I can't set the time on a Sony Dream Machine
Forums:
The instruction manual was lost - I figured out how to change the time on this clock with the hidden button at the base of the clock but I can't get the times to stick.  All help is appreciated! Lou
loulldoit
loulldoit's picture
Hi Larry - I'll get back to
Hi Larry - I'll get back to you with the model # - it's at the farmhouse.  Thanks for getting in touch with me about this. Lou
loulldoit
loulldoit's picture
Okay Larry - I've got the
Okay Larry - I've got the model # - it's ICF C490. Lou
Larry Dillon's picture
The very short manual is
The very short manual is available HERE
loulldoit
loulldoit's picture
Thanks so much, Larry - you
Thanks so much, Larry - you're awesome......from what I've read, I can only figure the dream machine is not so dreamy .......... trust me, from what I've read, I've been setting the machine correctly.  I guess it's back to the manufacturer!  Thanks again, Lou
If you cannot set the unit,
If you cannot set the unit, you probably have a bad keypad or a broken connection going to it.  Very common problem.
loulldoit
loulldoit's picture
What's the bad keypad, Larry?
What's the bad keypad, Larry? Thanks, Lou
The little board or button
The little board or button assy. under the buttons you push.
Normanmx
Normanmx's picture
Hi there...
Hi there...
I lost the owners manual to a Icf-c218 sony dream machine and I just cant figure out how to set the time and other things..
Could anybody out there help me out?
Norman
PennyG
PennyG's picture
http://www.docs.sony.com
if you cannot follow the
if you cannot follow the directions in the owners manual. how are you going to understand any typed out instructions????
Daryl2
Daryl2's picture
I have a Sony Dream Machine ICF-218 and bought it specifically because I need the battery back-up for work. Recently the power went out and I noticed the display was off. Replaced the battery but when I unplug it, the display disappears again. It's not in backwards, seems battery related, everything else is ok...don't know what else to check! Nothing in the manual I can see.
I'd appreciate any ideas, Thanks.
Linda
Alex A
Alex A's picture
To set the clock, press and
To set the clock, press and hold the "Clock" button until you hear a beep. Use the "+/-" button to set the time zone. Press the "Clock" button. Use the "+/-" button to set the date. Press the "Clock" button. Use the "+/-" button to set the time. Press/hold the "Clock" button to save the data you've just entered/
Alan A
Alan A's picture
Thanks Alex that is awesome.
Thanks Alex that is awesome. I couldn't change my time either and lost the booklet. It worked!!
JR63
JR63's picture
I bought the Sony Dream
I bought the Sony Dream Machine for my daughter and paid nearly $180 for it from Myers. It stopped working in less than a year. The volume turns up to 20 (full) automatically and the times cannot be set. The buttons do not respond when pressed. I changed the battery and followed the instructions, but it still does not work. Very disappointed! (and yes, I can read)
gldnmjh
gldnmjh's picture
Gosh, Thanks for the tip....
Gosh, Thanks for the tip.....I've been trying for an hour and finally thought, look it up, dummy.... Got it. My husband went into a a tizzy this morning because the clock was in the wrong year and thought it was DAYLIGHT SAVINGS TIME!!! hahha!! It was a hoot!
Terence Oakley
Terence Oakley's picture
Lost the instructions to my
Lost the instructions to my sony dream machine clock radio ICF-C773L can any body help please
Terence Oakley
Dorai
Dorai's picture
I have a Sony Dream machine,
I have a Sony Dream machine, auto time set FM?AM clock radio model ICF-C218 I have lost the instructions can someone tell me how to set the time and alarm.
Thanks.
Terence Oakley
switch of the plug then on
switch of the plug then on it will read 12.00 press clock button and use + - button on top off clock to set the time
BuckBusterDeluxxxe
BuckBusterDeluxxxe's picture
Hold down the clock button
Hold down the clock button until the hour block digital clock display begins to flash. Next use the up-down button to set the hour desired.Then hit the clock button to activate the next routine which is the minutes.Set the minutes to the desired minute with the up-down button. Once the hour and minutes are set you can advance the function to AM-PM. I never heard a beep when I held down the clock button to start off with.the "clock" button is the key...just watch what flashes as you scroll through the functions with that clock" button. Once you activate a desired block...just use the up-down button to set your time. Good luck.....Buena suerte amigos...
Jen B
Jen B's picture
God bless you Alex! Clocks
God bless you Alex! Clocks that don't show the right time are SO AGRAVATING!!!! Thanks for your help.
bluejeanswomen
bluejeanswomen's picture
Lost instruction booklet can
Lost instruction booklet can anyone tell me how to brighten the screen
Also how to use an external Harddrive via usb..the dream machine shows no usb connected...
Any help out there I would apprecite it.
Reysplace
Reysplace's picture
Alex A, your a WIZ. Your
Alex A, your a WIZ. Your instructions were totally on point. Now I can sleep.
Thank you.
cathleen egan
cathleen egan's picture
When I set time on dream
When I set time on dream machine it automatically returns to 12:00
Serial # 6487546
Ardra21
Ardra21's picture
I have misplaced the
I have misplaced the instruction booklet for my Sony ICF-C318 clock radio. Could someone please tell me how to reset the time.
Thank you
Manny Chris
Manny Chris's picture
I have misplaced my
I have misplaced my instruction booklet to my Sony ICF - C318 clock radio. Could some one please tell me how to set my time also. Thanks
Trey Buttelmann
Trey Buttelmann's picture
The trick is that the "clock"
The trick is that the "clock" button is on the back of the machine.
wildcate
wildcate's picture
I lost my instruction sheet
I lost my instruction sheet for sony dream machine mod#10f-0218.Can you help print it out?
Are you kidding
Are you kidding's picture
I feel like an idiot, but I
I feel like an idiot, but I cannot get headphones to work on my Sony Dream Machine. I plug into the 'Audio In' jack, and the sound still continues to play through main speakers. What in the world am I doing wrong?
MsPink4life
MsPink4life's picture
You press aand hold clock...
You press aand hold clock.......and click it four times........until the whole time starts blinking....... then click the with the hiphen abd plus sign to your designed time and click clock and ur time is set
