PS3 ip address Failed. PLEASE Help!
14 posts / 0 new
tropickel
tropickel's picture
I see half the PS3 owners have this same question, but I cannot get my PS3 to hookup online.
My strength says 100%, but when I try to log on it says ip address failed.  I don't know much about computers, so half the info given out there just confuses me more.
Would someone please help me step by step if possible. We have a Netgear WPN824.
thank you so.... much any help is very much appreciated!!!!
Matt Whitlock's picture
I'm sure if we work together
I'm sure if we work together we can get you up and running.
First, do you know what kind of security you have enabled in your router? What have you tried to do to troubleshoot. Will be very helpful in helping you figure out where to start.
tropickel
tropickel's picture
Thanks but how do I find this
Thanks but how do I find this out?
Routers typically have a web
Routers typically have a web interface that you can access through your computer's Internet browser.
Type: "192.168.0.1" (without the quotes) into the address bar and you should hit it. That's the most common, but some routers use differnent standards.
Did you set up your router when you got it, or did someone else?
tropickel
tropickel's picture
192.168.1.1   That is what
192.168.1.1   That is what mine is.     what I type it in it comes up as the netgear smart wizard.  On the left of the page there is a scroll down sections.  It says Security service.  I clicked on that.  It says n/a under the antivirus software.  Is this what you're talking about?
What would be a good time that you're on here.  so we can better communicate.
zzoinks2
zzoinks2's picture
ok...i had an ip addressing
ok...i had an ip addressing issue. if anybody else has this then here is what i did. i have a linksys wireless router G and its setup on a wep. my problem was that i had four wep keys generated and was trying to use the ones other than the 1st (or the one that i used as default transmit key which is adjusted in the router on the wireless security page). so make sure you use the default wep key even though you may have other systems, computers, or gaming equip under that same wep. anyways, hope this helps. it worked for me in a snap!
zzoinks2
zzoinks2's picture
autumn78
autumn78's picture
I had this problem,
I had this problem, everything else connects to the internet except the PS3. I solved it by hitting the Reset button on my wireless box/ router (Netgear), waited 10 mins for it to do it's thing and it worked fine afterwards :-)
adam1121
adam1121's picture
Ok so mine is not connecting.
Ok so mine is not connecting. I used to have the wii connected but that doesn't anymore either. I have reset the router a hundred times, turned it on and off, unplugged it, made sure the wep key and everything was correct but nothing seems to work, any advice? I have verizon and a verizon wireless
router
darrenj1
darrenj1's picture
with regards to the Verizon
with regards to the Verizon one, I saw a post saying that you need to manually put the ip address in, if that helps.
uurx-98
uurx-98's picture
hi there i also am having
hi there i also am having troubles with my wireless connection i have re booted my router time and time again and still keeps sayin ip adress failed or timed out is there anyway i can restore or reinstall my internet connection so i can fully restart my internet from scratch
amark03
amark03's picture
I am having the same probelm.
I am having the same probelm. My ps3 is is finding my Ip address, but not connecting to the internet. i have checked and manually put in the IP address, but still cannot figure it out. I have comcast service and a netgear wireless adapter. Any suggestions????
Robert Crane
Robert Crane's picture
I have verizon fios too and
I have verizon fios too and the same problem. the wep key is incorrect and it says the ip address failed
ip ads
ip ads's picture
the manual ip adress angle
the manual ip adress angle will not work it wont fucking let you go pass you have to go back and do the fucking automatic i have tried it hundreds of times and i am pretty much convinced the only way this works is through the fucking ethrenet
