks. I just ordered all 4 capacitors and two fuses just in case I need it.. I will get back to you asap.
thanks
If the caps are for the 525
If the caps are for the 525 series set, there are a lot more then 4 bad capacitors I'm afraid.
CUBAN37
The caps are for the wd-52825
The caps are for the wd-52825 series ... Let me know if I have to order some more.. They will be here on monday...
thanks
Look at the stuff I sent you.
Look at the stuff I sent you. Should have read and looked at the set before ordering.
Max 634
Larry:
Larry:
I've got a Mitsubishi WS-55613 with the blinking green light issue.  Would you please email the repair instructions to [email protected]?
Thanks in advance  - Max
Sure Max, on it's way to you.
Sure Max, on it's way to you. Good luck.
kendraa
Hello larry,
Hello larry,
I also have the blinking green light of death. Could you please send repair instructions to [email protected] --
Thank you,
Gregory
randy g
I have a model wd-52525,the
I have a model wd-52525,the green light was flashing,so i put in a bulb it lights up for 3-4 sec.then shuts off?????? I was told that it was the ballast.that alot of comp.blow out .Could you please help.I put it all back together and now the red lamp light stays on all the time ?????? thank you very much.if you have some repair information it is much needed
Randy @[email protected]
M & M
I also have a WD-52525 that
I also have a WD-52525 that has the flashing green timer light flashing. Could I please get the fix as well?
Thanks in advance.
M & M
I found a service manual
I found a service manual online and have started the flashing light repair on my WD-52525. I found 2 swollen caps on the FMT board and 1 swollen cap on the DM board. I will be replacing all 8 caps between the 2 boards. Any recomendation on the size caps I should upgrade to? There has been some mention of 1000uf 25v to replace the 1000uf 16v that came with the set. Has anyone done this on a later DLP set with out having problems? Any recomendations on brand name? I'm guessing not radio shack, I will probably buy them from Sandy's electronics.
randy g
can someone please send me
can someone please send me the manual for my wd-52525?I had the flashing green light.Put now I have a red light that stays on!I tryed two new bulbs,and they did not help.
Thank you,Randy
randy g
Hello,
Hello,
I deleted the information you emailed me by accident, I need to know how to buy the repair kit for model 52525 mitsubishi tv.
Thank you very much for your time,
Randy
P.S. do you get all the components you need to repair the t.v and instructions.
thanks again look forward to hearing to you as soon as possible
number5has16
I'm new to this web-site but certainly not new to the blinking green light on my Mitsubishi WD-52525.
I used to be able to get it working eventually but not this time. Please send repair instructions to the following address [email protected]
Your help is greatly appreciated.
Robert
67baja
Can you please send the repair instructions to me too? [email protected]
Thanks a million
randy g
larry please resend the
larry please resend the instructions to me.I dont know why I havent gotten them??? Thanks again Randy wd-52525 repair
randy g
Larry I have a wd-52525 that
Larry I have a wd-52525 that has the same problem that everbody else has ,Do you have a fix for me also?I seen a kit on e-bay for sell but I can't find it again,Do you know of it? thanks for your help.
Randy
randy g
Larry I e-mailed you but for
Larry I e-mailed you but for got to give you my e-mail ad.it is [email protected] for a fix for my wd52525 thanks again
Randy
jrhgandalf
I have installed the four
I have installed the four capacitors it worked for five minutes and the light is back to blinking any suggestions?
randy g
Randy
randy g
Randy
jrhgandalf
