JVC TH-C50 Home Theater
46 posts / 0 new
mth57
mth57's picture
The unit will not turn on.  The outlet it is plugged into has power.  Is there a fuse in this unit?
dans_repair_service
dans_repair_service's picture
These units have fuses, but
These units have fuses, but that is not usually the problem.  Is there a standby light on?  If not, then there is a problem with the standby powersupply.  Without the standby, the unit will never turn on.  If the standby light is on, then the unit may be in "protection" mode and not turn on.  Usually when in the "protect" mode, puching the power switch will cause a click followed by another.  This is the unit trying to start and shutting down.  Please post info about the standby and we'll try to help further.
Dan
mth57
mth57's picture
I replaced T1AH250V fuse the
I replaced T1AH250V fuse the day after I posted this problem and it has worked ever since. Once you have the cover off the fuse is very easy to locate.  I had switched the breaker to the outlet off by mistake.  I guess my old surge protector wasn't working.
Vettehead247
Vettehead247's picture
mth57 said: I replaced
mth57 said: I replaced T1AH250V fuse the day after I posted this problem and it has worked ever since. Once you have the cover off the fuse is very easy to locate.  I had switched the breaker to the outlet off by mistake.  I guess my old surge protector wasn't working.
I'm having the same problem I returned it to the store they replced it and now the new one did the same. I have searched for a fuse (T1AH250V) but haven't had any luck. Where did you find one?
jkorber
jkorber's picture
I have a TH-C30. I had the
I have a TH-C30. I had the same problem where the unit just stopped working - no standby light and no recognition of power at all. After checking this forum and another, I opened the unit, found the ceramic fuse where the power comes in and went to Radio Shack. They have a T1AL250V fuse pack that is a 1 amp, 250 volt, 5 X 20 mm SLOW BLOW ceramic fuse which is a better fuse for this common problem. Their RS number is 270-1063 and a pack of 4 costs about $3. Put new fuse in and the problem was solved. Perhaps the C50 uses a different fuse but Radio Shack can help you get the correct slow-blow ceramic fuse for your unit. Take in the old fuse...
The repair took minutes - 3 screws on the back and two screws on each side. Lift the cover from the back (it is slip-hinged on the front) and replace the ceramic fuse. It slips out with a little help and the new one snaps in place.
HelpmyJVC
HelpmyJVC's picture
same issue as everyone,
same issue as everyone, except I changed the fuse, plug it in, and fuse blows immediately. Help!
Lester
Lester's picture
Hey Guys, had the same issue.
Hey Guys, had the same issue. Called JVC and found the part # for the unit - in my case th-c60.
website to order from:
http://www.globalsemi.com/catalog.aspx?section=O1&subsection=4
Part #:QMFZ0591R0E
Hope this helps. Thanks to all on this thread provided alot of great info.
helpmyJVC2
helpmyJVC2's picture
I have JVC TH-C40, after
I have JVC TH-C40, after openning and pulling out the stuck DVD the power will not turn on after connecting to power outlet. where can I find the ceramic fuse in the receiver itself. I am not a tech at all! need help!
jkorber
jkorber's picture
I have the mod 30 but suspect
I have the mod 30 but suspect the same configuration for your C-40. See my August 08 post above for description of cover removal (unplugged). After cover is off, look right next to the point where the power cord brings the power in and you will see the small fuse in a metal fuse-holder that is frequently discussed. You might need a small screwdriver to pry the fuse loose/out. This is not a big issue to handle on your own. Also see my description of the fuse and wehere to buy a replacement.
RicLee
RicLee's picture
I purchased a JVC TH-C50 a
I purchased a JVC TH-C50 a little over a year ago. A couple months ago it worked perfect then one day I went to turn it on and although it has the standby light on, it doesn't work. The drawer for the DVD's doesn't open up, the FM/AM radio doesn't work ........ nothing works. Unfortunately the warranty is over with.
I really can't afford to take it to a JVC "authorized" repairshop.
RicLee
RicLee's picture
S.T.
S.T.'s picture
August 17, 2008 9:05 AM
I have a TH-C30. I had the same problem where the unit just stopped working - no standby light and no recognition of power at all. After checking this forum and another, I opened the unit, found the ceramic fuse where the power comes in and went to Radio Shack. They have a T1AL250V fuse pack that is a 1 amp, 250 volt, 5 X 20 mm SLOW BLOW glass fuse which is a better fuse for this common problem. Their RS number is 270-1063 and a pack of 4 costs about $3. Put new fuse in and the problem was solved.
Hi everyone. I purchased the slow blow glass fuse: 1 am 250 volt with no luck. Mine is ThC50
I did see it light up red then dead. Is this guy dead or does the fuse take some time to kick in?
thanx
dans_repair_service
There are cases where the
There are cases where the fuse blows unnecessarily. Replacing the fuse usually fixes that case. In your case, there is a real problem inside that is causing the fuse to blow to prevent further damage. This may be a simple problem or not. Without taking measurements and examining the actual system it is difficult to say. These are decent systems and are probably worth an estimate fee at a local shop. Try to get a detailed repair estimate and perhaps we can walk you through the actual repair using that estimate information.
