Durabrand DVD Home Theatre System Help
33 posts / 0 new
jrricky
I recently bought this device but i cannot seem to be able to get any sound from all of the speakers when i want to watch my cable channels. The surround sound from all the speakers only work when I play a dvd or a cd music disc. What can I do to get the surround sound from all my speakers when watching cable?
Hi jrricky,We'll have you up
Hi jrricky,
We'll have you up and running in no time, but we need to find out a little more about your setup.
If you're not getting any sound from your cable channels, I'll need to know what device acts as your cable tuner (the TV, cable box, VCR, TiVo, etc.), and how you connected the audio from that device to the back of the home theater system. What kind of cable did you use, and where is it plugged in to each device?
franky
I also bought a durabrand dvd
I also bought a durabrand dvd home theatre system..I can get the surround sound to work on my DVD's but not the TV alone, can anyone help me out. Thank you!
ron1966
i bought a durabrand dvd home
i bought a durabrand dvd home theater system and i cant get it to play sounds through my new tv .the dvd player works fine i got all kinds of jacks no matter what i do no sound through my tv alot of people have this problem but i see no solutions i have charter cable. can anyone help
ron1966 said:
Hi ron1966,
I'll pose the same question to you that I did the original poster of this thread.  If you're not getting any sound from your TV channels, I'll need to know what device acts as your TV tuner (the TV, cable box, VCR, TiVo, etc.), and how you connected the audio from that device to the back of the home theater system. What kind of cable did you use, and where is it plugged in to each device?
CKENWORTHY1986
i have just bought a
i have just bought a DURABRAND SA51AR home theatre system, to go with my DURABRAND 2127N tv. and DURABRAND CG5660-M freeview set top box. i have connected all my output leads obviously the speaker ones. but my input i have only one red yellow white jack on my tv and three sets of red and white jack leads with home theatre system. cant get no sound no matter how many times iv swapped the input leads ... any idea s whats going wrong :oS :(
my tv is running freeview through scrat and aerieal is through free view and linked bak to the tv.
Chantypo1971
Hi
Hi
I have just bought the Durabrand SA51AR 5.1 Home Theatre System, but it doesn't seem to be compatible with my TV, DVD player or SKY+ tv box. The SA51AR has 3 pairs of input cables but all my equipment only has 2 output. The cables are red and white in colour. Can you help?
Chantypo1971
Hi
Hi
Pickle121970
Hey,
Hey,
I just installed the same system and can only get the surround sound to work with the DVD player. Here is how I have ours hooked up right now. The VCR is hooked to our coax cable (Antenna In) then a coax cable from the VCR out to the TV In. From the VCR Audio Out L, Audio Out R, Video Out (Red, White, Yellow) I connected these to the DVD Audio In L, Audio In R, Video In. From the DVD player I connected the Audio Out L, Audio Out R, Video Out (Red, White, Yellow) to the TV Audio In L, Audio In R, Video In....I'm stumped. please help.
P.S. on this particular DVD player there are no S-cable hook-ups or coaxial hook-ups. My only remaining ports are a Y-port(green), Ps-port(blue), Pr(red), aand a digital audio output(orange). THANKS!!
Teresa Duckworth
I have misplaced the remote
I have misplaced the remote control for my Durabrand 2004 model or the Durabrand 2005 model. I am not sure which model it is. Can you tell me where I could purchase the Durabrand remote control for either one of these modles? A universal remote contral does not work.
Thank you.
Ahmed
After looking at the first 8
After looking at the first 8 blogs posted, we don't feel so damn stupid. Has anyone figured out how to get the sound through the tv too? Is it even possible? Or did we all just get ripped?
Florin
I have a Durabrand like that.
