Mitsubishi WS55513
204 posts / 0 new
a.d.
a.d.'s picture
Hi same here ws-55513.
Hi same here ws-55513. Blinking green light. Please send help!!!!! adamstriz@hotmail.com Thank you so much!!!!
a.d.
a.d.'s picture
Hi same here, blinking green
Hi same here, blinking green light on ws-55513. Please send help!!! Thank you so much! P.S. shouldn't Mitsubishi have done a recall? Every single one of these has done this by the looks of things. Don't get it. adamstriz@hotmail.com
Gacky
Gacky's picture
Larry, I dont know for sure
Larry, I dont know for sure if I have the same problem as the others here. I dont recall seeing any flashing lights other than the ones in my head when my 2 year old 55" died. Had a friend at the time worked on tvs who relaced some caps . Worked good for 2 years then died again. Please send me the fix too. Thank you. Mike smutpup@wctel.net
tapir123
tapir123's picture
Larry, I'm yet another
Larry, I'm yet another frustrated owner of a Mitsubishi WS-55513 with the blinking light problem. I guess I'm lucky in that I haven't been resetting the TV as others have. Would you please send me the repair instructions so I can see if I can make this thing work without forking out the big bucks. Thanks so much! Paul tapir123@yahoo.com
a.d.
a.d.'s picture
You can get detailed
You can get detailed instructions off this site. They are in the articles section. Type in Mitsubishi repair in the search box and you should get it. I think it was the first one that popped up. It's three pages and perfect. It is for a different tv but it's a Mit. WS and the guts are just the same as the 55513. Few less screws and some of the wires you have to loosen might be different. Use a ground strap so you don't make this $5 problem into a serious one. Good luck, worked for me.
micmouse10
micmouse10's picture
So I replaced the capacitors
So I replaced the capacitors and now when I plug the tv in, I get a ticking noise and the green light still blinks. I have tested the fuses on the board and they seem to all give feedback. Ideas? And helpw ould be appreciated!
Matteo21
Matteo21's picture
Please send the same
Please send the same documentation for a Mits ws-55513 with the same no power / blinking light problem - thanks, seats21@gmail.com
stupidtv
stupidtv's picture
sound like a blinking light
sound like a blinking light epidemic we should riot at mitsubishi factorys lol.
if your still around or if anyone with the info is still on here can you send me a copy ofthe instructions for repair
Jerry.b_stockmyer@yahoo.com
a.d.
a.d.'s picture
There are instructions right
There are instructions right here on techlore. Open the articles section and type in " mitsubishi repair " in the search box. The first article that comes up is how to fix this problem. It is for a different model mitsubishi but I used it to fix my ws-55513. Same parts and everything, once you get into it you'll see. That article is the only thing I needed to fix my tv besides parts and a solder iron. My total cost for my 55513 was $12. Buy 35v 1000uf 105o capacitors,grab a screwdriver and get ready to watch tv!...as far as any other problems go I can't help. I'm not an electrician, I'm actually a car guy so until I have another problem with mine all I know how to do is replace these capacitors. Good Luck
Josh C
Josh C's picture
Please email the fix
Please email the fix instructions to mribay16@yahoo.com. I have the WS-55513 model with the green blinking light. Thanks.
Tomcat35
Tomcat35's picture
We are having the same blinking light problem with our mitsubishi ws 55513. Could you please send the repair procedures?
foxtrotters@cox.net
Thank You!
ruloboy
ruloboy's picture
I have a blinking problem
I have a blinking problem with my mitsubichi WS55313, it does not power on, the green light goes on and then off after 2 or 3 seconds, can I fix it myself?
ruloboy
ruloboy's picture
Can you email me the
Can you email me the instructions too, mine has a problem just like that
my email is raulcastroa@gmail.com
Thanks in advance
dave69
dave69's picture
Can anybody help me with same
Can anybody help me with same problem on my ws55513. Power LED blinks all the time and would not reset at all. Any help greatly appreciated...
