My TV just started to lose its convergence so I converged it. I had to do this twice in about a 10 min timeframe. It then went completely black. I decided to change the convergence amplifiers, but the TV is still black. Maybe a resistor? Any help on this is greatly appreciated.
First off, If you are sure of the model number, do not fret just yet. You most likely need to check and see if you have the right plus and minus voltages on the IC's. Did you buy the good IC's? Or the aftermarket type IC's? If you paid less the 10 to 15 bucks a pop, they are the cheapo IC's. You will most likely need a service manual to see where the pico fuses are, as these do blow out when these IC's blow out. Also, Did you install new heat sink compound on the backs of the new IC's before you installed them? let me know if you did all this as well as access to a service manual, as I do not have this model number in my data.
I did buy the cheapo IC's. I have a service manual that I downloaded. I really don't know how to look for the pico fuses though. I did use heat sink compound on the IC's. I can send you the service manual via e-mail if you want to look at it. Thanks for helping.
Sure, send to [email protected] and I will see what I can do for you. Do you have a mutimeter or an ohm meter?
if anyone can email me that service manual or a link to it I would appreciate it. I too have a conv. problem and will need to address.
thanks
can I get a email copy of that service manual. I can't find it anywhere. thanks
I would love to get a copy of that service manual if possiable I have a pt53wx53g and my screen just went blank. I unpluged it and than pluged it back in, it tries to start up but goes black again and the power light flashes 3 times and pauses then repeats. Please help! [email protected]
I would like the service manual if someone has it. I have the same problem. I replaced the 110's with 150's, but not I can move the blue. Any ideas? Could it be bad solder joints?
Hi,
I have a PT-53wx53g panasonic tv and it does not turn on. there is a red light flashing 5 times. What could be the problem? I want to determine if its worth repairing? Thanks so much for taking the time to respond!
Sameera
