Like Jack says, no service manuals to be had. It needs new convergence chips. Open it up and get visually familiar with the inside. The convergence chips are thermal-glued to giant heat syncs on the D board...you can't miss em. If you're like me, a little apprehensive about soldering new chips in, just unscrew the board tray and slide the whole thing out after disconnecting your cables. Be sure to label the cables, you'll want to plug them back in correctly the first time.
Find a local electronics shop and have them replace them for you or talk to the guys at Atlas Electronics in Dallas if you have no local reputable shop. I recommend getting someone to test the board first as one bad resistor can mess up your newly replaced convergence chips.
Remember, there is high voltage in your tv so be careful.
I have a Toshiba 50HX81 with the blinking power light issue. I replace F850, 851 and 852. the Tv worked for about an hour and now 850 and 852 have blown again. All caps look good, should I go directly for the convergence IC or look for something else on the power supply board?
I spoke with Sam at Atlas Electronics in Dallas (local referral) this morning. He's quoted me $22.50 to test the board and install the convergence amps. He's charging $20 for each amp so around $60 total. Not too bad considering I don't have to purchase a precision soldering iron and risk messing up the board also.
Larry, I hope you beat down that cancer...hang in there buddy!
I took the board to Atlas this morning and waited less than 15 minutes. Only problem was the convergence amps. He upgraded me from 110 to 150 for $10. Total $77 w/tax.
Larry Dillon said: great to hear!!another fix via a DIY!!
mike s ...hard to find a good tv repair guy...think you can give his phone no. maybe I can mail my board to atlas for repair....thank you ....rudy g.([email protected])
I have a Panasonic PT-47WX42X, I just replaced the IC's it got better but I sill can not bring the red all the way in, and the green has to be all the way to the right to get the best that I can get. ANy help would be great. I also have read that I may need to adjust in the service menu but I don't how to get to this menu. Can anyone tell me how? thanks in advance for any Help.
I have a Panasonic PT-53WX52F with the same 3 blinks, can someone send me a service manual, and the best place to purchase the parts. [email protected]
You need to get into the service menu. Activating the Panasonic service menu is a strange process, i don't have it here now, but once i get into work tomorrow i will relay the info.
if you leave an e-mail address I will send you a PDF of the service manual so you can see for yourself all the steps to adjust the different fine and course Adjustments in the service menu !
i have a panasonic PT-53TW53 and i replace the converge chips twice in a row thinking it blew up the first time but before i replaced the IC the tv was working and after my soldering of the new IC the tv click turns on and then immediately off with 3 blinks.. HELP i can't get this tv on at all. replaced most resistors tested by a ohm meter and spent $21...
Larry Dillon said: if you leave an e-mail address I will send you a PDF of the service manual so you can see for yourself all the steps to adjust the different fine and course Adjustments in the service menu ! Larry Dillon
Having the same problem here - I'd love the manual too. I'm going to try and tackle this myself.
hey nick do you have any idea how many models Panasonic makes??do NOT ask orb leave an e-mail address any longer here on techlore please. please ask on the technicians corner under the resources tab on the home page if you do not see it there ASK there Please!!!!!
the 3 blink on a Panasonic is always the bad convergence ic's
The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
Hi, I have a Panasonic PT-53WX42F with the same 3 light blinking problem as everyone else. I am going to order the IC replacement kit and was wondering if anyone could email me the service manual.
I also have a Panasonic PT-53WX42F with 3 blinking lights and was woundering if I as well could get the service Manual. Thanks if you can :) [email protected]
Hi, I also have the Panasonic PT-53WX42F with 3 blinking lights and was wondering if I also could get the Manual Emailed to me, Thank you if you can :) [email protected]
I had the same problem with the light blinking three times. I had a friend replace the IC's and i have picture now but the convergence is all screwed up. I tried adjusting it with the remote but it won't do anything. The prompts come up and the arrows blink but there is no adjustment being made. Any suggestions?????
Sounds like a resistor and or a pico fuse,did you check the ones around the IC's?Did you clean the board around the solder joiints with acetone and check for bridged gaps
Larry Dillon im having the same problem with my fire house TV cant afford to buy new one can can u send manual forpt-47wx42f
Good luck and post again with any questions.
I have a PT-56TWD63G doing the 3 blink thing. Please upload a service manual if you have one.
I looked up IC parts on Panasonic's website. Is this the part I need? C5AA00000203 IC (VIDEO) $51.20
Any help is appreciated. Happy New Year all!
Mike
I never found a manual. Here's where to get the ICs (you need 2). http://www.electronic-repair-kits.com/index.html
Jack
Thanks, Jack. Did you have to replace any resistors or pico fuse?
I hope that Larry Dillon is doing better. Good luck to everyone for 09!
Mike
I didn't have to replace anything else. Lucky, huh? Good luck to you.
Jack
yes I would say luck! but it happens sometimes. and thank you I am feeling better but won't in a few days as I start my chemo adain '>(
Mike
Speedvision again....yes!!!
http://www.atlaselectronicsinc.com/
This is a family owned operation which has been around for years. I highly recommend them.
Thanks Larry
Larry Dillon.
hey i have a pt53tw53 and it blinks four times i dont know what the hell it means
Thank you in advance,
Kyle Fisher
Can someone please email me the service manual for this? I opened up the back of my PT-53WX42 and I have no idea how to get the board out.