I have a Durabrand like that. Yes, from DVDs it is able to give sound in 5.1 (DolbyDigital) but it does not have any input for digital signal (I don't understand why). Perhaps somebody would know how to add a
Kam
i have the durabrand sts98rw
i have the durabrand sts98rw dvd player with surround sound system & cant get the sound to work with the cable only if were watching a dvd. it does not matter how it currently connected jus tell me what do do from scratch & i will do...thank you so much
arprincess said:
What do you mean "it doesn't matter how it's connected." That's the only thing that matters.
Without knowing what device tunes your cable, I can't give you instructions on how to do it. I can, however, give you the basic principle.
You'll either use a TV or set-top box (DVR, cable box, VCR, etc) to tune your cable channels.  You need to plug the audio ouput of that device into the audio input on the sound system. Turn on the sound system and select that input.
If you're using a TV, some sets don't have audio outputs. If so, you'll need to use a set top box to tune your cable. Some TVs have a setting in the menu to turn on the audio output. You won't get sound until you do.
Also, if someone would post a picture of the back panel of this "Durabrand" audio system, that would be helpful.
rogersk
how do you connect the
how do you connect the surround sound system to the television as mine only has a headphone jack and a audio in
rogersk said:
Technically, you could use the headphone jack. You'll need a 1/8" to RCA cord to plug in to your audio system. Then, make sure the volume on both the TV and audio system are up.
CANDACE
MATT CAN YOU PLEASE HELP ME.
MATT CAN YOU PLEASE HELP ME. I HAVE A SANYO DS24205 TV WITH THE AUDIO JACKS ON THE FRONT, AND IS ALSO CABLE READY RESULTING IN NO BOX. I HAVE THE DURABRAND STS98RW DVD HOME THEATER SYSTEM. I BOUGHT AN RF MODULATOR TO HOOK UP THE TWO DEVICES. AND I TOO, AM HAVING THE SAME PROBLEM AS OTHER FOLKS. SURROUND SOUND ONLY WORKS WITH DVDS OR CDS. WILL A DIGITAL AUDIO COAX FIX THE PROBLEM? I DO KNOW THERE IS ONLY 1 VIDEO CHANNEL WHEN YOU PUSH THE TV INPUT BUTTON ON THE REMOTE.THE BACK OF THE HOME THEATER SYSTEM HAS THE POWER CORD, COLOR CODED SLOTS FOR EACH SPEAKER AND AUDIO IN AND OUT, VIDEO IN AND DIGITAL AUDIO I THINK.
CANDACE said:
Candace,
First, please don't type in all caps. It's considered rude in just about every forum. It's even in the site rules:  http://www.techlore.com/help/forum_policy
Second, your TV does not have any form of audio output. The jacks on the front are INPUTS, not outputs. So, if you rely on the internal tuner to watch your cable TV, there's no way to get the sound out of the TV and to your audio system. In your case, there's not even a headphone jack to work with.
If you want to hear sound while watching cable TV, you'll need to use a cable box, DVR, TiVo, or even an old VCR instead of the tuner in the TV. All of those other devices have audio outputs that can be routed to your audio system.
CANDACE
Sorry for all caps. Its a
Sorry for all caps. Its a habit that i use even when printing. I was told it was a left handed, right brained thing.I bought a digital audio cable. Is it possible to hook my ihome up for this use. It does have an audio out jack. If so, will it only play through the ihome speakes or both the ihome and surround sound? Do i just hook the cable to audio out on the ihome and to digital audio on the home theater system.
CANDACE
And at this point im grasping
And at this point im grasping at straws. Could i even use a second dvd plaer for this?
Okay, let's slow down a bit and figure it out before you go buying
stuff. mmmkay?
A few questions:
Let's start with the goal. Your first post made it sound
like you wanted to get the sound for your TV channels to come out of
your surround system. Is that correct?
Currently, you watch cable through the TV's tuner. There's no cable box or DVR in the mix. Correct?
I'm pretty up to date on stuff, but I don't know exactly what you mean by your "ihome." Are you talking about an iHome iPod Dock? Can you be specific about what you're talking about, perhaps a web link to a product page so I can be on the same page?
