Anyone who can make a suggestion I would greatly appreciate it. I have messed up the main TV and the wife is not happy.
I know next to nothing about the inside of a TV. Here is the problem. My center channel sucks in my surround sound so I thought I would open up the TV and hook up the TV speakers that are not being used to add a little kick to the vocals. I am in the field of Custom Electronics so I thought this should be easy. Here is what I did
Opened up the back panel and cut the speaker leads
Spliced on 22 guage wire to the amp and closed the panel
After I did this the TV would not power up so I put things back as they were when I opened the TV and still no luck
The hard power button comes on and blinks Red / The normal power button will not do anything. I have looked at the fuses and they are Ok?
Anything else I can try??
whats the make and model of the tv? did you blow the speaker's in it?
You did unplug the set before perfoming this little modification I assume?
