Mitsubishi WS55513
204 posts / 0 new
Larry Dillon's picture
Just solder the pad that the
Just solder the pad that the cap wire sticks through
micmouse10
micmouse10's picture
Well, no luck. I replaced
Well, no luck. I replaced the caps and it didnt work. Now I hear a ticking sound in the back of the tv and there is still a blinking light.. any ideas??
try reseating the board as
try reseating the board as describe in the rinstalation part of the repair document.
micmouse10
can you email me the
can you email me the directions please? I am not sure we have the same ones. I never got an email from you. Micmouse10@aol.com
I would really appreciate it
micmouse10
I still havent gotten the
I still havent gotten the directions but I went ahead and took the board out and put it back and still the blinking green light. I only get the ticking noise in the middle of the back when I push the reset button. Can anyone help please??
micmouse10
Well I tried taking out the
Well I tried taking out the board again and put it in without the case just to make sure that it was properly connected. But that didnt help. The capacitors that I had taken it were bubbled at the top, which means they were bad.. So I put new ones in.... and now it still doesnt work. Any ideas on what it might be? When I push the reset button there comes a tick in the back middle of the tv. That doesnt go on until I push the reset button...
Please help. I am trying so hard to try to repair this. I cant afford to go out and get another tv... please
Buck Wilson
Buck Wilson's picture
Larry
Larry
Mitsubishi ws-55513 green flashing light I am having the same problem could you please send the repair doc. to me also Thanks so much
Wilsonm@nucorsteel.com
micmouse10
Does anyone know what to do
Does anyone know what to do next if the capacitor fix doesnt work??
Ken1000
Ken1000's picture
Micmouse10,
Micmouse10,
Try using caps with Breakdown voltage of 25V or 35V. When I used recommended 16V, it didn't work either. Keep at it, I ended up replacing caps 3 times before getting it right. Go slow and be careful. Good Luck.
Ginger C
Ginger C's picture
I have the famous green blinking light. Mitsubishi ws-55513. We were watching tv fine. Bought a new one and moved tv into another room to sell. I went to turn it on and it just keeps blinking and won't turn on. I have had someone that he replaced one of the fuses on his dm board and it worked. My problem is how to get the dm board out?? What needs to be removed to get it out? We took off the part next to it that has all the component plugs, took the plastic bracket off the top, and the screws at the back and middle. It won't come off, there is something at the other end inside the metal case that is keeping it from coming off. There is not enough clearance above to lift it out.
Does the instructions you send out have this information and also how to test the capacitors and fuses to determine if they are bad. Thanks for your help in advance.
Ginger C
Ginger C's picture
micmouse10 said:
Hi Micmouse10,
I have read a ton of posts on this problem as I am currently trying to fix it my self.  There was a guy in CA that was told to replace those capacitors.  He did it and his didn't work either.  He then tested the fuses on the board and found out that one of them were bad.  He just piggybacked the new one on top of the old one because he didn't know how to get that one out.  Put dm module back in and his tv worked.  If you look to the right inside on the tv you will see a white label with some information on it.  Read it and at the bottom they give you the fuse #'s and tell you there on the dm board.  He said he picked them up at an electrical supply company for a few dollars.  He tested them with a multimeter and you are looking for continuity.
My problem is I don't know how to get the dm module out.  So if you have info on that that would be great.  Let me know if you try testing fuses and if that is your problem.
If I knw whre to send you the
If I knw whre to send you the info, It explains it all in the directions.
Buck Wilson
Larry
Larry
Please send them to me also
Ginger C
Ginger C's picture
gchmelewski@nc.rr.com.
bill early
bill early's picture
larry my ws55513 had the cap.
larry my ws55513 had the cap. problem. had it repaied- now 6mos later the problem is the tv will play a few mins. pops to a blue screen. power off-power on same thing again.tv menu will come on but none of the inputs
thanks bill. send to email . earlysr@bellsouth.net
DMF
DMF's picture
We are having the same blinking light problem with our mitsubishi ws 55513. About a month ago I tried turning on the tv but the light was blinking & it wouldn't turn on. Then an hour later it was working fine. Unfortunately, today I went to turn it on & the light was blinking again but this time it won't stop. Could you please help me?
dmarino25@optonline.net
Thank You!
Ginger C
Ginger C's picture
Did you also check your fuses on the back of the board.  Sometimes those are bad as well as the capacitors?
micmouse10
yea i checked the fuses..
yea i checked the fuses.. they were all good... any ideas what to do next??
Spiro Papadopoulos
Spiro Papadopoulos's picture
Mitsubishi WS-55513 55 in.
Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
About 6 months ago replaced the 4 caps and has been working great ever since. Now it has power, but picture and sound go out, TV still works you can go to menu and anywhere else, you just loose reception on TV and DVD turn TV off then turn it back on, it comes on by itself for 5-60 seconds
The whole time the green light stays on and TV operating just no sound and picture any idea?
steve@klassykoach.com
Redman
Redman's picture
Hey Larry, Moneyshot here
Hey Larry, Moneyshot here from the Sony forums. I have had no luck with fixing my sony but have come across a mitsubishi ws55513 for $400. The owner says he has no problems at all with it but I am very scared to buy a used TV. Its a 2004 model. Any advise or suggestions would be greatly apriciated! What to look for, common probs, anything? thnx again!
jeffw
jeffw's picture
Hi Larry...same WS-55513
Hi Larry...same WS-55513 blinking light of death prob here...requesting your very popular fix as well as any service manuals what-not that you might have. Thanx.
cygnusx1@satx.rr.com
SB001
SB001's picture
Hi Larry-
Hi Larry-
I have just bought a used Mitsubishi WS-55513 set, believe it or not the set is working ok and I only paid $50 for it! I have not had any problems yet, however the gentleman I bought it from says that occasionally the set will turn itself off. After reading this thread I am wondering, just in case I end up having the same problems down the road as others have posted here, if you could go ahead and shoot me the fix for the set losing power (just in case!) My email address is: sblag000@yahoo.com
Also, what would cause lightly faded vertical strips on either side of the set? (Pic still looks very good but they are noticeable.)
Donna Poo
Donna Poo's picture
I have the same blinking green light problem. The first time it happened, I tried the reset button to no avail. We unplugged it for several days and then plugged back in to see if it would work and it did. However, we are now back to the blinking green light. Could you please send me the repair instructions. I greatly appreciate your help.
DkluvsTk2006@aol.com
Thanks, Donna
Bakerbl225
Bakerbl225's picture
Larry, can you send me the
Larry, can you send me the repair documents for the WS55513 Model? The green light is blinking and no power. Thanks.
Extech
Extech's picture
Hi Larry, I just aquired a
Hi Larry, I just aquired a WS55513 with the same problem. Could you please send the repair instructions to: cjwilson@mwt.net.
Thanks much,
Extech
Spiro Papadopoulos
Hi Larry, I just aquired a WS55513 with the same problem. Could you please send the repair instructions to: steve@klassykoach.com
Thanks much,
Steve
PC509
PC509's picture
I am having the same problem Larry. Could you email me the same? Thanks a lot!
dharper@vistarip.com
I really appreciate it!
Dustin
Extech
Extech's picture
Thanks much,
Extech
Spiro Papadopoulos
Thanks much,
Steve
PC509
PC509's picture
Dustin