CANDACE
Yes my goal is to get sound
Yes my goal is to get sound from my cable tv channels through the surround sound. And you are correct about the tv as well. It is cable ready so my coax connects directly into the back of the tv.
My ihome is an ipod dock. Its actually an iStereo iP915 made by KODA. It was bought from Wal-Mart. I would rather not hook it up this way if other options will work. I have an extra dvd player still in the box but am open to any suggestions
CANDACE
I also have a set of 2.1
I also have a set of 2.1 channel speakers from coby in the closet. There are 2 satellite speakers, right and left, and a subwoofer. On the back of the subwoofer there is 1 audio input and a (L) and (R) audio output. Would this be any help
Great, thank you for the clarification. Now, let's think through this for a moment...
How do you believe connecting an iPod dock to your surround system will
result in letting you hear cable TV channels?
Think about it this way. In order for the iPod dock to send the sound from the TV's cable tuner to the surround system, you'd still need to get the sound out of the TV and into the iPod dock. Of course, if you could do that, then you wouldn't need the iPod dock!
Therein lies the problem. The only device you have that can tune in your cable channels, the tuner in the TV, doesn't have any audio outputs.
So, we need a different cable TV tuner... one with audio outputs. Your iPod dock doesn't have one of those (you can't plug your cable line into it), and neither does a DVD player (a DVD recorder would though, but that's probably not what you have). Your other speakers don't tune TV, either. You need something like a cable box, DVR, TiVo, VCR, or a new TV with audio outputs. There's no other way around it.
CANDACE
Oookkaaayyyyy. Now i see. I
Oookkaaayyyyy. Now i see. I was so missing the obvious need for something to plug the cable line into. I was only looking for the little audio out jack. Thanks so much!!! Now i just have to find a cable box or vcr, etc.
simarik
Help! Bought a Durabrand HT
Help! Bought a Durabrand HT 395 and hooked it up to a 28" RCA TV and
SONY DVD player (both fairly new) and now the TV rolls frequently and
we often get a distorted band across the top of the screen. We do NOT
have a VCR attached. Any ideas? The rolling is driving us insane. By
the way, the sound is excellent. Thanks!
Thanks & Regards
_____________________________________
Wide Range of  Wholesale Consumer Electronic
odiedo
ok, I bought the durabrand
ok, I bought the durabrand home theater system second hand as part of a package deal with a t.v.. The guy that sold it to me had it working without a hitch. I recently unplugged it, because I bought a new power strip with a surge protector in it. All I did was unplug the main cord, and now it will not work at all. There's power going to it, but no sound will come out. I think it has something to do with pressing a button on a certain channel, but idk...my boyfriend is ready to trash it and spend a fortune on a new system, but I am convinced it's something really simple and stupid...PLEASE HELP!!
iluv2waltz
I have a Durabrand STS98RW
I have a Durabrand STS98RW Theater System. It was working fine for the last 4 or 5 years. I recently got a flat screen tv and I disconnected it from old to hook into the new one. Now it the DVD door does not open and there a system 545 that i would guess is an error code running across the display. What does this mean and what can i do to fix it. Help please thanks
CANDACE
I'm back. As you can see in
I'm back. As you can see in my earlier posts back in February, im having problems getting sound out of my tv. I have a new Crosley tv with 3 hdmi connections, an svideo connection, 2 compostive connections, s vga/pc connection. Will any of these help me to get sound from my cable tv channels to come through the Durabrand home theater system? The Durabrand has the yellow, white, and red connectors. And also an orange audio out. Thanks
gary shaw
i have a durabrand home
i have a durabrand home theater system and only my front speakers and sub are working.help
William Jones
My HT 400 Home theaater audio
My HT 400 Home theaater audio system was working perfect when I went to bed, the next morning it would not turn on...Why? Any suggestions?