Dan
DamianAK
DamianAK's picture
I opened the box up and
I opened the box up and replaced with a glass fuse 3 times and it blew instantly when plugging it in do i need to find a ceramic fuse or is my machine just done for.
DamianAK
DamianAK's picture
same problem with the machine
same problem with the machine blowing the glass fuse every time i plug it back in do i need a ceramic fuse or is my machine toast.
jkorber
jkorber's picture
Just get the ceramic slo-blow
Just get the ceramic slo-blow (slow to blow) fuse at Radio Shack (see other comments in the TH-C30 section). That will (should) resolve your problem.
gibbs
gibbs's picture
I came home recently to find
I came home recently to find my one year old JVC TH-C50 had lost power. When I unplugged and then plugged back in, it started flashing alternately between the red power light and a blue light that looks to be illuminating the DVD trays. I replaced the fuse with a slo-blow (although didn't suspect it as the cause) and still see this alternating light show. Any thoughts/suggestions appreciated.
Gryphon
Gryphon's picture
does anyone know the part
does anyone know the part number for the fuse? My radioshack doesnt carry the ceramic fuses and to order them through jvc you need a part number. . . i know it's a T1AH250V ceramic fuse but thats not working for a part number.
Gryphon
Gryphon's picture
does anyone know the part number for the fuse? my radioshack doesnt carry the ceramic fuse and to order it through jvc you need a part number. T1AH250V doesnt work for a part number. any ideas?
Gryphon
Gryphon's picture
sorry for the same post 2
sorry for the same post 2 times in a row. im new to this but i just spent some time talking to JVC if you are like me and have not found something to work or found the fuse anyware. you can try and order it from JVC. the part number is QMFZ059-1r0-E. I just ordered one and the total after shipping is $8 kinda pricy for one fuse but i have 5 movies in my player that beg to differ. i'll try and post again after i recieve it but no promises. good luck to everyone. there are alot of different pages dedicated to this piece of junk.
DamianAK
DamianAK's picture
i was in another town and
i was in another town and found the slow burn fuse and it works great now
tmmns110
tmmns110's picture
I have the same problem! I
I have the same problem! I replaced the fuse and still nothing!
Any suggestions?
WilliamNie
WilliamNie's picture
I have the TH-C30 unit and
I have the TH-C30 unit and was wondering if there was a subwoofer upgrade? Mine just doesn't seem to pack that much of a punch. I've tried different positioning in the room I have it in and nothing seems to work for me.
Blueo
Blueo's picture
I replaced the fuse and got
I replaced the fuse and got power but my DVD player won't open or have any audio to my TV. If I play the am/fm radio it works. What's wrong?
Mauiglider
Mauiglider's picture
I cant find T1AH250V fuse for
I cant find T1AH250V fuse for my jvc. I am having the same problem with no power. I hope this fixes it but where do I find this fuse???
Jason Kleinert
Jason Kleinert's picture
YO GIBBS - did you ever get
YO GIBBS - did you ever get an answer to this:
" came home recently to find my one year old JVC TH-C50 had lost power. When I unplugged and then plugged back in, it started flashing alternately between the red power light and a blue light that looks to be illuminating the DVD trays. I replaced the fuse with a slo-blow (although didn't suspect it as the cause) and still see this alternating light show. Any thoughts/suggestions appreciated."
can anyone help Gibbs and I with this situation?
gibbs
gibbs's picture
Jason,
Jason,
Never heard back from anyone. In fact, never heard of anyone else having this problem.
rwillems
rwillems's picture
I recently bought a TH-C50 to
I recently bought a TH-C50 to replace my TH-C20. Seems to be working but I can not get any sound out of my speakers. Can the TH-C20 speakers attach to the TH-C50 receiver? I can get sound out of my TV. The DVD player is working. Everything seems to work but the Speakers. I installed a different cable but no luck.
blankbilli
blankbilli's picture
the Slo Blo fuse from radio
the Slo Blo fuse from radio shack worked perfectly so far. Got the glass one they did not have ceramic in the shelf.
thanks for all the great advice... tH-C60 1 amp 250v fuse exactly where you said it would be.
Back up and running!
jkorber
jkorber's picture
I think they will not work
I think they will not work properly. I am just guessing but I think the ohms are different and I think the old speakers connected to the sub-woofer via proprietary cable and the new systems speakers connect direct to the amp. Could be wrong but this is my best guess after a few years...
rodpaiva
rodpaiva's picture
I just replaced the T1AH250V
I just replaced the T1AH250V ceramic fuse from my JVC TH-C50 system for a new slow-blow fuse from Radio Shack, but unfortunately the system is now turning on and off every two seconds. What is wrong? Any thoughts or suggestions? I really appreciate it.
