I am having the same issue as everyone else, blinking green light. I have a WS-65909 Diamond. could you please send the repair instructions, manual, and also where I can buy the capacitors to [email protected] Thank you very much.
If you wish to use those or I also sent a link at the end of the e-mail that tells you what capacitor to order. Mitsubishi does not make their own parts. there are about 200 different companies inside your TV set.
Larry Dillon said: If you wish to use those or I also sent a link at the end of the e-mail that tells you what capacitor to order. Mitsubishi does not make their own parts. there are about 200 different companies inside your TV set.
I'm not sure why, but I got your email, but there are no links or attachments to the manual or any of the information I need to do this repair. Could you please send it to me again for a Mitsubishi WS-65909 to [email protected] Thank you again for helping me out.
Larry Dillon said: I have just mailed all who has asked for the documents, and I sent along the different service manuals also. Good Luck, and let us know how you all made out with this repair.
I have a WD-62825 with a timer light that's flashing. Every once in a while I can get the TV to come on but it seems to be getting worse (an I was previously having a problem with the Status light flashing - that probalem went away and now this one has surfaced).
Can you please send me any/all all instructions and manuals that would apply to this/these conditions described.
Much Thanks. Replaced the 4 capacitors on the top and I was good to go. BE SURE YOU press the DM FIRMLY back into place. At first I thought I had not fixed it. I paid$25 to have the pieces installed so the total was around $35 total (not bad).
Hi Larry. I have a WS-65813 and just woke up this morning to see it winking at me. Tried the reset to no avail. I am now going to unplug it and graciously await your directions. Please send them to ejmerch@hotmail-dotcom. Thanks!
Larry Dillon said: Robert and SCfan, If you would like to attempt to repair your TV set, I will send you the instructions on how to do so. If you do not know how to solder well, do not attempt to replace the capacitors yourself. Pay a pro to do this for you. After all you are already saving a bundle of cash. If the capacitors inside the board are not swollen on the tops, as the direction shows you what they look like, the capacitors are most likely not your problem. But the best test is to replace them. I have a few different documents for different sets. Go through them and use the one you need. Good Luck
hey there i'm a newbie but i also have a mitsubishi ws-65315 that won't turn on, i also did the hold the menu and input button on the front panel and it flash once pause then 2 more times so dose mean that is code 12 whatever that means? But then i read this so i was woundering if i can also get the instructions on how to replace the capacitors. thanks alot Tony
I posted back on 3/22 asking for the instructions and service manuals yet have not seen a repy and I have not yet seen a response form you, yet it seems that others who've posted since my posted have gotten responses.
please don't get me wrong, I'm not expecting anything near immediate service, I'm just wondering if you might have missed it in this rather large thread and all the requests that you get. Here is a copy of my original posting (please note the email address is broken up in an attempt to reduce spam):
I certainly didn't mean to be insulting in any way, shape, or form - not by any means!! I know that you're getting paid zero for this and probably spend a lot of time doing this (which is greatly appreciated!!).
I'm in IT and was simply trying to figure out what might be the problem as I usually never have issues with people sending to my gmail account (If I have problems with my work account I have them send it to my gmail and it has never failed before).
toneloc said: Hey Larry I go them Thanks. The only problem is that my ws-65315 caps don't look like the ones in the photos. I am almost positive I have the module out but I seem to have the real small silver caps in mine. Am i posibly looking in the wrong place. I have several pictures that i took I can forward them to you for review if you'd like. I appreciate your time. [email protected]
hey larry is there any help for me on that ws-65315 it won't turn on. thaks Tony
hey Larry its Todd agine I finly got another Tv and do you have a repir maul for a ck-35402 send it to [email protected] and did you finly got the manul from me?
I have a Mitsubishi ws-55613 and I now have the fast blinking green light. It sounds like Larry is the man to talk to about this. I am sure that I can fix this if I have the information. I am seeing that buying a dm module is not very cheap. If larry could send me the information that would be great. [email protected]. thanks a million
I have a WS-65611 and it's winking at me. Tried the reset to no avail. I am now going to unplug it and graciously await your directions. Please send them to [email protected]. Thanks!
hi every one...hey i have a 65 mitsubishi ws65909 with green light flashing and its not letting me turn on my tv can eney help ....hey larry if u are reading this can i get the infornation from u my e mail is [email protected].....
People need to start posting their request on the proper model number thread It is getting way too confusing this way. This thread is for the model number WS65513 series set. No Doggie I did not get the service manual and No, I do not have that model number. Jim and pama, I will have those repair documents out to you all shortly. Good Luck
I work for the Distance Ed department at a college that has the Mitsubishi WS-65513 with the green light problem. Could you please send the service manual and repair info to [email protected]
Hello Larry,
TIA!!
Robert Strom
robert.strom at gmail.com
I also need the directions. My 73713 went out over the weekend. My email address is
Doug
zig, great news man! glad to hear it! Doug, your repair directions are on thier way also. Good luck
John
Will send them out to you shortly John, Good Luck!
Got them and am ordering parts now.. Thanks!
TIA!!
Robert Strom
Different model number Tony. The set I am talking about is the WS-65513, NOT the WS-65315. Big difference. Sorry.
Robert, that was sent out to you twice. It kept coming back as undeliverable.
How large are the files? Are you copying the email, or manually typing it?
If manually typing it's common for people to type STORM, instead of STROM.
robert.strom at gmail.com - I'm logged into it right now and it's working fine.
You could also try robert_strom at cox.net
Dude, I do know how to send an e-mail. I have been doing this a long time. I always copy and paste. What was the model number you needed?
I have a WD-62825
Again - TIA / much appreciated
Robert
Thanks Larry,
I did the repair over the weekend and my set is now functioning.
No instult taken, at all. Will try it again later this afternoon. I do not have a remote attached yet to my desktop.
Hi Larry - My WS-55513 has been struck with this blinking light fiasco! May I also get a copy of your repair manual?
Thank you in advance!
Hi Larry.
Tim
ok Larry I send it out to to agine and follow the like to the down lode tell me when you got it its for the WT-42311
ok i sent you a new e-mail with the file of it. it mite be a little big i for got to make it small
Hello Larry,
Thank you sir!
larry,
have a wd-52725 with the wavy blue lines. Tech said it needs new dm board at $$$. Would also like the instructions for capacitors etc. thanks.
