Well, stop me if you've heard this one before... last weekend I noticed that the timer light on my four year old Mitsu 65 incher was blinking and the TV wouldn't power on. The reset switch didn't fix the problem and a quick look at Google led me here. If someone could fill me in on the repair procedure, it would be most appreciated.
Thanks in advance!
Cheers,
Winslow
Teelovato
Teelovato's picture
We were wondering the same
We were wondering the same thing - same thing happening with our TV - could you please send us the instructions? I am good at soldering and could probably fix it  email address is ucanrentme@gmail.com
Tonyd33
Tonyd33's picture
My blinking timer light is
My blinking timer light is flashing green, can someone please email me how to fix it, spb10717@yahoo.com
Tonyd33
Tonyd33's picture
Can't do it myself with the
Can't do it myself with the soter, any professionals in LA YOU RECOMMEND
tracehaze
tracehaze's picture
I'm having the same problem.
I'm having the same problem with the blinking timer light.  I have been able to use the surge protector to turn on and off.  This just started happening when I disconnected the DirectTV receiver and stopped using that remote.  Can I get the repair instructions sent to tracy.hazelett@yahoo.com
Sleepinsuby
Sleepinsuby's picture
WD-65831 tv here doing the
WD-65831 tv here doing the same thing. Was working fine. The timer green light would blink on starting the tv then it would work fine. Was playing xbox one on it about an hr ago when the screen and all went out and the green timer light started blinking. Larry could I get you to email me the instructions as well. Sleepinsuby@gmail.com  thanks
cbeggs
cbeggs's picture
I have a Mitsubishi WD65737
I have a Mitsubishi WD65737 that has a green blinking indicator light for approximately 15 seconds followed by the Mitsubishi electronics screen coming up for about 15 seconds then tv shuts off. I recently replaced the bulb and it worked great afterwards.  I have tried the reset process via the owners manual but this has no effect. I have unplugged it from the wall outlet and surge protector for overnight and still no change in the result.   Any help would be appreciated.   Clint
cbeggs
cbeggs's picture
Regarding post "I have a
Regarding post "I have a Mitbushi WD65737" above, I was able to solve the problem myself and wanted to post it here to help anyone who is having the same issue. After checking the error code that my TV generated after it shut down, it yielded the code of 12. This code indicates that nothing is wrong with the hardware of the TV. Hence it had to be a software problem. The Mitsubishi website has a section that explains how to download new software to a USB drive and install it on your tv. Very easy to do and after I followed the procedure they outlned, my TV works normally again.
dpagem
dpagem's picture
Not sure if my first message
Not sure if my first message posted.  I have a WS-65711 with the dreaded blinking green light after a power surge.  would appreciate it if you could send me the file with instructions as to how to fix it to dpagem@gmail.com
kkruzito2016
kkruzito2016's picture
Hi, my name is Joe. This
Hi, my name is Joe. This message is 4 Larry Dillon. Or to whom ever can help me. I noticed u were helping others with their situations with thier tv's. I was hoping to get your help also. I have a Mitsubishi WD-65833 Diamond Series with a code 34 (lamp abnormality) exept i know for sure the lamp is good. It could be that the ballast is no good but i dont know that for sure. When I turn the tv on it stay on for about a minute then turns off. The picture and sound are fine until it shuts off. Then the fans run for a while after that. I'm gonna assume they stay on b/c the bulb has to cool down. So i just let them run. I noticed you had mentioned that it could be some bad capacitors. Also that they can look in good condition even tho they are not. Anyway,...I was wondering if you can email me the instructions as to how to go about fixing this tv and R&R'ing all the capacitors and/or whatever else needs to be replaced. I appreciate your help if you can.   Thank you in advance. I can sure use the help. Also i can help out other people with the same problem if  you are willing to help me.. My email (s) are....   kkruzito2013 @ yahoo .com                                  kkruzito2013 @ gmail .com
kkruzito2016
LARRY DILLON...PLEASE HELP!!!
LARRY DILLON...PLEASE HELP!!!   I'm not sure if last post got posted so again can you plz help me Mits WD-65833 turns off after a minute. Can I also get the Instructions as to how to fix my tv...thanks in advance.. You can send instructions to: kkruzito2013@yahoo.com kkruzito2013@gmail.com
stowe
stowe's picture
Hey Larry I know this is a
Hey Larry I know this is a super old post. Hopefully you will still see this. I'm having the same issue as everyone else. I'm excited to break out the old iron and give this a whirl. Is there a chance you could send me the same Info to stowe.bizmail@gmail.com? Thank you in advance!
Tmmw77
Tmmw77's picture
Wd-6583 . Same blinking green
Wd-6583 . Same blinking green timer light issue. Tmmw77@hotmail.com
Dvines69
Dvines69's picture
the blinking green light has
the blinking green light has gotten us too!  Could you please email the fix to Doug.vines@gmail.com
M20j
M20j's picture
Hi,
Hi,  I have a WD-57831 with the green timer light blinking fast. Can you please email me the instruction for the fix?  Thank you very much. Markmende@msn.com
Qtdds219
Qtdds219's picture
Hi Larry
Hi Larry We have the same problem with the blinking green light. Can you please send the link on how to repair it and the service manual for WS55613.  My husband is pretty handy with these things.  Thank you in advance. Qtdds219@yahoo.com
AcreMaster
AcreMaster's picture
Larry...same issue here after
Larry...same issue here after power outage. Please send HELP to AcreMaster@aol.com Thank you very much.
hshell25
hshell25's picture
Hey Larry I have a WD-52531
Hey Larry I have a WD-52531 and the cap looked good but i went ahead and changed them because i have the blinking green timer light and the tv wont come on problem after replacing the cap i still have the problem do u have any other ideas on what it could be. Thanks hshell25@bellsouth.net
Chamaco212
Chamaco212's picture
I have a 42 inch Olevia TV
I have a 42 inch Olevia TV how do I reset my parental control I forgot the password
aabrams9
aabrams9's picture
Larry, The blinking green light seems to be a major problem with these tv's.  My husband is going to remove the part and have someone do the work.  Would you please emal us the fix at dabrams9@cox.net?
wwboss
wwboss's picture
Larry, I too have the dreaded (now I see very common) blinking light syndrome.  The tv has been sitting for a while, waiting to be taken to the dump.  I found this post and thought I'd give the repair a shot.  Not sure if you're still providing the directions or if Mitsubishi has since provided you with a nice check since you have had a hand in fixing many of their TV's!  It is obvious Mitsubishi had issues with many of their projection TV's.  Please email to wwboss302@roadrunner.com. Thank you in advance!
wwboss
wwboss's picture
Forgot model number, WS-65511
doubleoseven
doubleoseven's picture
Larry, could you please send
Larry, could you please send me the instructions to fix the cap issue. Thank you. Model : Mitsubishi WD-65833 Email : darwin.brewer@gmail.com
Topic locked