Here is my email. dvav1469@yahoo.com
Ryan86
Ryan86's picture
I'm having problems with my
I'm having problems with my WS-55513. It started with the screen going in and out from a black screen to cable again, then the remote control and the buttons on the front of the TV stopped working the next day. The volume stays at 0 but I can still change channels. It is my parents TV so I'm not sure if there was a power surge or anything else that could have caused damage. Any info will help! email - Revolsnayr@hotmail.com
Guest (not verified)
Guest's picture
Sir Larry Dillon...God of all
Sir Larry Dillon...God of all Repairs.
I am a recent victim of the WS 55513 blinking timer light due to a power surge. Could you be so kind and send me a copy of the repair procedures.....I would greatly appreciate it and thank you for your time....John Curtis
Guest's picture
sorry Larry..I guess an e
sorry Larry..I guess an e-mail address would help....johncurtis@mchsi.com
Again, sorry and thank you for your time and info!!! John
Pontiacfan455
Pontiacfan455's picture
Larry Dillon said: Check and
Larry Dillon said: Check and double check all of the cables and plugs and make sure they are not pulled out a little bit. I have seen this happen a hundred times, and even when I have done work on a TV set this has happened. That is why i ALWAYS, before plugging in a set, go over all of the cables and plugs by hand to make sure they are all seated into their sockets all the way.
Mr. Dillon,
I too have the flashing timer green LED on my Mitsubishi WS-55513.  My wife was changing the desired input (TV was on and everything was fine), then the unit began acting as if the software / firmware was messing up.  She tuned the TV off and now it will not respond.  All we have if the flashing LED.....
I have checked all cables.
Any assistance will be GREATLY appreciated.
Mike Brown
Salem, VA
Pontiacfan455
Mr. Dillon,
Mr. Dillon,
As requested, my e-mail address is Pontiacfan455@comcast.net.
Note: I left my TV on all night, and when I awoke, the flashing light had stopped flashing (after at least flashing for four (4) hours yesterday). It is working just fine now........
As a precaution, please send instructions on what I should check if this WS-55513 acts up again.
Thanks for responding, and have a great weekend.
Mike Brown
Guest's picture
Good Afternoon and Happy Friday! I just received your kit and it looks like the Capacitors are OK. There are no bulges on the tops...could they still be bad? I did notice however that there are other capacitors (3 in total)in the set that have a yellowish glue/caulking in appearance type substance that seemed to come out of the top of the capacitors and run down the side...does this mean anything? Did they rupture, is this some type of factory insulation????? I have no idea...lol I have pics of everything....let me know if you want me to send them to you. Didn't want to start removing good capacitors...thought it best to consult with you first....Thanks again as always for your time. john curtis
Larry Dillon's picture
if you could send me a
if you could send me a digital photo that would be the best!! send to techman32k@yahoo.com thanks!!
Larry
john yes the old caps do not
john yes the old caps do not have to look bad to be bad please follow the direction and reolace all of the caps wioth the ones provided
Guest's picture
Installed new caps per instruction and still I am getting the blinking green light. Also, pulled the DM and re-installed per instructions...same result. Do you send installation instructions for rest of kit? Is that the next step?Thanks for your time and info...John
did you check the surface
did you check the surface mounted fuses inside the DM, they are mounted on the solder side of the board. GOOD luck
micmouse10
I have the same problem.. The
I have the same problem.. The caps were bulged when I took them out and replaced them and still get the blinking light. I checked the fuses with a multimeter on the opposite side of th eboard and they all registered.... what would be the next step?
take out the Dm , take off
take out the Dm , take off the case around the DM, reinstall the DM, making sure it is seated correctly. also would depend on how long you reset the TV when you had the blinking light and then the set started working again??
micmouse10
i just did all that... it
i just did all that... it never worked after i changed the capsales...
lets try this again! how many
lets try this again! how many times did the set not go on or had the flashing light and you did a reset or unplugged the set and it started to work?? Be honest with yourself please!
micmouse10
the set went off, i replaced
the set went off, i replaced the capacitors... put it back togehter, green light still flashing.. i took it apart to make sure i did everything correectly, checked the fuses, and put it back together. still blinking light.. there is a ticking though ever since i replaced the capactiors... do u know what that means??
Guest's picture
Checked the fuses on the opposite side of the DM Board F9B00 & F9B02 with a multi-meter. The needle went off the chart on both...what is the next step?
Thanks again for your time and info...John
